6'' Pro Comp Lift Kit Help..
Discussion in 'Suspension' started by agaona, Apr 28, 2011.
  1. Apr 28, 2011 at 6:31 AM
    agaona
    agaona [OP] Member
    Adrian
    Laredo
    13 Tacoma Texas Edition 4x4
    3" nitro lift by pro comp
    Hello guys, I am new on this site and I need a little help or guidance. I've bought my first Tacoma last week (2011, 2WD, Double Cab, Prerunner SR5) and I was looking into lifting it. Would you recommend a 6'' lift for my new truck? Or what what other brand would work best for my truck....
    Thanks
  2. Apr 28, 2011 at 6:37 AM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    pro-comp K5073b or K5073BMX that is for a 6" Lift Tacoma with VSC
  3. Apr 28, 2011 at 6:49 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    No db for a prerunner,,get spindles and 5100s
  4. Apr 28, 2011 at 7:02 AM
    agaona
    agaona [OP] Member
    Adrian
    Laredo
    Thanks guys for your response. But what are the differences between the two (6'' Pro Comp Lift Kit vs Spindles & 5100s)?
  5. May 8, 2011 at 8:50 PM
    ColoradoTaco
    Boulder
    2013 DCSB OFFROAD
    If you have a 4wd truck you have to get a drop bracket lift i.e. pro comp etc. this cuts a piece of you cross member away tomake room for the front drive shaft to you differntial.
    If you have a 2wd truck you can get 6" of lift without cutting the crossmember using spindels and new coilovers............i have no clue about this method but there are threads in here about it search 6" spindle lift
  6. May 8, 2011 at 9:48 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    spindle lift if 2wd
    don't waste money on a drop bracket kit..
    or long travel if you have the money is always nice :)
  7. May 8, 2011 at 9:49 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Go with spindles
