6-speed guys: at 35mph, what gear are you in?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Iowa10, Jun 30, 2016.
  1. Jul 1, 2016 at 5:33 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    ^ I go from 3rd to 5th a lot. I find shifting from 3rd to 4th barely changes the RPM at all. My uncle is a truck driver with an 18 speed freightliner and he always says "just use what you need" for gears.
  2. Jul 1, 2016 at 5:50 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    To the guys that run 35mph in 3 or 4 gear, is this your first manual? Just curious
  3. Jul 1, 2016 at 6:29 AM
    Pigpen
    Dan
    Northwest Montana
    I'm 41 and have been driving manual transmissions my whole life. I learned to back up a trailer with a MT helping the old man get firewood when I was 12 or 13. I've only owned 1 auto in my life - 1985 Buick Delta 88 4 door. Had it for about 2 years as a kid.
    So..no.
    I am on load E 33s on stock gears though, and live in the mountains. Also, my truck weighs over 5K pounds for DD.
  4. Jul 1, 2016 at 6:46 AM
    Duck_Hunter
    Duck_Hunter Well-Known Member
    Tejas
    2014 Tacoma TRD Off Road Manual
    ATC shell
    I curious why you're curious. This may change the way I drive. I've had seven vehicles in my life, all MT. I would be in fourth gear in this scenario.
  5. Jul 1, 2016 at 6:47 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    54 years driving a standard gear selection is done by the driver has nothing to do with the truck other than it will teach you when it needs shifting.
    The truck is capable of doing 30 or more in first and on the flat maybe be fine in 6th eventually you'll figure out what works best for you.
  6. Jul 1, 2016 at 6:52 AM
    Pigpen
    Dan
    Northwest Montana
    In general, I try to keep my RPMs close to 2K. For most of my driving , at or a hair above 2K yeilds the best MPGs. I get 18 MPG tanks all summer long, with the exception of long drives where I'm traveling through the mountains in excess of 70 MPH, then I get about 16.5.
    Mariotaco and Duck_Hunter like this.
  7. Jul 1, 2016 at 7:04 AM
    Duck_Hunter
    Tejas
    ATC shell
    I'm the same way. Always try to keep it around 2,000. I've found that it's a nice balance between MPG and not having the engine struggling.
    TheMuffinMan and Pigpen[QUOTED] like this.
  8. Jul 1, 2016 at 7:14 AM
    zimmmtaco
    zimmmtaco Better than it was before it got like it is
    Northwestern PA
    15 DCSB Blue Ribbon Met 4x4 OR, 6MT
    TRD Pro susp kit 265/75R16 BFG K02's Husky Floormats Vent visors Hella 500 on custom mount
    Usually 5th for me, unless in traffic..... Have about 3 miles of 35mph roads on my commute that are regularly patrolled, and 5th keeps me between 35-40, even on the downhill grades.
    Like 58 Siesta, I turn tanks of 18-18.5mpg regularly throughout the summer running a DC with E load 31" BFGs
  9. Jul 1, 2016 at 7:23 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    4th or 5th
  10. Jul 1, 2016 at 7:31 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    3rd normally sometimes 4th here. Under normal circumstances I stay between 2-3k RPMs. Why make the engine do work in an RPM range that it puts out shit for power? Gas mileage has more to do with how far you press the gas pedal than RPMs anyway. Plus being in 5th or 6th at 35mph would make me feel like a sitting duck... sure you can just shift but I'd rather have the engine "cocked" at all times... it's one of the beautiful things that a manual allows you to do that you basically can't with an automatic.
    shakerhood, samiam and Duck_Hunter like this.
  11. Jul 1, 2016 at 9:02 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    1500 rpm if city and flat-whatever gear it takes. 6th by 45mph. Highway 6th gear is 2450 rpm and 67 mph, again mostly flat. Fuelly shows about 19 city and 21 highway with summer gas over the last 2 years.
  12. Jul 1, 2016 at 9:05 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If it's a 35 zone, I'm typically driving 40-43 mph. If I can maintain that speed, I'll cruise in 5th gear.
  13. Jul 1, 2016 at 9:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    1st and just past 3k. :devil:
    PSU Taco85[QUOTED] and scottalot like this.
  14. Jul 1, 2016 at 10:38 AM
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    Never in my life have I gotten 18 MPG I came close once lol The worst I've done is 14.5 mpgs but I was driving between 80-90mph going up on elevation
  15. Jul 1, 2016 at 10:46 AM
    #35
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Whatever feels right, usually 4th or 5th. 17 to 18 mpg is pretty easy in this truck, when I drive it nice I break 19.
  16. Jul 1, 2016 at 11:43 AM
    #36
    concentric_killa
    concentric_killa Well-Known Member
    2011 4x4 DBL Cab Taco
    +3.5 TC Long Travel DMZ Spring Under Nitro 4:56 Gears Custom Snorkel List Goes On..
    I will probably be in 3rd or 4th but I have 4:56 gears..
    Green Jeans likes this.
  17. Jul 2, 2016 at 11:52 PM
    #37
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    In a 35 zone I just drive five over in 4th gear at 2,000 RPM.
  18. Jul 3, 2016 at 6:25 AM
    #38
    BWIG
    BWIG Tarheel.
    2008 TRD OR AC 4X4 V6 Manual.
    This.
    Driven manuals all my life. I try to keep it at 2,000 RPM most of the time. No desire to lug the engine.
  19. Jul 3, 2016 at 6:32 AM
    #39
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    4th or 5th. 6th sometimes depending on terrain. Truck seems happy at around 1500 revs. It'll accelerate from 35 in 5th or 6th if I'm not in a hurry. Which I never am. Like previously mentioned, use the gear you need. I jump all over the place.
  20. Jul 3, 2016 at 7:44 AM
    #40
    gilpinrobert
    gilpinrobert Well-Known Member
    Rob
    California
    2015 TRD Pro
    Aries pro series grill guard, Rigid Off Road LED lights, Snugtop Rebel Shell, Go Rhino step bars, Wheelers AAL Progressive 3 pack, Toytec 3/4 inch front spacer, Kicker 600 watt amp and new full range speakers, seat covers, rear diff breather mod, anytime fog light mod.
    If I am cruising at a consistent 35mph, then I will shift to 4th. But if I am in California traffic and I am slowing down and speeding up from 35mph down to 15 or 20 mph then I stay in 3rd.
