6 quarts?
Discussion in '4 Cylinder' started by The Shape, Aug 23, 2009.
  1. Aug 23, 2009 at 12:31 PM
    The Shape
    The Shape [OP] Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    The 2.7 in my '09 should hold 6 quarts of oil with a filter change correct? That's what I get from the owners manual anyway, I am just getting prepared for my first oil change at 5K.
  2. Aug 23, 2009 at 12:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Aug 23, 2009 at 12:53 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    6 quarts will end up showing a big overfill on your stick (if you can read it). After looking at every thread on the subject, both here and at TN, I determined that both the stick and the spec are wrong. My solution is to use 5.75 quarts with the larger V6 filter. This will still show a slight overfill on the stick but nothing ridiculous. To summarize the disparity; my dealer says 5 quarts with filter, the manual says 6.1 with filter, a supposedly official document from Toyota (TN thread) to their mechanic’s says 5.8 with filter, and if you go strictly by the stick it is 5.25 with filter.
  4. Aug 23, 2009 at 1:45 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I do 5.5 with the filter. Works out to be just about right.
  5. Aug 23, 2009 at 2:09 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    This.
    6 is dry capacity.
  6. Aug 23, 2009 at 2:18 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You maybe right, but if you are, that means this is the first of the 21 vehicles that I have owned where the owners manual shows the dry capacity for the oil and filter change. IMO, the dipstick is the problem. When I bought my truck I checked the oil and it was well above the fill line. When I did my first oil change, I put 6 quarts in the engine and the level was the same as the factory fill. Now, having said this, I've decided to err on the side of caution and put 5.5-5.75 quarts in. It is better to be slightly low on oil than to overfill the crankcase. Now when I check the oil it's on the fill line. JMO.
  7. Aug 23, 2009 at 3:52 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I put in about 5.5 quarts. After I put the oil in I let the truck run for a few minutes and check the dip stick to make sure I am good. IMO, go off the dip stick.
  8. Aug 23, 2009 at 4:52 PM
    CometKat
    Carson City NV
    Except the stick is almost impossible to read. If you scuff up the stick you can get one good reading after the truck has been sitting overnight.
    I came to a compromise of 5.75 by averaging the spec ( 6.1 ) and the stick ( 5.25 ) to get 5.675 and adding a little for a larger filter. This is also close to the 5.8 number metioned above which is probably correct.
  9. Aug 23, 2009 at 10:31 PM
    The Shape
    Forrest City, AR
    I know on my '07 I always had the dealer service it and looking at my receipts they all show I was charged for 5 quarts.:confused:
  10. Aug 24, 2009 at 5:26 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    uhh i put 6.1....my dipstick reads right in the middle.....
    i use synthetic tho and let it drain out for awhile...around 1/2 an hour to an hour tho...lol
  11. Aug 24, 2009 at 10:50 AM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    i put 5.5. ive been changing my oil since i got it in 05. i think i called toyota to verify. doesnt is also matter with viscosity?
  12. Aug 24, 2009 at 6:17 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    I do around 5.3 with the standard size Toyota filter (90915-YZZG1). As difficult as it is to read that dipstick, I think I am right on the full mark when I measure about 5 minutes after stopping engine.
  13. Aug 24, 2009 at 6:31 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    5.4382912 quarts
  14. Aug 24, 2009 at 6:34 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    :) I think you are of by .0000245 quarts.
  15. Aug 24, 2009 at 6:46 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Damn, I thought we were all off more than that:(, lol........:D
  16. Aug 24, 2009 at 8:20 PM
    CometKat
    Carson City NV
    Numbers so far
    6.1
    6
    5.8
    5.75
    5.675
    5.5
    5.438…
    5.3
    5
    I’m glad Toyota made it so easy for us
  17. Aug 24, 2009 at 10:23 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Maybe we can find the average?:rolleyes:
  18. Aug 25, 2009 at 2:16 AM
    dsailer
    dsailer Member
    Orlando, FL
    Average is 5.6
    So, statistically speaking,.... a nats ass over 5 should be fine.
  19. Aug 25, 2009 at 10:35 AM
    alextdunn
    alextdunn Active Member
    alex
    san Diego
    05, 4cly, base, Xtra cab, 5 lug lift
    ready lift 5 Lug lift, bed lights, 400 watt inverter, scan gauge II, AFE pro Dry s, second air filter removed
    I change my oil out when it is hot and let it drain till it cools down.
    Then i pour any oil that is left in my old Qt. let it drain and fill the filter part way.
    when all is done i use about 5.314 or a little more that puts me about 1/2 way up the dip stick then i top it off if needed.
    First time i did it by the specs it was way over filled.
    it is way simpler to add oil than take out 1/2 qt.
  20. Aug 25, 2009 at 5:29 PM
    SUPMO72
    SUPMO72 Well-Known Member
    Cleveland Ohio
    09 MGM Reg 4x4 5spd
    OEM Fog Lights, Tailgate Lock, Color matched OEM Grill, GT seat covers, Undercover bed cover, OEM back up camera
    5.5 should do it...
