6" powered Bazooka Sub
Discussion in 'Audio & Video' started by Jhunter, Dec 29, 2014.
  1. Dec 29, 2014 at 7:27 AM
    Jhunter
    Jhunter [OP] Well-Known Member
    Atlanta
    Black '14 TRD DCSB
    Just getting started
    Disclaimer: This is just some first hand feedback for someone wanting to make a system upgrade with minimal expense and limited time. Keep in mind that this Sub is not intended to win any stereo competitions and is probably not what the 'hard core' guys want or like.
    So with all that said, I purchased a 6" Bazooka 100 watt powered subwoofer from Amazon for $150. I have a 2014 DCSB with the factory Non-JBL audio system. The stock system is 'decent' but really lacks bass. After reading a bunch of reviews, I figured what the heck. Wow! this little sub thumps hard and totally changed the sound of the stock system:eek:. The Amp does have a gain control and I set it at about 40%. Install was pretty simple. I removed the driver side plastic tray from behind the back seat. The sub fits nice and snug with no issues or straps. I then ran the fused link from the battery back to the sub (under the truck and drilled a hole into the cab floor). Grounded the unit to the cross bar on the back wall. Lastly, I had to splice into the rear door speakers (Right & Left) and jump some speaker wires to the sub. In order to do this, I had to undo the seat belt and pull the plastic from the pillar between the front and back doors. This was the most time consuming part. Overall, it was a great $150 purchase with a huge impact.:D
  2. Dec 29, 2014 at 9:07 AM
    Doc Jr 8156
    Doc Jr 8156 Well-Known Member
    Rancho Cucamonga
    2013 DCLB Pyrite Mica 4X4 TRD Sport
    King 2.5 Shocks w/ resi front and rears Total Chaos UCA Icon AALeafs SCS SR8 Wheels BF Goodrich TA KO2 tires All Pro Apex Sliders K&N Air Filter TRD Seatbelt Straps TRD Hubs DeZee Bed mat Extang Trifecta Viper 5904 Alarm Antenna X Ultra Gauge AFE Stage 2 Intake TRD Exhaust OEM Roof Rack HID Headlights and Fogs Weather tech laser mats Alpine CDE 149BT Headunit HAT Clarus 6.5 components front and JL Audio C2 650x for rear 2 Alpine SWP T-10 shallow 10-inch subwoofers Alpine PDX V9 main amp, Alpine PDX M-6 mono sub amp Dual 10 inch sub box Pop-Lock Anytime fog mod Differential breather mod KB Vodoo Bed Brackets KB Vodoo Tailgate protector Midland Portable CB Firestick CB Antenna Osram Headlight Bulbs and Rallyelights harness
    Hello,
    Why do you need to drill a hole on the cab floor just to install power for your sub? You can just run the power wire with fuse from the battery to the firewall then along the side floor panel to the sub location. Godspeed.
  3. Dec 29, 2014 at 9:12 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    x2, I would never have done that. That metal will be so sharp and will rub and eventually SHOrt out and burn your truck down. SEEn it happen.
    Please make sure you maybe insert a grommet or run via firewall anyways
  4. Dec 29, 2014 at 10:44 AM
    Jhunter
    Atlanta
    Black '14 TRD DCSB
    Guys - I used a small rubber grommet in the drilled hole. Should be safe for years to come...
