6 speed manual transmission noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elrobbygtaco, Nov 24, 2022.
  1. Nov 24, 2022 at 9:57 PM
    elrobbygtaco
    elrobbygtaco [OP] Member
    Robby
    2.7L 2013 Toyota Tacoma 4x4
    Hey I am trying to diag a noise coming from my manual 6 speed transmission on an 06 trd off-road. The noise is heard in the cab when driving in gear. It’s a slight hum or grind that could be mistaken for your ac fan being on. When I move the shifter around I can change the pitch in the sound ever so slightly. At low speeds the sound is not so loud. It is loudest in 4th and 6th gear doing highway speeds. 5th gear is completely normal. I just put a new master cylinder in, bled it and changed my transmission oil. The noise was there before this work but has settled down a little after. But is still bugging me. Anyone out there have this problem? Tips or tricks? I’m thinking my synchros are maybe worn down or off. Lmk what you think. Thanks!
  2. Nov 24, 2022 at 10:04 PM
    sethstacoma
    sethstacoma Well-Known Member
    Seth
    2022 Toyota Tacoma TRD O/R 6spd manual.
    A hum or a grind? Two distinct different sounds.
  3. Nov 25, 2022 at 7:54 PM
    elrobbygtaco
    Robby
    It’s not really much of a difference in this instance. If I had to pick one or the two I would say hum. And you can feel it through the shifter knob. So obviously deep down it’s a soft grind.
  4. Nov 25, 2022 at 7:59 PM
    sethstacoma
    Seth
    If its not grinding shifting into any gears I'd say syncros are working good, I've had gear boxes that had hum in certain gears at certain rpms. What transmission oil did you use and when you drained old out any unusual shavings come out?
  5. Nov 25, 2022 at 8:00 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Does the sound go away when you press the clutch? If so, then it's possible the throw out bearing is going.
  6. Nov 26, 2022 at 5:26 AM
    elrobbygtaco
    Robby
    It’s not a throw out bearing. It only makes noise when it is in gear. And the noise goes away when In neutral or when the clutch is in. Also it does sometimes grind downshifting to 2nd or upshifting to 3rd under load. But I used 75w-90 gl4 royal purple gear oil. Ever since I installed the new master cylinder and trans oil. The noise has reduced and shifting has become much smoother. But it’s just this noise when in gear driving I can’t seem to understand.
  7. Nov 26, 2022 at 5:28 AM
    elrobbygtaco
    Robby
    Starting to think I might have to just have a transmission expert take a look. It does have 150k on it and if it was driven rough it could just be time for new gears. Also no metal shavings when I did the trans oil. Everything appeared normal.
  8. Nov 26, 2022 at 6:16 AM
    sethstacoma
    Seth
    I've had a tacoma that had the hum in certain gears I say just drive it as long as it isn't grinding too often and fluid is good should be able to get another 100k or more just like it is.
  9. Nov 26, 2022 at 2:44 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    My 6 speed has always whined in gear while moving. 207K miles.
    elrobbygtaco[OP] likes this.
  10. Nov 26, 2022 at 6:05 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Mine used to whine in 4th, but it has quieted down in the last couple of years.
    I use Lucas mostly, but switched to Redline this last time. I'm at about 139,000 miles.
  11. Nov 10, 2023 at 7:31 PM
    Dirtytco
    Dirtytco Member
    Josh
    2016 MGM Offroad on Kings
    What did the master say about your trans?
  12. Oct 25, 2024 at 10:03 AM
    Suprtank
    Suprtank New Member
    2006 Tacoma TRD 6spd 340k
    None
    My 2006 Tacoma TRD 6spd v6 340k is making the same hum in the same gears. Runs and pulls strong though. It bothers me because I’m worried something is wrong, but it just runs too dang good. Did you ever get an answer?
  13. Oct 25, 2024 at 4:30 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Change the fluid, Redline MT90 and life should be good. Same fluid in transfer. Redline 75W90 in diffs. See if that helps rather inexpensively.
  14. Oct 26, 2024 at 12:11 PM
    HellsWells
    HellsWells Well-Known Member
    Spencer
    Richmond, Va
    2011 TRD Off Road Double Cab
    Are you still using the original shifter? If so the rubber dampening in the shift lever could be deteriorated. I have a short throw Core shifter. My transmission started to whine in 4th and 6th as soon as I installed the Core shifter, which is a solid one piece shifter.
