6" lift pros/cons
Discussion in 'Suspension' started by Capitol, Jan 19, 2023.
  1. Jan 29, 2023 at 7:17 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Some state(s) will fail your inspection for cutting the crossmember
    there was a thread on this in the last week or so
  2. Jan 30, 2023 at 1:08 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Oh, my bad. Maybe some other company then…?
    I have Rough Country’s kit in my FJ Cruiser, it don’t need any cutting.
  3. Jan 31, 2023 at 1:57 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    So I looked up Rough Country's kit specifically for the FJC, and I now see the FJC front kit is designed different than the Tacoma front kit (I guess I too thought they were at least similar).
    The FJC frame must be different enough to allow no cutting, though I can't make out exactly what it is different in the photos (I can see for certain the mounting of the diff housing to the crossmembers is different, and they use a new rear diff mount whereas the Tacoma kit reuses the OEM piece).
    https://s3.amazonaws.com/roughcountry/install/92177000A.pdf
    The OP however does not show an FJC in his profile, he shows a Tacoma... So looks like he has to cut if he wants more than 2" lift without risking shortening the life of frontend components.
    Again, save the piece that was cut. It's not the big deal so many make it out to be to weld it back in and return the truck back to stock to sell, put a different kit on, whatever. Only thing is make sure your guy doing the welding (if you don't do it yourself) is competent.
    That's messed up! I hadn't heard anyone complain of that before... I wonder if the guy had a newly-hired schmoe doing the inspection who didn't know what they were looking at (RC and others all provide a replacement crossmember that goes underneath the cut one).
