6 inch lift without cutting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B1gJack15, Apr 7, 2022.
  1. Apr 7, 2022 at 5:32 PM
    B1gJack15
    B1gJack15 [OP] Active Member
    Jackson
    2015 DCSB White Prerunner
    I wanted to know if there is any way I can get a 5 or 6 inch lift without cutting anything. I don’t do off-roading or go ride in mud. I have a 2015 Prerunner.
  2. Apr 7, 2022 at 5:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    4" spindle lift, 2" adjustable coil over.
    But the burning question is why?
    blu92in99, bigmw, Junkhead and 2 others like this.
  3. Apr 7, 2022 at 5:59 PM
    B1gJack15
    Jackson
    Would they need to cut if I ended up doing that?
  4. Apr 7, 2022 at 6:40 PM
    TacoTuesday1
    SD CA
    Prerunner
    Not off-roading
    6” lift
    lol
    Junkhead likes this.
  5. Apr 7, 2022 at 8:57 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    6” body lift /thread
    wilcam47 likes this.
  6. Apr 7, 2022 at 8:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  7. Apr 7, 2022 at 9:06 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    This is your answer.
  8. Apr 8, 2022 at 5:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    I answered what you asked originally, which was a no cut solution.
    Some simple Google research on how these parts work and you'll get it.
    Cutting is typically a drop bracket lift. You're doing well to try and avoid that.
    But you also avoided answering 'why?'
    blu92in99 likes this.
  9. Apr 8, 2022 at 5:53 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I'm pretty sure the only reason for cutting the stock cross member when doing any 6" drop bracket lift is to make room for the front driveshaft. You don't have one so I doubt you'd have to cut it.
  10. Apr 8, 2022 at 7:25 AM
    B1gJack15
    Jackson
    Thanks for the solution. New to everything and wanted to lift my truck in that general range.
  11. Apr 8, 2022 at 7:50 AM
    B1gJack15
    Jackson
    Do you know how much something like that would cost by chance
  12. Apr 8, 2022 at 7:51 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Google: Tacoma spindle lift kit
  13. Apr 8, 2022 at 8:09 AM
    B1gJack15
    Jackson
    I assume you’d get 4 right? Sorry for questions but I’m not knowledgeable with this type of stuff
  14. Apr 8, 2022 at 9:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    The rear doesnt have spindles to replace.
    As far as costs, you can do your own shopping.
  15. Apr 8, 2022 at 9:13 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    You can put a drop bracket lift on a pre runner with no cutting if you want. You only cut the frame on a 4wd
    Grey 2015 likes this.
  16. Apr 8, 2022 at 9:18 AM
    B1gJack15
    Jackson
    So will it basically squat my truck if I get the 4” spindle lift and 2” adjustable coil over?
  17. Apr 8, 2022 at 9:25 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    Yeah you'll need to add a shackle flip lift, blocks, or a new leaf pack to lift the rear
  18. Apr 8, 2022 at 9:33 AM
    B1gJack15
    Jackson
    Say I were to do the two previous things to the front, would a 4 inch block make it level or do I need to go less?
  19. Apr 8, 2022 at 9:34 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    3" suspension lift and 2" body lift. Will out perform any crappy bracket drop lift.
  20. Apr 8, 2022 at 9:35 AM
    skeletron
    Clark
    Sakerlina
    2020 TRD Broh
    4" block ought to make you level or with just a little rake since the truck should sit about an inch higher in the rear stock
