6 quarts of oil? Prob? No biggie?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Aug 23, 2015.
  1. Aug 23, 2015 at 1:05 PM
    MudFlap
    MudFlap [OP] Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    Wasn't paying attention and accidentally poured 6 quarts of Mobile 1 5w30 into my V6.... yeah I know bone head move.... Don't really want to have to drain and refill.... So will 6 quarts kill me or what?
  2. Aug 23, 2015 at 1:07 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    Just get a graduated cylinder, or measuring cup and drain off what you over filled... It can be catastrophic.
  3. Aug 23, 2015 at 1:09 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    I thought it held 6. That's what I always put in when I change mine.
  4. Aug 23, 2015 at 1:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't know how sensitive the 2nd gens are, but I have always put 6 in my 3.4 liter 1st gens.
  5. Aug 23, 2015 at 1:11 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I'm usually closer to 5.5.
    Just loosen the filter and let the oil drain from there. I don't think it would take more than two or three times to get it to the right level.
  6. Aug 23, 2015 at 1:11 PM
    DrFunker
    DrFunker Well-Known Member
    Next oil change, Fumoto that mofo. :thumbsup:
    voz, Justinlhc, 4x4Only and 2 others like this.
  7. Aug 23, 2015 at 1:28 PM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I've rounded up to the next full quart on every Toyota I've ever had, never an issue, lots and lots of miles on them.
    Don't sweat the small stuff.
    PSU Taco85 likes this.
  8. Aug 23, 2015 at 1:34 PM
    Pigpen
    Dan
    Northwest Montana
    I'd check the dipstick before doing anything. It's supposed to be about 5.5. .5 high might not be a biggie, but in principle too much oil can be a really big deal. Maybe keep an eye on your PCV for signs of oil.
    Draining at the filter would be the easiest way, I like that. Just use some plastic tubing and a Solo cup. Voila!
    DukesTaco likes this.
  9. Aug 23, 2015 at 1:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm thinking 1/2 quart isn't a deal breaker either way low or high. Any more than that I would be concerned...
    Do the filter and call it good if you are worried about it...
  10. Aug 23, 2015 at 1:49 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Being anal maybe, but if the book say x.5 qts. then that's what I do and I have the luxury of setting aside whatever time is necessary when I work on my car.
    It's likely not the end of the world because any shop that does oil changes is either going to under fill 1/2 a qt. or overfill 1/2 a qt. None are going to take the time to measure 16 oz.
  11. Aug 23, 2015 at 1:53 PM
    Blkvoodoo
    Kevin
    Near Clayton NC
    This.
    5.5 will take level to top mark on stick, 1/2 quart more is ~1/4" higher on the stick. no issue. plenty of room for that, you'll slosh just as much driving the truck
    4x4Only likes this.
  12. Aug 23, 2015 at 5:17 PM
    js312
    Joe
    New England
    I use an old 20 oz soda bottle without tubing. Fits right under the drain spout perfectly and holds itself in place.
    Biscuits, DoorDing and Pigpen[QUOTED] like this.
  13. Aug 23, 2015 at 5:48 PM
    Lester Lugnut
    This works if the bottle is good and sturdy. I once tried using a Walmart water bottle(their cheapest 24 bottles per case) and that ended up being a mess. Reverted to the 5/16" tubing.
  14. Aug 23, 2015 at 5:52 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    No big.
  15. Aug 24, 2015 at 8:01 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I use a large 2 litre soft drink bottle. Cut off the bottom with a knife and leave the cap on. The bottle will sit under the filter housing upside down without having to attach strings or anything else. After catching oil just carefully remove bottle and add it to the container you used to catch oil from oil pan. Easy and you can wipe it out and reuse it next oil change. Old soda bottles can be used for funnels using this same method.
  16. Aug 24, 2015 at 8:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah if you had said you only put 5 quarts in thats perfectly fine (thats what i run and the dipstick shows JUST below the full mark) but too much oil even by half a quart can create excess case pressure and thats no bueno.
  17. Aug 25, 2015 at 8:38 PM
    mardoqueo galindo
    mardoqueo galindo Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    I use 6 liters all the time for 6 years now,no problem,4.0 preruner 2008 movil one
  18. Aug 25, 2015 at 8:44 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This is cool as heck! Reliable no leak long term?
  19. Aug 25, 2015 at 9:37 PM
    s brake
    s brake Well-Known Member
    2005 Double cab short bed TRD
    I've had them in five of my cars without any problems.
    Kyitty[QUOTED] likes this.
  20. Aug 25, 2015 at 9:56 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Fumoto FTW! Had them on all my trucks!
    DrFunker[QUOTED] and Kyitty like this.
