6-Speed Driving Tips...post them here
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Oct 25, 2010.
  1. Oct 25, 2010 at 1:50 PM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    After reading all the hoop-la about 6-speeds and how some find them hard to shift, and hate the engine RPM hanging, and the gas mileage, I figured perhaps I start a tip thread for efficient 6-speed driving.
    After much reading here and other sites, I learned a few things to add to my driving habits.
    One was to shift to 6th to coast versus neutral. I tried that today doing 40kph (25mph) and the engine reved at 1k versus 12-1300 in neutral. I read that the coasting in gear will shut off the fuel injectors and keep the engine running versus neutral that needs gas to keep the engine running.
    Anyway, if this is a dumb idea or was done before, oh well...I tried! :D
  2. Oct 25, 2010 at 3:29 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Doesn't seem to do that on mine. I get the slightly lower readings on my gauge coasting in 6th vs. coasting in neutral. Neutral has always resulted higher mpg readings for me than coasting in gear, especially at freeway speeds. On one particular stretch of road for me on the way to work, if I coast in 6th, my gauge will read about 75mpg. As soon as I switch to neutral, it'll read 115 mpg. The main disadvantage of coasting in 6th at freeway speeds is that the engine will slow the vehicle down so you won't coast as far.
    Most of those who reported the higher mpg while coasting in gear were automatics and they used scangauges. I don't know of anyone who has a manual who has confirmed the same thing with a scangauge. My gauge is an Aeroforce gauge.
  3. Oct 25, 2010 at 5:01 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    For me personally.
    I find the smoothest up shifts for city driving is around 2500-2700 RPM, downshifts I do at 1900 and use the gears to help slow me down, thus saving my brake pads. When cruising, I up shift a gear (40 Kph I'm in 3rd, 60 Kph I'm in 4th) to cruise at about 1800-2000 RPM. Less RPM means less fuel being used.
  4. Oct 25, 2010 at 5:06 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    most of the time if hard acceleration isnt needed i'm in 6th gear by the time i'm at 30mph. i rarely downshift to slow down as brake pads are cheaper to replace than transmissions.
  5. Oct 25, 2010 at 5:06 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    You want mpgs on the 6 speed?, try not to go over 2K rpms on any gear. Best mileage I got was about 21.8 mpgs on the freeways.
  6. Oct 30, 2010 at 6:20 AM
    Priddle
    Although I know this truck has more power than my old 03 4-banger, I am not realizing that while I drive. From reading this forum the past few days about keeping RPMs as low as possible, I am realizing that this truck is fine at 1000-1200 rpm while cruising. I can do 50+kph in 6th and not have any struggling. My 4-banger would struggle with any bit of throttle. This truck does not. So I am making an effort to get it to the highest gear possible and see how my next tank does.
  7. Oct 30, 2010 at 9:15 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    x2
    Never did understand the whole downshifting thing - brakes and brake pads are way cheaper than a transmission
  8. Oct 30, 2010 at 9:27 AM
    Evil Monkey
    Robert
    Escondido, CA
    It isn't going to hurt anything. I've had manuals for many years. It's never been a problem. If you think about it, you're engine braking every time you take your foot off the gas while you're in gear.
  9. Oct 30, 2010 at 9:28 AM
    Azjohn
    Azjohn Well-Known Member
    arizona/SLO Ca/SF Ca.
    2010 trd sport
    debadged
    Down shifting with proper rev matching does not harm trans or clutch just saves brakes. A short shift kit is a must.
  10. Oct 30, 2010 at 10:25 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    if you downshift right you arnt going to do harm to your tranny so not wearing down your brake pads is cheaper than wearing them down basic economics and when shifting to second i find that a little more feathering is needed to make that gear engage as smooth as say 2nd to 3rd or 3rd to 4h
  11. Oct 30, 2010 at 1:25 PM
    superminsoo
    superminsoo Well-Known Member
    How are you in 6th gear at 30? Isn't the lowest recommended speed for 6 at 41 according to the manual?
  12. Oct 30, 2010 at 1:54 PM
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    Some things I've noticed:
    -shift between 25-3000 for smoothes changes
    -Only push the clutch in a few inches when up shifting, just enough to disengauge the clutch.
    -I always downshift when slowing down. Engine braking FTW.
    Don't really have any other tips, what speed do people find is the best for cruising in 6th? I find it hard to narrow down a speed as I always seem to be driving up/down hills on the 400 highway.
  13. Oct 30, 2010 at 2:02 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    In most places, Pennsylvania for one, it is illegal to coast in neutral on the road, tough to prove for certain, but illegal nonetheless. It is also a bit unsafe as you would want the ability to accelerate in the case of some emergencies and may not have time to put it back in gear in such cases. I know what you are going to say it only takes a split second to put it back in gear, but in a true emergency a split second is huge.
  14. Oct 30, 2010 at 2:22 PM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    not over 2000 rpm?? in 6th u would only be doing 90kph , lol
  15. Oct 30, 2010 at 2:45 PM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Dayton
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    x2. Best fuel economy and smoothest shifts at around 2000 rpms
  16. Nov 1, 2010 at 10:54 PM
    808matt
    hawaii
    19 Ranger
    i cant read so i wouldnt know
  17. Nov 2, 2010 at 1:32 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    yea.. 6 gear is not coasting. "coast" in the best gear for the speed... always, always, always. Did I mention always? ONLY time I've coasted is when I'm out of gas on a mountain side and when changing shoes. Neither are safe.
    If you can't feel it you can't fake it. There's a formula that you could follow sure, but too complex to relate in text. Just pay attention not only to how much foot you're using but how long and the feel of the pull of the engine. Stay out of the gas more so than light on it. Start from there and you really have to learn it. its a skill not a checklist.
    Get a CDL. Those trucks are a lot less forgiving as would, likely, be your instructor.
  18. Nov 2, 2010 at 1:33 AM
    island808
    Jedediah
    hawaii
    yea... the speed limit in canada where/when i was last there...
