6 Speed rough disengage from first.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dimitrik, Apr 12, 2011.
  1. Apr 12, 2011 at 12:11 PM
    dimitrik
    dimitrik [OP] Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    I have this problem for a while now, but I am just wondering if anyone else has this.
    When I disengage the first to shift to second there is this rough feeling and sound that comes with it. Only way to avoid it is to keep the gas pedal pushed slightly for about half a second.
    Is there a known fix for that? Or is it just a flaw?
  2. Apr 12, 2011 at 12:40 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    are you sure you're depressing the clutch 100%?
  3. Apr 12, 2011 at 12:44 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  4. Apr 12, 2011 at 3:54 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    I'm sorry, I wasn't specific enough.
    What I mean is when I press the clutch to switch gears in first, it does the jerk and sound. From first to neutral is what I mean. Moving the gear is all fine, it is just when I press the clutch.
    After the jerk I put neutral with no trouble. Hope I explained it better.
  5. Apr 12, 2011 at 4:32 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    That is "normal" for the 6 speed. Wait until you experience the clutch lag during first start up when it's cold. Not to mention the pedal squeak when it's hot out.
  6. Apr 12, 2011 at 6:02 PM
    dimitrik
    Dimitri
    Quebec
    AllPro Skidplate
    It's got 50 000km. I know most of the caprices of the clutch. I just wanted to see how normal the thing I mentioned was.
    So I'll just keep doing my thing for the first that makes it smooth then. No biggie.
