6 Speed for 1999 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco3177375Pilot, Dec 4, 2013.
  1. Dec 4, 2013 at 2:17 AM
    Taco3177375Pilot
    Taco3177375Pilot [OP] New Member
    Ken
    North California
    SC V6 Tacoma
    I'm new to the forum as of this morning. Does anyone know whether a new 6 speed manual transmission (for the 4wd V6) will fit into a 1999 Tacoma 3.4L V6 4wd? My 5 speed is popping out of 1st gear occasionally and mostly when warm. Dealer says change the transmission, but do I really need to change it? Is the dealer looking for more income? Is there anything I can do to stop the popping out of 1st? Admittedly, the pickup is now approaching 297,000 miles. As with other owners, shifting is not the most pleasant if I get in a hurry, but that apparently is normal. I just don't see Japanese manual transmissions as all that good; that goes for their clutches as well.
  2. Dec 4, 2013 at 2:34 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    Whoa!!
    didn't even finish reading your post, dude... don't yank that transmission yet
    popping out of gear is a VERY common problem with these, especially with near 300k, cause the seat and socket get chewed up
    http://www.instructables.com/id/Toyota-Tacoma-manual-transmission-pop-out-of-gear/
    Install these:
    http://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-shift-lever-ball-seats
    http://www.marlincrawler.com/transmission/shifter-parts/heavy-duty-shift-lever-socket
    If That doesn't solve the problem immediately, you won't be out that much $
    heck, you could probably resell them to someone on here inside of a day
  3. Dec 4, 2013 at 5:31 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I would try a shift seat and socket like above, if that doesnt fix it, i would bet the 1-2 shift fork is worn and not capable of fully engauge the gear. If that is the case, you can fix it, but you need a press. You can google R150 shift fork and see what I am talking about. If you google Toyota tacoma 6 speed, you will also see that it has had a lot of issues... The R150 is a SOLID transmission, but like anything else its all about how it was taken care of.
    Its funny you would say something is not all that great but has nearly 300,000 miles on it.....
  4. Dec 4, 2013 at 9:29 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Like mentioned before, don't yank the trans until you check out those links.... but as an FYI, the 5 speed 1st gen transmissions are a reliable unit and are better than most american manual trans out there. The 6 speed, on the other hand, tends to be a little more delicate, if you ask me.
    *side note* As for clutches, exedy is one the best brands out there and they're Japanese. Check out their twin and triple disk clutches... they can handle over 1500 ft=lbs of torque on a daily driver.
  5. Dec 4, 2013 at 11:13 AM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
    I've been meaning to do this for awhile. thanks for the links!!!!!
  6. Dec 4, 2013 at 11:44 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    IMO 300k is pretty damn good.
    The Toyota E153 (MR2 Turbo) transmission will also hold 800rwhp unopened...I'm kinda curious now what you consider a "good" transmission.
