6 lug strut to 5 lug strut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2nd gen 5lugger, Nov 29, 2017.
  1. Nov 29, 2017 at 10:32 AM
    2nd gen 5lugger
    2nd gen 5lugger [OP] Member
    Ohio
    2013 trd off road
    Was curious if there is any real difference on the 5 lug strut and the 6 lug strut. Is there anyway you can fit the 6 lug style strut to 5 lug? Only thing that I know is different is that the brake line tab that holds the line in place
  2. Nov 29, 2017 at 10:42 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    anything is possible. Just depends on how handy you are with tools
  3. Nov 29, 2017 at 10:48 AM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    I would suggest that @2nd gen 5lugger head on over to the 5-lug section and start reading.
    https://www.tacomaworld.com/forums/5-lug.114/
    The Bilstein 4600 series struts usually found on the front end of the 6 lug Tacoma Pre-runner line, are easily transplantable into the 5-lugs. The Bilstein 5100 series rear shocks can also be run, if you are running an additional AAL leaf spring.
  4. Nov 29, 2017 at 11:31 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    dimensions of the front suspension on a 5 lug vs 6 lug are alllllllll sorts of different, get shocks meant for your truck.
