6 speed issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cudason, Mar 1, 2010.
  1. Mar 1, 2010 at 3:00 PM
    cudason
    cudason [OP] Well-Known Member
    Vancouver
    TURD
    Eagle Alloy 050 series wheels. TRD fj shift knob Bilstein 5100 set @1.75 TRD CAI TRD seatcovers 2009 Taillights Xenon HID kit
    bought a 2005 trd sport 6 speed. throwout bearing/bell housing/shift rod issues. just curious as to how many of us suckers bought the faulty 6 speed tranny thinking they were taking the safe route buying the manual. warranty will not cover it. i'm sitting @54,000 miles. apparently it should be covered AS IT IS THE BELL HOUSING AND SHIFT ROD THAT ARE CAUSING THE T/O BEARING TO CRACK!!! i'm really unhappy with toyota over this and would like to contact the media and get this out there. anybody interested in aiding me and a few others in this? for those who currently own a 6 speed, but haven't yet had this occur, i'd keep a close eye on it, and cross your fingers it doesn't rear its ugly head. the rpair bills will be huge, and its sounds as though toyota doesn't have a fix yet. some owners have had this t/o bearing replaced 4 times, and have eventually had their trannys replaced!. i myself expected better build quality from toyota, and a little more support from their service. if i wanted a cheapo, shitty truck, with issues, i wouls have bought a ford. over and out
  2. Mar 1, 2010 at 3:07 PM
    bkthompson6
    bkthompson6 Well-Known Member
    Brandon
    Oregon
    Over and Out doesn't make sense. Over means you are done transmitting and awaiting a response, Out means you are done transmitting and are not waiting for a response. You can't put them together like in the movies. They contradict themselves. I'm just messing with ya, I too have the 6-speed tranny and (knock on wood) have not had any issues with it yet.
  3. Mar 1, 2010 at 3:12 PM
    cudason
    Vancouver
    TURD
    lol...out
  4. Mar 1, 2010 at 3:12 PM
    onejsullivan
    onejsullivan Member
    Cape Cod
    08 Rugged Trail Prerunner
    campershell, rear spring tsb
    I had a 08 6sp and the throwout bearing was replaced. it made a whining noise when sitting, or when shifting (it changed) luckily though it was under warrantee because it was under 36k miles. anyway long story short,,,, i always play nice with the service writers/mechanics because they always seem to hook me up.
  5. Mar 1, 2010 at 3:24 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    so you bought a truck w/ "throwout bearing/bell housing/shift rod issues" shouldnt that be a dumb part on your end?
  6. Mar 1, 2010 at 3:30 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i've read about this on this forum but haven't had any issues with my 5 speed yet...is this only for 6 speeds?...if mine does this i will get it fixed then trade it in for a nissan frontier...why keep it if it's gonna happen again and again?...this just seems to be an odd problem...i mean how long has toyota been making manual trannys?...they should know how to do it by now...lol...probably some lame company that made the parts for them screwed something up
  7. Mar 1, 2010 at 3:47 PM
    cudason
    Vancouver
    TURD
    when i bought my truck it wasn't yet an issue 808matt. i don't really see how thats my fault. its a toyota 6 speed issue. anyway i see you have the 6 speed. better watch what you say big boy! squeek, squeek... is that your throw out bearing?lol!
  8. Mar 1, 2010 at 4:05 PM
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    i did research before buying my 2010 Tacoma, went against getting the Xrunner because of this KNOWN issue. Its all over the FJ Forums too. its ONLY the 6 speeds and there is suppost to be a TSB and a fix for it, last month....to no avail. As far as your original post, it sounded like, or i should say read like you bought it with the problem and hoped to fix it cheap....its just how it read, i thought the same thing, that you bought a bad trans truck to fix. Depending on when you got it, there was a ton of issues out there and its a known defect. some get lucky adn dont have the problem , but it was a major factor NOT to buy the X runner (or a 4x4 6 spd, automatics are for soccer moms and minivans :) )
  9. Mar 1, 2010 at 4:06 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    No problems with mine yet, I'm about 46K miles so far.
    What were the symptoms that you had your throw-out bearing go bad?
  10. Mar 1, 2010 at 5:57 PM
    808matt
    hawaii
    19 Ranger
    exactly what he said. from reading your post it seemed like you bought it w/ the known problem. hence me saying it was dumb on your part then.
  11. Mar 1, 2010 at 6:05 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    It sounds like a chirping/squealing. It goes away if you depress the clutch. Nothing more than annoyance really.
  12. Mar 1, 2010 at 6:22 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    you really want to contact the media because your truck is having problems? ROFL. this is hilarious.
  13. Mar 2, 2010 at 9:59 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
  14. Mar 2, 2010 at 10:17 AM
    Manwithoutaplan
    ID
    cudason when did you start noticing a problem with your 6 speed was it just at 54k or was there any big signs before??:confused:
  15. Mar 2, 2010 at 10:27 AM
    cudason
    Vancouver
    TURD
    no signs before. it started about 5,000 miles ago. I didn't notice it during the winter because my windows were closed. once i noticed it, it became louder and more obvious. did a search on it and voila! big time concern for many 6 speed owners. i opted for the 6 speed, because i figured it was the safe bet as far as toyota trannys went. no dice. for the record i don't do any super serious 4x4ing and really maintain my truck well. the worst part is that it doesn't seem like toyota has got their collective shit together and found the fix for this yet. so, i guess its just wait and see. for those that think i'm a whiner, well when i spend $30,000 plus on a new truck, i don't expect unsolvable issues at 50,000 miles. this truck is barely broken in. its pretty embarrasing when a flashy new tacoma sounds like a 10 yaer old sunfire. just wanna get the word out there and see if we can't get toyota to find a proper fix, and admit these trannys are crap
  16. Mar 2, 2010 at 3:35 PM
    kilgoja
    Alabama
    :mudding:
    cool another recall/problem/tsb avoided by me buying the 4 banger instead of the v6 :)
  17. Mar 7, 2010 at 4:12 PM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    Yes, he should. This is a problem waiting to happen on every single 6 speed FJ and 05+ Tacoma out there. There is an aluminum pilot shaft that is not outlasting the pressure plate, clutch disk and release bearing, the primary wear and tear items. On most other truck transmissions, including the 05+ 4cyl 5 speed, the pilot shaft is made of steel and is a $75 replaceable item, but not the case on these 6 speeds. The aluminum pilot shaft on these 6 speeds is press fit into the bell housing and requires a new bell housing, which is even more labor plus a $400+ bell housing and another $300+ in wear and tear items at least. It's a ton of labor.
    So if OP has any luck drawing the attention of the media that every single FJ and 05+ 6 speed is likely to suffer premature failure of clutch assembly due to a design and materials flaw on that pilot shaft, resulting in a $2000+ service bill, I applaud him.
    I wonder how many owners start to hear that chirp and then trade their vehicle in on a "good day" when there is no noise, just to get rid of it... Seems there are a lot of preowned's out there waiting to "shaft" their new owners.
  18. Mar 7, 2010 at 4:18 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    i too got a 6spd. no probs yet. i drive fast n shift hard. i have had an issue with one person where i've had to replace the bearing twice -not warranty because he said he wore it out offroading and riding the clutch. but he paid to replace it cuz it was making noise/going out.
  19. Mar 7, 2010 at 4:25 PM
    SnoBoarder
    Lost
    Just out of curiosity, how many miles on your 08? This is usually a 50k- 80k event, sometimes less, but usually right around that range.
  20. Mar 7, 2010 at 4:27 PM
    tacobo670
    Ray
    Las Vegas
    didnt know about "50-80k event" but i got alot but i killed my odo so i would say about 25k actual
