6" procomp tire size questions
Discussion in 'Suspension' started by Sage, Feb 2, 2012.
  1. Feb 2, 2012 at 12:40 PM
    Sage
    Sage [OP] Well-Known Member
    SoCal
    07 TRD Sport
    So I have a 2007 TRD sport and want to go 6" not to familiar with IFS, I've see a lot of stuff about only being able to run 17" or bigger rims I have some all terran BFG's that are 275 75 16 and want to use them to save money can I do so without spacers and is it safe. I have a rock crawler that I want to tow and some trail riding can I do this and if I go 6" will those tires look too small with the lift ... Any pics would help ....
    bTW love this forum
  2. Feb 2, 2012 at 12:46 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  3. Feb 2, 2012 at 12:57 PM
    Sage
    SoCal
    07 TRD Sport
    I wanted to run 16" rims for now but not sure if it's able to be done without spacers ... Also what's an ideal rim size to run for trail riding ... Also do you guys think those tires will look to small with a 6" lift ... Lastly am I good towing about 4500 to 5000 pounds with blocks in the rear ... On a budget but will replace with a new leaf pack eventually ..
  4. Feb 2, 2012 at 1:21 PM
    Sage
    SoCal
    07 TRD Sport
    .......help.....
  5. Feb 2, 2012 at 1:24 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    do some searching around the forum, you'll find the info you want!
    16's will be fine, again it depends on the wheel. Most guys are running 16-17" wheels for trails
    tire size varies, from 32's up to 37's
    275's should look fine, maybe a little small but itll work.
  6. Feb 2, 2012 at 1:41 PM
    Sage
    SoCal
    07 TRD Sport
    bTW love this forum
  7. Feb 2, 2012 at 1:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    seriously, if you're going to ignore what I say, then search the forum. the info is there
  8. Feb 2, 2012 at 1:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    don't make duplicate threads.
  9. Feb 2, 2012 at 1:51 PM
    Manwithoutaplan
    ID
    that doesnt help the guy out.
  10. Feb 2, 2012 at 1:57 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Just buy a three inch lift op you'll be happy with that
  11. Feb 2, 2012 at 1:58 PM
    Sage
    SoCal
    07 TRD Sport
    Sorry konaborne I just thought I might not have posted in the right forum and wanted a straight answer ... Thanks for your help
  12. Feb 2, 2012 at 2:22 PM
    Sage
    SoCal
    07 TRD Sport
    I'm thinking go big or go home ... But what's everyone's thoughts on spindle lifts and can I add on to them later on ... I'd like to go bigger than 6" but don't want body lift and hate blocks but if I have to do them for now I will ... What about a spindle in front and a shackle ext in the rear .. Keep in mind this is my daily driver and I want to tow with it every once in a while...
  13. Feb 2, 2012 at 2:33 PM
    Manwithoutaplan
    ID
    if you want a off road preformance got with a 3 inch. this is coming from a guy that has 6 inch that wheels alot.
  14. Feb 2, 2012 at 2:41 PM
    Sage
    SoCal
    07 TRD Sport
    I love the look manwithoutaplan truck looks sick so you don't like your 6" ... This is my daily driver I have a 1977 cj 7 for the big stuff ... Do you think I can tow my rock crawler with my taco ?
  15. Feb 2, 2012 at 2:42 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    should be fine if gas mileage isn't a problem!:D
  16. Feb 2, 2012 at 2:44 PM
    Manwithoutaplan
    ID
    thank you. if you want to just show it off not to do much off roading go with the 6 inch. but if you want to do alot of romping around go with 3 inch preformance lift. YEa you should be able to tow your 1977 cj i guess i just depends on the weight of trailer .
  17. Feb 2, 2012 at 2:57 PM
    Sage
    SoCal
    07 TRD Sport
    That rig is only 3500 pounds and I'm guessing about 1000 pounds for the trailer ... Just a flat bed .. Manwithoutaplan have you had and problems with your lift ...
  18. Feb 2, 2012 at 3:07 PM
    Sage
    SoCal
    07 TRD Sport
    When I go 6" can I use those 16" tires without a spacer if I go 4.5 back spacing ... And is it safe don't want to ruin my taco ..
  19. Feb 2, 2012 at 3:49 PM
    Manwithoutaplan
    ID
    you should be fine then towing. No i have not had any problem with. I have had some injuries but those were self inflicted :/. You can try the 16 inch, but i think procomp/fabtech recommends 17 inch.
  20. Feb 2, 2012 at 3:50 PM
    Manwithoutaplan
    ID
    Dependin where you are i can help you put on the lift if you want. I did mine 6 inch lift and many others.
