6 pre outs, 7 channels, what's the limiting factor?
Discussion in 'Audio & Video' started by sweater914, May 22, 2009.
  1. May 22, 2009 at 8:22 AM
    sweater914
    sweater914 [OP] Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    Here's the hypothetical situation I have with another vehicle at home. I can easily install one pair of speakers in the kick panels, another pair in the front doors, and one more pair of speakers on the rear deck, plus a subwoofer.
    I'm curious as how this setup would be wired. If the HU only has 6 pre outs but 7 channels as described above, how/were would you plugin or splice into the RCA cables to get the signal from the HU to the speakers? In this scenario assume multiple amps.
    Please excuse my simpleton mind, my only install has been with a 4 channel amp to 4 channels, pretty easy.
  2. May 22, 2009 at 8:28 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    You can split the RCA with Y adapters for highs/mids/or low pass.
  3. May 22, 2009 at 8:29 AM
    4x4Taco
    Ontario
    07 TRD Off-Road 4X4
    I dont think I have ever seen 6 preouts on a head unit???
  4. May 22, 2009 at 8:40 AM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    run the kick panels and doors off the same channel.
  5. May 22, 2009 at 8:47 AM
    sweater914
    North Dakota
    That was quick.:D
  6. May 22, 2009 at 8:50 AM
    sweater914
    North Dakota
    The crossovers that you describe are they in addition to the crossovers provided with a component setup?
  7. May 22, 2009 at 10:42 AM
    sweater914
    North Dakota
    That seems to address the situation, however please let me know if I've gone off the deep end, replacing several crossovers which came with the component speakers at substantial cost with an all-in-one crossover seems counter intuitive. After reviewing several sites and reading about component speakers, manufacturers make a huge point as to the quality of not only the speakers but the crossovers provided with their setups. My understanding of crossovers are they filter out certain frequency ranges which are undesirable for the speaker (ie you don't want an 80hz signal going to a twetter). If this is the case how important is the quality of the manufacturers provided crossover? Is this all a marketing ploy or is there some substance to using the provided crossovers?
  8. May 22, 2009 at 11:13 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    not uncommon.
    2 for front speakers
    2 for rear speakers
    2 for subwoofers.
  9. May 22, 2009 at 11:51 AM
    sweater914
    North Dakota
    Then why would you sacrifice the superior quality of the speakers crossover by re-installing your Sony unit? Unless your Sony ES outshines the other crossovers.
    4x4Taco stated you could use Y adapters, but with every additional connection isn't there the possibility of adding signal noise?
  10. May 23, 2009 at 9:53 AM
    sweater914
    North Dakota
    Let's take the discussion a step farther, the folks who build competition systems with more speakers than your local Best Buy, how do they manage all the sound? Aside from a wiring mess, there must be some central hub for all the speakers to eventually get back to the HU.
