6 speed manual transmission fluid change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sechsgang, Jun 24, 2011.
  1. Jun 16, 2013 at 10:25 PM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    You have a lot more miles on yours then, I have 52K on mine. I would think using synthetic would help with the synchronizers. When I drained out factory fill there was very little metal dust on the magnetic drain plug. Good sign and the oil was fairly clean. I read about horror stories on these transmissions but if you drive it like a truck they should be fine. No speed shifting, leave that to your hot rod. :D
  2. Jun 16, 2013 at 10:28 PM
    byrd
    byrd Unknown
    David
    Kansas
    24MM or 15/16 both will work and use a 6 point socket, not a 12 point. I actually used 15/16 since it snug up a little tighter on the plugs. The 24MM was a tad loose.
  3. Jun 16, 2013 at 10:33 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    well all be dang
  4. Jun 16, 2013 at 10:34 PM
    byrd
    byrd Unknown
    David
    Kansas
    I will assume it was more than the $40 I paid for 2 quarts of RP and $3 for the crush gaskets. It's not hard to do, just have to crawl under her. The hard part is filling, I used a rubber hose and squeezed the bottle, but have bought a pump since then and did my front differential which made it so much easier. I would suggest the screw on hand pump for filling. Got mine at Napa for about $8.
  5. Jun 16, 2013 at 10:38 PM
    byrd
    byrd Unknown
    David
    Kansas
    Yeah after 30 years of changing the gear oil out on a muncie rockcrusher never once did it squirt out taking the fill plug out first, only Toyota. :rolleyes:
  6. Jul 5, 2013 at 11:13 PM
    Nmwill
    Nmwill Well-Known Member
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Blacked out emblems and grill. 265/75's shortened antenna
    About to order 2qts of redline mt-90 75/90 gl4 for my 6spd tranny. That's the right stuff isn't it?
  7. Jul 6, 2013 at 1:18 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  8. Jul 6, 2013 at 2:33 AM
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    never take out the drain plug if the fill plug doesn't come out first.. unless of course, you have a backup plan to fill the tranny with fluid.
  9. Jul 6, 2013 at 2:35 PM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    Yeah its not just so the oil drains easier. If you drain it and can't get the fill plug off you're hooped until you can haha.
  10. Jul 8, 2013 at 4:45 PM
    kalieaire
    Santa Clara County
    Yep, i've done that on my older cars. However this doesn't work for folks with a cable tranny. So it doesn't work in every situation.
  11. Aug 15, 2013 at 10:34 AM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
  12. Apr 21, 2014 at 12:18 PM
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Man, I just replaced my transfer case with local auto parts' synthetic and now it runs like CRAP! Going to spring for the redline and put it in the manual tranny and transfer case.
  13. Apr 21, 2014 at 12:23 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    yeah i did mt90/ rp/ amsoil/ and am on lucas right now mt was by far the best and rp was the worst
  14. Apr 22, 2014 at 8:38 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Is mt90 safe to use all around? I heard people say regular dino oil is best in the differentials. Plus it calls for gt-5
  15. Apr 22, 2014 at 10:17 AM
    #35
    Ghost848
    Tony
    Alberta,Canada
    no mt stands for manual transmission, i am using lucas in diffs right now and they are happy... non synthetic at that.
  16. Apr 23, 2014 at 9:52 AM
    #36
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Yah I did the same thing- went mt90 for the tranny and transfer case them regular dyno oil for the diff's with LSD additive in the rear. Runs great now! It almost pains me not to put synthetic in the diff's but I guess it doesn't work as well.
    Shifting is much smoother with the mt-90. Great oil!
  17. Apr 23, 2014 at 10:42 AM
    #37
    anethema
    J
    Dawson Creek,BC
    There is absolutely nothing wrong with synthetic in the diffs. It will work better in every way if you put the right stuff.
    After putting Amsoil severe gear in, my truck runs like brand new again. I put it in everything including the manual transmission.
    Here is a full white paper doing rigorous tests on all the synth gear oils.
    The amsoil came out far far ahead which is why I used it.
    http://www.scribd.com/doc/337564/Study-of-Automotive-Gear-Oils-from-wwwoilshoppercom
    My shifting is smooth like butter, my diffs are quiet and smooth. It's great.
  18. Apr 23, 2014 at 12:23 PM
    #38
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    mobil 1 transmission lube didn't work well for me,drained it out,and went with redline much better.
  19. Apr 23, 2014 at 12:38 PM
    #39
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Interesting. I tried Severe Gear in my 6sp and it didn't help at all. MT90 has been the best for me.
  20. Apr 24, 2014 at 11:57 AM
    #40
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    This is far from the first time I've heard this which is why I just went dyno in the diff's. The mt90 in the tranny and transfer case seems to be great but I wanted to out something better in the diff's. However, I heard regular was the best. Is the amsoil synthetic?
