6" Pro Comp Lift on 09 Taco
Discussion in 'Suspension' started by FuryGrrl, Jul 29, 2013.
  1. Jul 29, 2013 at 8:37 AM
    FuryGrrl
    FuryGrrl [OP] Active Member
    Heather
    Rhode Island
    2009 Tacoma 4x4 TRD Sport
    towing package 6" Pro Comp Stage 1 lift
    Just had a 6" Stage 1 Pro Comp lift installed in our 09 Taco. Advanced Automotive Performance in Uxbridge MA did an amazing job. 12 hour install. 33" Toyo Open Country Tires on 18" KMC XD Addict wheels. She's beautiful! Can't wait to buy more goodies for her.
    Anyone else run in to a problem with the tire pressure sensors with new wheels & tires? Were told that we were required to buy them (Town Fair Tire), they were installed, but now the light is either flashing or just on. I thought I heard somewhere from someone that we may need to take it to the dealer to have the sensor reset or something?
    Also, any tips on maintaining the longevity of the wheels? Particular cleaning solutions you use?
  2. Jul 29, 2013 at 8:58 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DBCB SB 4x4
    Yes
    Great looking truck ! The TPMS sensors can be a complete pain even within the OE spare tire too. If you search " TPMS bypass " on any Toyota truck forum you will find a 10 minute quick way to disable the TPMS dash light and then you can remove the sensors completely.
    You have a TPMS set button under too right next to your hood latch release... Search TPMS on this forum and you will find a ton of info.
  3. Jul 30, 2013 at 5:35 AM
    FuryGrrl
    Heather
    Rhode Island
    Thanks!
  4. Jul 30, 2013 at 5:37 AM
    Codyj8
    Codyj8 Shit'll buff out!
    Cody
    Hardin, MT
    01 Silver Tacoma 6'' lift on 35's
    Uniden CB, 5" Firestick, Allpro tube bumper, homemade rear tube bumper, Fuse pannel, Zeus 20in lightbar, zeus led pods, 9500lb Superwinch, LED turn signals, LED tail lights, Husky toolbox with LED break lights, Rhino lined bed/bottom pannels of truck, tinted windows, Grey wire mod, Undead Offroad rock sliders, 35in Goodyear Kevlars, 15in steelies (black)
    Looks good! And welcome to TW:)
  5. Jul 30, 2013 at 5:43 AM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    Truck looks real good. How much did the lift cost to install?
  6. Jul 30, 2013 at 7:30 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    A little lift & some extra steel....
    Truck looks great Heather! Tire longevity......be sure to get an alignment after this install.....if they didn't already do it. And rotate those tires with every oil change....33's aren't cheap so you'll want them to last. I did not have any issues with my TPMS after changing wheels so I can't help there.
  7. Jul 30, 2013 at 7:35 AM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Longetivity of your tires. Make sure you get them aligned after the lift (the shop might have already). Also rotate your tires EVERY oil change. Truck looks great btw
  8. Aug 5, 2013 at 8:25 AM
    FuryGrrl
    Heather
    Rhode Island
    It was 12 hours of work, plus they had to replace the bushings in the front end and they did an alignment. Total was $1950 at the shop for the install, bushings & alignment.
    Great suggestion about rotating every oil change! Will def be doing that.
    I've looked up the TMPS a little more. From what it seems, the new sensors have codes that go with them. I guess we need to get the codes and go to the dealer to have them reprogram the sensors? I tried the reset process that was in the manual but it didn't do anything. It's indicating a malfunction. I think we'll just deal with the light. The tires take 88 psi but there's no way we're keeping that much in there anyway.
  9. Aug 5, 2013 at 8:34 AM
    FuryGrrl
    Heather
    Rhode Island
    Took her in our little local trail system after breakfast. beautiful sunday morning ride. can't wait to get a wench to see what she can really do! On that note - does anyone have any suggestions on an air compressor that we can take along with us? We had gotten one from Harbor Freight that SAID it was good up to 250 psi (BAHAHAHAHAHA!) but it wouldn't even blow up an air mattress. the Taco has the outlet in the back, but is it strong enough to power an AC? I know it doesn't power a circular saw...
  10. Aug 5, 2013 at 8:41 AM
    Warputer
    2011 TRD Off Road
    Agreed.....or the center tread will be completely gone in months.
  11. Aug 5, 2013 at 11:26 AM
    FuryGrrl
    Heather
    Rhode Island
    we have them at about 46psi right now. is that bad i wonder? i wonder what is the minimum pressure you should have in 33s? she's a daily driver. we put it up to 70 pounds the other day just to see if the tire pressure light would go off (it didn't so we lowered them back down).
