6-speed pilot shaft problems??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jgolden, Jan 9, 2010.
  1. Jan 9, 2010 at 3:08 PM
    jgolden
    jgolden [OP] Member
    06 Access Cab TRD Sport 6 Speed
    TRD Exhaust
    Does anyone know anything about the pilot shaft problems with the 6-speed Tacomas.
  2. Jan 9, 2010 at 3:10 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This has been covered a billion times. Do a search please
  3. Jan 9, 2010 at 3:16 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    Search Throw Out Bearing and Release Bearing too.
  4. Jan 9, 2010 at 3:19 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Its post #10
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/17819-throwout-bearing-again.html
    not sure if this is everything but based on the name of the thread it would have been hard to search and find that this thread talked about your topic.. check it out i hope it helps.
    edit: pinting people in the right direction whenit comes to search is not that hard gentlemen...lets try to help out instead of rip into people.. just sayin... people who dont know how to use the search function or know that it is even there because they are new to forums are always going to be here! lets jsut take a quick second to help them out. i mean you did take the time to make a post that offered them no help.
    at least torque sent him where he neded to go
  5. Jan 9, 2010 at 5:59 PM
    jgolden
    jgolden [OP] Member
    TRD Exhaust
    Thanks alot gjbonner
  6. Jan 9, 2010 at 7:52 PM
    gjbonner
    Guy
    Northern Idaho
    hey not a problem...90% of the people on here are very willing to help so dont hesitate to ask. however i will say that trying to use the search function to its fullest extent is going to go a long way in any forum. if there is no luck with the search then state that in your post and you will avoid negative "postbacks".
  7. Jan 9, 2010 at 8:41 PM
    jgolden
    jgolden [OP] Member
    TRD Exhaust
    I really want to know if anyone knows anything about a TSB for the T/O bearing and pilot shaft problem. Not had any luck finding one if there is one.
  8. Jan 9, 2010 at 9:23 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This is the only one I have saved.T-SB-0385-09.pdf
