6-Speed MT - Anyone swap 6th?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Mar 13, 2017.
  1. Mar 13, 2017 at 9:08 AM
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Getting a little tired of the horrible gas mileage on longer trips. Has anyone swapped their 6th gear for a lower RPM gear? Not sure if it's that straight forward, but I'd love to drop some RPMs.
    Norton likes this.
  2. Mar 13, 2017 at 11:28 AM
    Dasche_Riprock
    Dasche_Riprock Member
    Dasche
    2007 Tacoma Base Access Cab
    2" Supreme Suspension lift with 265/75r16 KO2's
    Good question! I'm interested in this as well.
  3. Mar 13, 2017 at 11:29 AM
    rockguitar316
    rockguitar316 Well-Known Member
    Adam
    Dayton Ohio Area
    Now: 2016 WRX stage 2 377hp/350tq. Then: 2016 TRD Sport DCSB 6MT (don't kick me!)
    It's definitely been done. There's threads all over about re-gearing. Just use the search bar.
  4. Mar 13, 2017 at 11:32 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I don't think that's called re-gearing. this would involve tranny work (id assume) re-gearing is dropping in new differential that is geared differently. swapping out a single drive gear probably wouldn't be so simple.
    Norton and tamer[OP] like this.
  5. Mar 13, 2017 at 12:06 PM
    mtbjohn42
    mtbjohn42 Well-Known Member
    Laporte, CO
    2005 Toyota Sequoia
    Get bigger tires :)
  6. Mar 13, 2017 at 12:48 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I would be more interested in a Granny Gear but I dont think its possible.
  7. Mar 14, 2017 at 6:07 AM
    tgear.shead
    tgear.shead Well-Known Member
    The R452's 5th gear is used on R150/151/155 to achieve a 0.69:1 5th gear. I don't know if that gear will fit RA60 or not, or if the cluster ratio is appropriate to make this change, but it might be worth some research.
