6 sp manual downshifting effect mpg?
Discussion in 'Technical Chat' started by MMazz365, Apr 8, 2011.
  1. Apr 11, 2011 at 12:32 PM
    #41
    whoareyou133
    whoareyou133 Well-Known Member
    Claremont Los Angeles
    02 Prerunner TRD
    No pre runner trim, no mud flaps,no step ups,I do have the Deck plate though. Kings @ 0 and 5100's in rear. stock leafs. Total chaos UCA.
    AMEN to that!:p
  2. Apr 11, 2011 at 12:33 PM
    #42
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Who are you?
  3. Apr 11, 2011 at 6:53 PM
    #43
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    You wont save any real mpg in the time going to a light, the savings in mpg is in steady speeds and not using the brakes (coasting)....in SAFE methods.
    In the big scheme of things what WILL save you gas is getting lights that you can coast too , and end up going through at 10 or 20 mph.Every time you use the brakes you throw out mpg , this is why many hybrids incorperate regenerative braking ... to eliminate the biggest mpg waster around town....braking /stopping.
    Downshifting , injectors ,rpms and all that wont have a big result +/- on the mpg. Yes, they WILL effect it some for the 2-7 seconds while you coast, but wont really add up to ,say 2 mpg savings. Perhaps more like .1 or .2 realisticly. We cant really quantify 12 lights in 4 miles and G-force of stopping over distance x vs mpg, so why bother.
    Coast if you can to a light, downshift if you have time and are at low or moderate rpm, it wont cost you anything leading to the shop.
    I wont bother with higher rpm shifting discussion here,....different thread that has endless re-quote potential and just isnt worth it ,also has no real benefit at a stoplight to stop.
  4. Apr 11, 2011 at 6:56 PM
    #44
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    x2
  5. Apr 11, 2011 at 7:02 PM
    #45
    tacomarich
    tacomarich luvsoffroading
    rich
    arizona
    trd 4x4 offroad
    for me, i seem to average at best 16mpg or just under. doesnt really matter if i downshift or not. if it does, only about a couple mpgs or so. i think 04-08 tacomas (manuals) only get around 16-17mpg, vs the newer ones? those are around 18-22 i think.
  6. Apr 11, 2011 at 7:30 PM
    #46
    Tacoyota
    08 4wd
    I like coasting in the left lane to a red light.... when I see a BUS stopped on the other side . Always some hotshot-tard trying to pass and I just trolled him into the wait line behind the bus lol. I get 1-2 a week doin that.
  7. Apr 11, 2011 at 8:09 PM
    #47
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Gotta be related to BartStar!
  8. Apr 12, 2011 at 2:35 AM
    #48
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    You won't save gas compared to neutral, but you will have more control going downhill via engine braking, especially while towing. I like using my brakes as little as possible.
    We are on the same page.
  9. Apr 12, 2011 at 3:01 AM
    #49
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    I don't think you're downshifting is affecting your MPG's. It's usually start up and shifting that affects that. Keep the RPM's lower then 2000 when you shift and as you said lay off the lead foot a bit lol! I was gonna say you might wanna check some things like the air filter and plugs and such but you've got a 2010 so there shouldn't be issues with those things just yet.
    You fill up every 3 days? How much and what kinda driving do you do? I do mostly city driving, about 15-25 miles a day (give or take a few) and I fill up once every 2 weeks. Getting around 275-300 miles per tank.
    (I downshift to slow down too btw) It does slow you down lol, thinkingman is cracking me up. Not too much thinking going on!
  10. Apr 12, 2011 at 6:26 AM
    #50
    macgyver
    Brad
    Canton, GA
    Must be nice to fill up once every two weeks :D
    I fill up twice a week. :( Getting about the same mileage per tank as you stated.
  11. Apr 14, 2011 at 1:31 PM
    #51
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Twice a week! Damn. That's like $450 - $500 a month in gas alone. You'd probably be better off buying an old Corolla or Geo Metro beater for the commute, and saving the truck for weekends.
  12. Apr 14, 2011 at 3:10 PM
    #52
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Don't want to go into all of that thread, but my point of view is: BRAKES ARE MADE FOR SLOWING YOU DOWN./ Brake pads cost nothing, changing a clutch costs a lot, use your brakes/ Your clutch does not use itself when driving, but uses itself everytime your start and shift/downshift.
    In the end, its the traction you got between the tires and road that will determine the final braking distance, so engine braking or not, your brake have far enough power to make the wheel lock.
    So thinkinman is right, just use your heads and stop wasting your clutches by downshifting for no gains at all (since brakes are by far powerfull enough to lock the wheel anyway.)
  13. Apr 14, 2011 at 4:32 PM
    #53
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    X3
    This thread makes me LOL!
  14. Apr 14, 2011 at 7:28 PM
    #54
    KodiakToyTRD
    CO
    You could always shift without the clutch. Match your engine and drivetrain rpm and slip it into gear. The sweet spot is somewhere between 2000 and 2500 rpm. This works for up and down shifting.
  15. Apr 14, 2011 at 11:18 PM
    #55
    whoareyou133
    02 Prerunner TRD
    Well im andrew who are you? :)
  16. Apr 15, 2011 at 6:36 AM
    #56
    macgyver
    Brad
    Canton, GA
    Yeah tell me about it...23 mile one way commute, then I drive a lot on the weekends. I keep kicking myself for selling my accord after I bought the truck. DOH! ...but at the time I needed the cash to resolve a money situation with my ex g/f. Had to pay her for the furniture in my house that she paid for.
    Well my fingers are crossed for a company car sometime within the next year. :D Then I will go to filling up once every two weeks.
  17. Apr 15, 2011 at 6:37 AM
    #57
    macgyver
    Brad
    Canton, GA
    B-rad from malibu. j/k
  18. Apr 15, 2011 at 7:13 AM
    #58
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I have almost 110k on my clutch and original brake pads so far. Clutch still works like new, and inspected my pads just a few days ago and expect to get another 25 - 30k out of them. My commute to work is over 100 miles one way.
