6 speed manual transmission help please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Davetaco321, Jun 3, 2018.
  1. Jun 3, 2018 at 5:45 AM
    Davetaco321
    Davetaco321 [OP] Well-Known Member
    Black 06
    Can anybody tell me who builds good reman 6-speed manual? I have a 2006 Tacoma I love the transmission I cannot keep a clutch in it. It is not the clutch it is of course the bearings I have had squealing from the throwout bearing did a new clutch Hydraulics everything complete and had the new throwout bearing go out in 2 weeks. I put in the urd stainless steel throwout bearing sleeve upgrade and it lasted about 7 months now I am having the squeal again it is definitely the throwout bearing pre-loading when it is not supposed to when I press the clutch pedal in after I come to a neutral stop the squealing will subside or lesson. Short of going to Jasper which is probably going to be my next move I don't know what to do also and taking the junk strut20180603_084311.jpg spacer lift off and putting Billy's in the front already have the lift Leaf in the back. I love this truck but if I can't fix this transmission problem I don't know what I will do.
  2. Jun 3, 2018 at 6:19 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Generally when a thread title says “help, help, help...” it means someone is in duress and needs the TW crews assistance in recovery.
    Thread title changed
    glitcheffect7 and 98tacoma27 like this.
  3. Jun 3, 2018 at 6:52 AM
    Davetaco321
    Black 06
    Sry. Didn't mean to set off any alarms. Just at my wit's end and wallets and with my transmission.
  4. Jun 3, 2018 at 11:12 AM
    Hacktacular
    Hacktacular Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    These transmissions are not very good at all. There is a T56 conversion out there but it is expensive!
    I think a new OEM is about 3-4k.
  5. Jun 3, 2018 at 11:16 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The noisy throwout bearing is an issue that has plagued manual trans Tacomas for years....most of us just learn to live with it. It's rare that a throwout bearing actually fails...they just make that annoying chirping noise.
    Replacing the clutch every time the TOB starts to make noise sounds like an awfully expensive habit...
    Breadbox likes this.
  6. Jun 3, 2018 at 11:23 AM
    Hacktacular
    Robert
    URD makes a sleeve kit for this as well. I used it and so far no more squeak.
    eon_blue[QUOTED] likes this.
  7. Jun 3, 2018 at 11:25 AM
    eon_blue
    Azusa, CA
    Lucky, no fix that I'm aware of for 1st gens short of just replacing the whole clutch assembly with a beefier aftermarket kit, which I plan on doing next time around.
  8. Jun 3, 2018 at 12:34 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Do a search for the URD hydro throw out bearing. I think some people hear have had good luck with it.
  9. Jun 9, 2018 at 3:29 PM
    Davetaco321
    Black 06
    I have about $1,800 into trying to save this transmission I am over it and done. I am going to drive it until something breaks on it and then I am going to get the latest model 6-speed that I can find that will bolt to my bellhousing and do the Toyota TSB kit with a new bell housing at the same time. I bought a Chevy to drive because I want this truck bad. It has the 4 liter in it and it is strong as an ox.
  10. Jun 9, 2018 at 3:40 PM
    rheath08
    Russell
    Bakersfield, CA
    Like a couple of us has mentioned, look into the URD hydro bearing.
    I just put my trans back in today from replacing the 5th gear synchro. I did the URD sleeve kit. I reused my clutch, only 17k on it. Greased the hell out of the bearing, release fork, and fork pivot. I bypassed my clutch acumulator. I also put in a new slave from the fj cruiser. That slave has a 13/16 diameter piston while the taco is 7/8. I swear I could push my clutch with my pinky.i only have 15 miles on it, but she is grrrreat!
    (Childhood cereal mascot referance)
  11. Jun 9, 2018 at 3:42 PM
    Davetaco321
    Black 06
    Yeah my urd sleeve lasted 7000 miles would like to know how that works out for you after maybe ten thousand if it works I will check it out for sure I am also checking out the T56 trying to figure out if I can get my t-case to bolt and how the shafts have to work
  12. Jun 9, 2018 at 3:42 PM
    Davetaco321
    Black 06
    Also, had to first gen Tacomas never had this problem
  13. Jun 9, 2018 at 3:59 PM
    rheath08
    Russell
    Bakersfield, CA
    It is the design of the clutch release system that allows for this to start happening. Have you looked into the TSB's that Toyota has come out for this?
    Well, the first gens and the second gens are two completely different vehicles. The 4cyl second gen has the same R155 manual trans as the first gens.
    As for looking into a new trans out of a newer Tacoma, if you find that the new RA62f (I think that is the new 6sp trans in the 3rd gen) works, then let me know. The gear ratios look better than the RA60.
  14. Jun 13, 2018 at 5:59 PM
    Davetaco321
    Black 06
    As I'm sure most of you know could not find a T56 swap for a four-by-four 6-speed Tacoma. Also, went to urd website and the page for the hydro bearing is no longer available so I'm assuming the hydro bearing is no longer available I don't know. Back to the drawing board.
