6" Lift Alcan Rear Leaf Pack
Discussion in 'Suspension' started by prodigy808, Mar 2, 2011.
  1. Mar 2, 2011 at 10:30 PM
    prodigy808
    prodigy808 [OP] Active Member
    TX
    2011 Tacoma DC, LB TRD Sport 4x4
    For those currently running these leaf packs, are these a direct bolt-on project, or are longer shackles, hangar relocation required for install? Setup would be on a 2011 Doublecab longbed 4x4 TRD Sport with 6 inch Procomp lift. Would like to rid of lift blocks in rear and get a set of these. Any help would be greatly appreciated.
  2. Mar 2, 2011 at 10:36 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
  3. Mar 2, 2011 at 11:01 PM
    prodigy808
    TX
    Thank you very much S.B.
  4. Mar 2, 2011 at 11:05 PM
    S.B.
    Sean
    No problem.
  5. Mar 2, 2011 at 11:06 PM
    prodigy808
    TX
    Looks like he got longer shackles installed.
  6. Mar 2, 2011 at 11:54 PM
    prodigy808
    TX
    Also would like to run Bilstein 5125 shocks in the rear. What length/travel/valving would be recommended for this leaf packs? Light wheeling and towing main concern while keeping it close to smooth ride as possible.
  7. Mar 3, 2011 at 7:28 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
  8. Mar 3, 2011 at 7:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    keep in mind 5100 series shocks arent stem top. you have to have an adaptor which costs you wheel travel cuz it pushes the shock down further.
  9. Mar 3, 2011 at 9:05 PM
    prodigy808
    TX
    CT thanks for the link. Truck is sweet lookin even at stock height ain't it. NoFords which shock would you recommend if not 5125
  10. Mar 4, 2011 at 6:47 AM
    PLC721
    Patrick
    Chandler, Az
    i do recommend the 5125, however the perfect set up is the 12" travel 5160 because it has a stem top, but i have not done this yet personnaly, this is all info i have researched but i look forward to testing the 5160's out!
  11. Mar 4, 2011 at 6:48 AM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    get some longer shackles out back and have deaver's custom make you a leaf spring kit.
  12. Mar 4, 2011 at 6:50 AM
    PLC721
    Patrick
    Chandler, Az
    ^^ he's the man to ask
  13. Mar 4, 2011 at 10:21 AM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    what rear shocks are you running and yes i read your build thread cant find it anywhere?
  14. Mar 4, 2011 at 10:41 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    Man i wish I knew about these before I got my all pro expedition's
  15. Mar 4, 2011 at 10:50 AM
    PLC721
    Patrick
    Chandler, Az
    i believe he is still running the fabtech dirt logics
  16. Aug 10, 2011 at 9:43 AM
    KingofRedwood
    KingofRedwood Member
    Cuong
    Castro Valley
    2011 Tacoma 4x4 TrdSport
    It happen that I have exactly the same model like your with the same lift and the same thought - get rid of the rear bock. :D
