6 Speed auto tran.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gray Tacoma, Mar 20, 2013.
  1. Mar 20, 2013 at 5:22 PM
    Gray Tacoma
    Gray Tacoma [OP] Well-Known Member
    northern West va
    11 Access cab-TRD Sport Package Mag.Gray
    Wouldnt a 6 speed automatic tran help gain a couple mpg?
  2. Mar 20, 2013 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It could.
  3. Mar 20, 2013 at 5:29 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Depends.
  4. Mar 20, 2013 at 5:38 PM
    BradyT88
    BradyT88 Well-Known Member
    Damn! I want the A760F from a 4.7L Tundra. 1st 5 gears are the same as our 5 spd and then you have a 2nd overdrive. Would help me out with RPM's and my 4.88 diff gears.
    To answer this, I would say probably not. When I went to 33" tires my rpm's were so low at 75mph (about 1900-2000rpm) that the tranny would stay in 4th gear rather than 5th. I don't think our motors make much power at that range compared to the factory rpm of about 2300 at 75mph. If you were competely stock and shifted into the 6th gear from the A760F you would drop down to 1800rpm and might not have enough power to break the wind and it would shift back into 5th gear making 6th pretty much pointless...
