6" Lift Question
Discussion in 'Suspension' started by Rbohno, Dec 20, 2010.
  1. Dec 20, 2010 at 9:17 PM
    Rbohno
    Rbohno [OP] Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    Why does some of the 6" lifts I have looked at say must use 17" or larger rims with 4.5" of backspacing or less. I get the backspacing requirement, I just bought new 16" x 8" rims with -0- offset which equates to 4" of backspacing so I got that part covered but whats the deal with the diameter of 17" or greater requirement.
    What does the diameter of the rims have to do with the size of the tires you can install?
  2. Dec 20, 2010 at 9:19 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    i think its because the kit moves the steering knukle up or it moves something up that requirs a larger rim
  3. Dec 21, 2010 at 5:48 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    An 8" rim with zero offset has 4.5" backspacing, not 4".
  4. Dec 21, 2010 at 8:33 AM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    I bought the rims from Discount Tire and they list their rims by offset and when you ask them about backspacing they give you the "deer-in-the-headlights" look.
    So I got the manager involved and he told me that a -0- offset equated to the mounting surface of the wheel being exactly in the center/middile of the wheel so the following wheels with a -0- offset would be :
    • 8" wide wheel - 4" backspace
    • 9" wide wheel - 4.5" backspace - So what would the back space be for this wheel *
    And so on.................So I am not surpised if I was misinformed, I just took his word for the backspace amount of my new wheels and didn't measure while they were sitting there in the box.
    * This is the wheel they test fitted the 285/75/16 Nitto terra grappler on my truck with and it hit pretty bad in the front.
    Will the 8" wheel be better or worse with regards to fitment of a 285/75/16 on my truck?
    Thanks for your input/info
  5. Dec 21, 2010 at 8:42 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The centerline of the rim is based on the outside width, not the "rim width". Rim width is the inside bead. The center of the rim width and the centerline will not lie in the same place.
  6. Dec 21, 2010 at 8:43 AM
    KPT
    09 Prerunner
    Here this page has lots of good info, including a chart that will help you convert width and offset to backspacing
    https://www.rsracing.com/tech-wheel.html
    Damnit Ben that's the second time you've beaten me today!
  7. Dec 21, 2010 at 8:43 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    The reason they say a certain rim size is because of the larger spindle.
  8. Dec 21, 2010 at 8:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :cool:............
  9. Dec 21, 2010 at 9:06 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    and the fact that the tie rod is flipped to the top of the knuckle and not from the bottom like the factory setup.
    Justin
  10. Dec 21, 2010 at 9:17 AM
    kinkrider101
    santa barbara
    wheels and tires
    But I think you can run spacers in the front to fit a 16" rim
  11. Dec 21, 2010 at 11:02 AM
    Rbohno
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Damn, never cease to amaze me with all the knowledge thats out there!!!!!
    The term "stacked" when mentioning spidertrax scares me, define the amount of stacked.
    Thanks
  12. Dec 21, 2010 at 11:04 AM
    Chachie
    Justin
    Nor Cal
    Im guessing here but i think he means stacked as in combined with. ....although you could run a ton of stacked spacers and be like 10ft wide in the front!!!!! hahahahahaha
