6" lift rear shocks? / lift upgrade questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by devanb3, Apr 17, 2015.
  1. Apr 17, 2015 at 9:52 PM
    devanb3
    devanb3 [OP] Well-Known Member
    devan
    hampstead
    im looking for a set of decent shocks for the rear of my 2013 tacoma trd sport 4x4 lifted 6 inches... i have a rough country 6"lift and want to update this rear shocks that come with it.., any suggestions ideas???
    also because the rear uses a 4inch block on top of stock springs, im considering getting the ome leaf set that lifts 2.75 and put a 1inch block on that to lesson the block size in the rear and possibly doing the same with the front by updating my stock springs to bilstien 5100s set to the 2.75 setting with a smaller block up front... is this a bad idea???
    please if your going to say no dont do it please say why and have an actual educated reason...
  2. Apr 18, 2015 at 11:08 AM
    devanb3
    devan
    hampstead
    Nice thanks didn't realize they had an add a leaf for the set... What about shocks for rear for a 3-6in lift
  3. Apr 18, 2015 at 10:12 PM
    RudedogII
    RudedogII Well-Known Member
    So Cal
    Stock 2010 Double Cab 4x4
    None yet but in the works!
    Measure your exsiting shocks and order the same lenght form Doetsch Tech.
    I just got some Prerunner 8000 for the rear of my 2010. Only $45ea.
  4. Apr 18, 2015 at 10:22 PM
    RudedogII
    So Cal
  5. Apr 20, 2015 at 8:11 PM
    devanb3
    devan
    hampstead
    thanks also just found a set of bilstein 5100s that are for rear 3-5in lift...
    also if bilstein 5100 front give 0-2.5 and ome 2887 coils give 2.5-3 inches of lift well the combination give a 5-6 inch lift or am i looking into this too much???
  6. Apr 21, 2015 at 5:54 AM
    Pigpen
    Dan
    Northwest Montana
    You can't preload these coils safely. Even if you could, there would be no down travel in the strut - you'd already have it maxed out.
