6 inch Procomp Stage I or II?
Discussion in 'Suspension' started by caleb337, Jun 20, 2008.
  1. Jun 20, 2008 at 8:58 PM
    caleb337
    caleb337 [OP] Lifted Tacoma
    Carencro, Louisiana
    6 inch lift on a 05 SR5 TSS
    6 inch Procomp Lift, 35 inch Mud Terrains.
    What's the difference between 6 inch Procomp Stage I and Stage II? And which one is better?
  2. Jun 20, 2008 at 9:32 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    This is what i got from the website.
    Our Stage I system includes lower control arm drop brackets,
    differential drop brackets, sway bar lowering hardware and an
    additional rear cross member. Ductile iron spindle adapters
    are used to maintain factory tire rod angles and eliminate
    bump steer.
    Our Stage II systems add supported lower control arm drop
    brackets to eliminate lateral flex and cross member
    compression struts add a custom appearance. 90-95 4Runner
    achieves rear lift with 4” coils, 4-link relocation brackets and
    track bar relocation bracket
  3. Jun 21, 2008 at 8:04 PM
    caleb337
    Carencro, Louisiana
    So, would it be a bad decision to buy the Stage I?
  4. Jun 21, 2008 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What are you lifting to achieve? More off road performance or just for looks?
  5. Jun 22, 2008 at 1:04 PM
    caleb337
    Carencro, Louisiana
    Just for looks
  6. Jun 22, 2008 at 1:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Then you will be fine with the stage 1. :)
  7. Jun 25, 2008 at 12:56 AM
    20taco07
    20taco07 Well-Known Member
    sacramento
    2007 toyota tacoma sr5 trd sport 4x4
    chris pretty much gave u the answer, stage 2 comes with aftermarket coil overs that are much better than stock off road, and they are firmer, stage one is on stock suspension pretty much, but thats all u need for looks
  8. Jun 1, 2012 at 6:51 AM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    I'm lookn at stage 1 and 2 but I'm doing jut for looks also ... But I do care how it will ride .. If it don't feel anything like the stock ... I'm willing pay the ex money ... So should I buy the stage 2 or will I be happy with stage 1 . Need to know soon ordering with in week
  9. Jun 1, 2012 at 6:58 AM
    K1992f
    Kanon
    Ok thanks
