6 speed manual is GREAT!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by klown, Feb 26, 2008.
  1. Feb 27, 2008 at 5:51 AM
    klown
    klown [OP] Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Yeah, I guess the A/T's are faster...if you have a chick driving the manual (of course the chick is too busy putting makeup on to shift right anyways). If you know how to shift quick and drive a manual of course the manual will be faster. You can keep it in the power band longer. A/T's want to shift based on fuel economy not performance. A manual can do either one, based on what the driver wants.
  2. Feb 27, 2008 at 6:15 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Car and driver is known for trashing tranny's to get the best 0-60. They pulled a 7.4 (open diff) with a stick and 7.1 (LSD diff) with auto. The reason is probably because the stick with its lower gearing (look at 1st alone) requires more shifts to get to 60. Rear diffs and wheel spin off the line may contribute as well.
  3. Feb 27, 2008 at 6:19 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    No, if you look at the 0-60 times they really are faster
    They either fixed it for the 07's or i lucked out. i have no complaints about my cruise control. it never accelerates violently and on hills only overshoots by about 3mph. very little gear searching also
  4. Feb 27, 2008 at 7:02 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I'd like to see them run a locked 6spd. :D LSD vs open gives a slight advantage to the auto. And considering the difference is only 3/10ths of a second it could be slight wheel spin or a few other things.
  5. Feb 27, 2008 at 7:11 AM
    klown
    Lynchburg, VA
    Yeah, LSD will help with initial traction, certainly the results are not conclusive. I've got a TRD sport with a LSD, this thing takes off like a bat out of hell, very little wheel spin, it's just fun. I go through gas too damn quickly though LOL.
  6. Mar 5, 2013 at 11:10 AM
    Willinz
    Willinz New Member
    I am looking to buy a 06 Tacoma with the 6speed but it has 155000 on original clutch what do yal think should I buy never owned a 6speed. Really just lookin for some advice.
  7. Mar 5, 2013 at 11:46 AM
    forcefedsupra
    forcefedsupra Member
    Dustin
    Broken Arrow, OK
    2009 4x4 V6 manual
    I've had my 6spd just over a week now and I'm very happy with it, but it is dramatically improved with the URD short shifter. I'm so glad I got it even though it's difficult to put it in reverse. I also don't like how the engine revs higher when I shift even with my foot off the pedal. I'm used to a Supra 5-spd and it doesn't do that. I'm wondering if a lightened flywheel would help with that.
  8. Mar 5, 2013 at 1:08 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I have a 12 6sp. I love it. No complaints. it does have a pretty good learning curve. The 6th sp does need to be geared higher. 1st gear is pretty low but its fun to rev the truck up in 1st.
    I try to keep it under 2000rpm to get god MPG. But it really does shift better around 3000.
  9. Mar 5, 2013 at 1:20 PM
    MetallicTaco
    MetallicTaco Taco Driver Since '07
    San Diego
    2013 DC SB
    TRD Supercharger Alpine INE-Z928HD, TT Image Dynamics Components, TT 10" sub, JL Audio 4/600, Alpine Front and Rear facing camera lic plates
    I also have the TRD quick shift kit installed. Drove the truck a few days before the dealer put it in as it was not an original option on the truck @ time of purchase ($414 option, dealer cost installed). Difference was very noticeable once installed. The throws are shorter and over all the shifter is more notchy. The kit really firms it up and takes out a lot of the play between gates. Reverse takes a second (and a little force) to grab, but overall it is an improvement in sportyness (imo).
    The drive by wire system is the culprit in holding the revvs after the clutch is pushed in. I guess its ok, in some situations its good, some not so good.
  10. Mar 5, 2013 at 1:25 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    original clutch? will probably need replacing soon.
  11. Mar 5, 2013 at 2:49 PM
    Willinz
    Willinz New Member
    You think so I'd hate to buy it and have to fix something like that
  12. Mar 5, 2013 at 5:05 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    ? 127 MPH in 5th isn't fast enough with one more gear to go? Don't look at me that's from the Toyota book.
  13. Mar 5, 2013 at 5:13 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I'm not sure why people think it's so low it is the same as the 5 spd. stick. It's a trans for people that tow and learned how to drive with clutch you can actually use 6th gear towing no need to lock out O/D.
  14. Mar 5, 2013 at 5:18 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    negotiate to have it replaced.
  15. Mar 5, 2013 at 5:19 PM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I tore up the ham string in my left leg got pretty good using a cane to operate the clutch. Wife's car is a stick too.
  16. Mar 5, 2013 at 6:36 PM
    #36
    FuzzyRuttin
    FuzzyRuttin If it ain't broke, fix it
    Syracuse NY
    05 TRD Sport 4x4 6-ON-THE-FLOOR
    I went from a '97 3.4L taco to an '05 4.0L. The 97 required quite a bit more dexterity to launch than the 05, which I can't entirely attribute to an extra 600cc. The 97 also liked to buck on "redline" shifts if you didn't let the engine rev down a bit longer, no matter how much the clutch was feathered, whereas keeping up the revs and easing out the clutch actually works on the 05 if you want full-on acceleration through the gears. The 05 is definitely more forgiving and a lot smoother, I love it. I don't know how to drive automatics.
  17. Mar 5, 2013 at 7:12 PM
    #37
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    I would love a 6spd...but I want an UN synchronized tranny. That way I could float the gears w/o using the clutch. I drive an 18 wheeler with a 10 speed, and I rarely use the clutch in it.
  18. Mar 5, 2013 at 7:26 PM
    #38
    GuyWithCamera
    GuyWithCamera Well-Known Member
    Alan
    Tracy,CA
    Nissan 370Z
    I like my 6 speed... I was under the impression for a while that we had very crappy clutches since a friend at the time has a 08 X-Runner is on his 3rd clutch before 60K miles.
    40K miles later on mine and the original clutch (80K miles total on the original clutch) is still going strong... My old friend apparently just doesn't know how to drive a manual properly.
    EDIT: Oh yeah, I have an X-Runner so I drive it like a race car sometimes and it would be nice if the revs dropped abit faster between shifting.
  19. Mar 6, 2013 at 4:20 AM
    #39
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    If your racing why do you even let off the gas?
  20. Mar 6, 2013 at 6:38 AM
    #40
    GuyWithCamera
    Alan
    Tracy,CA
    Nissan 370Z
    Thats called power shifting... When you do that you're scuffing the clutch plate and adding excessive strain to the throw out bearing and transmission. So it's a bad thing to do...
    Google "power shifting bad"
