6'' Rough Country a good lift?
Discussion in 'Suspension' started by Red_Taco33, Mar 23, 2015.
  1. Mar 23, 2015 at 8:31 AM
    Red_Taco33
    Red_Taco33 [OP] Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    Just bought a 6 inch suspension lift for my taco, is this a good lift for mudding and wheeling?
  2. Mar 23, 2015 at 8:32 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I usually ask questions BEFORE buying..
    hcm and imjustabill1970 like this.
  3. Mar 23, 2015 at 8:37 AM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    agreed. if wheeling was a priority i personally would of stuck with a 3" suspension lift over a 6" bracket lift.
    imjustabill1970 likes this.
  4. Mar 23, 2015 at 8:45 AM
    Red_Taco33
    Upstate New York
    Guy at the shop said it was good for it, thought i would ask you guys.
  5. Mar 23, 2015 at 8:46 AM
    Red_Taco33
    Upstate New York
    Why not? Too high of a lift?
  6. Mar 23, 2015 at 8:47 AM
    geekhouse23
    Barely any clearance with a drop bracket..
  7. Mar 23, 2015 at 8:48 AM
    geekhouse23
    Remember, he's trying to sell you something to make money..
  8. Mar 23, 2015 at 8:52 AM
    Red_Taco33
    Upstate New York
    Yeah you guys are right, thanks boys.
  9. Mar 23, 2015 at 8:53 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    For the love of drop brackets! Do not buy a rough country :eek: There has been too many members with issues already. Buy cheap, get cheap.
    A properly setup drop bracket can hang with a 3" just fine. Just depends on what kind of offroading you plan do. If you want to fly through a desert and play in the dunes then obliviously a 6+" lifted truck is not going to perform as well. If you plan on mud and slow crawling/trails then a good setup drop bracket can perform well. But, beware it will cost much, much more than any 3" lift unfortunately. Thus is why most will recommend a 3" and the ease of install.
    allrsdup likes this.
  10. Mar 23, 2015 at 8:54 AM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    I can't "off road" with my DB lift. Barely any "clearance" :rolleyes:
    Justinlhc and allrsdup like this.
  11. Mar 23, 2015 at 9:01 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Rape wasn't so bad, now was it?
  12. Mar 23, 2015 at 9:01 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Actually no? Your putting less stress on the cv angles, tie rod angles, and still having usable down travel and up travel. You dont necessarily "loose" clearance at the drop bracket. You just dont gain as much as a 3". Where most people forget also is you gain an incredible amount of frame, front and rear bumper clearance. Not trying to bash your opinion. There is just more to a properly setup drop bracket then most people know.
  13. Mar 23, 2015 at 9:03 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Lol ditto
  14. Mar 23, 2015 at 9:04 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    The funny things is that those 6" drop bracket lifts cost about as much as an Icon Stage III.
  15. Mar 23, 2015 at 9:04 AM
    Matic
    Tricky Dick
    Easley, SC
    Oh please. Do tell.
  16. Mar 23, 2015 at 9:05 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    You have less clearance with your 6" DB lift than someone with a 3" suspension lift.
  17. Mar 23, 2015 at 9:09 AM
    Matic
    Tricky Dick
    Easley, SC
    I'm waiting.
  18. Mar 23, 2015 at 9:19 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    I'm just not trying to mis inform the OP. There is pro's and con's to 3" and 6" lifts. I do understand I did not gain clearance at my cross member nor did I loose any clearance. I enjoy wheeling my truck much more than I did with my 3" lift personally.
  19. Mar 27, 2015 at 11:53 AM
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I'll chime in on this one.
    I do not understand how this less clearance paradigm is so pervasive around here. If we are going to talk about clearance, we need to be more specific as there are several areas:
    Under the front diff
    Under the rear diff / axle
    Frame clearance
    Drop bracket kits do not lift under the front diff but they do lift the frame, as such a 6" DB is going to have more frame clearance which has a huge effect on breakover angles, approach angle, and departure angle.
    The standard 3" non drop brackets kits will increase clearance under the front diff and frame clearance as well but 3" is less than 6" so they do not have as much frame clearance nor do they have as good of approach, breakover, or departure angle.
    The only thing that will increase clearance everywhere, including the rear axle / diff is an increase in tire size.
    WRT to use a DB or not, there are tradeoffs everywhere. The drawbacks to a standard 3" non DB kit are real. Loosing down travel is a big one. Down travel is huge when you're in the rocks maybe not so much for mudding or mall crawling. Look at trophy trucks and ultra 4's ; how much down travel do they have?
    What do you think happens to the roll center of a 3" lift? What about a 6" DB? Which is better?
    CV life WILL BE decreased with 3" kits.
    DB actually provide clearance for bigger tires wheras the 3" do not. (the top of the travel is still the same as factory unlike a DB)
    ETA: Clearance anywhere and everywhere is important but I am going to say that between the wheels (under the diffs) is not the most important. Solid axles are terrible for ground clearance under the diffs and yet almost every hardcore crawler has solid axles F/R. I've never heard of anyone swapping H1 suspension in.
    All that being said, for the record, I am going Old Man Emu on my rig.
    YOTA 209 and allrsdup like this.
  20. Mar 27, 2015 at 11:58 AM
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    :confused: You pointed out everything I try to explain to people. Yet your still going with OME
