6 speed gears an fuel economy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsmooth87, Sep 11, 2011.
  1. Sep 11, 2011 at 9:24 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    im curious if skipping gears on the 6 speed(1,3,6 while shifting at 2k) uses less gas compared to using all 6 gears so long as your shifting at 2k as well?
    hope that makes sense.
  2. Sep 11, 2011 at 9:32 PM
    HIYota
    HIYota Well-Known Member
    Angel
    O'Fallon, IL originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    I honestly don't see how that would help. Wouldn't that bog your engine down when the RPM drops from shifting.
  3. Sep 11, 2011 at 9:47 PM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    It won't do you any good. The engine is going to lug when you shift and skip gears, rendering your mileage the same. Just drive like there is an egg on your throttle and shift conservatively.
  4. Sep 11, 2011 at 10:00 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    for best fuel mileage according to toyota, shifting at 2500K is ideal. So skipping gears at 2k, im going to go with your going to get shittier mileage.
  5. Sep 12, 2011 at 12:26 AM
    d5800877351
    d5800877351 New Member
    Portland, OR
    2010 Impulse Red TRD O/R AC
    If you think about it, skipping a gear is effectively making your tranny a gear short and defeats the purpose of having all 6 gears.
    However, I often skip 5th gear since 5th and 6th are so close. Usually stay on 5 on highway, 6 for freeway.
    yada yada, do what you like!
  6. Sep 12, 2011 at 7:01 AM
    Hayes
    Brandon
    Denver, CO
    The only way to get a definitive answer is to do it... Let us know what the results are.
