6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. Feb 14, 2021 at 8:09 PM
    #201
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
  2. Feb 14, 2021 at 8:54 PM
    #202
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I did turn a little adapter to make the release bearing that I selected play nicely with the Tilton release bearing piston. That would not be necessary if you were doing this swap using the 3rd gen pressure plate and release bits though. Details on that are in the the other thread. Let’s discuss that there for the benefit of all that’re interested.
    Although they’re a little bit blended; I’ve been trying to keep the trans swap info separate from the clutch/etc... thread. My thoughts on that are the possibility that someone may be interested in the HRB and not so much in the trans swap. Or, vise versa.
    Jeff Lange and 6 gearT444E like this.
  3. Feb 15, 2021 at 2:46 PM
    #203
    BillDaCat8
    Jake
    PHX
    I did more driving around today. Had to get the truck through emissions. So, I knew I needed a bit of freeway driving to complete my drive cycle.
    Wow. Is the best word I can think of. It’s awesome. Cruising at 75 is quieter and more relaxed. It was fun to downshift into 5th (same ratio as the RA trans 6th) and buzz along for a bit, then click it up into 6th and watch the rpm’s drop. I think the driveshaft balancing is a factor as well. The truck feels so smooth now.
  4. Feb 16, 2021 at 3:25 PM
    #204
    BillDaCat8
    Jake
    PHX
    First post updated with parts list. I'm probably forgetting something. Remind me of any glaring omissions and I'll fix it.
    jjgandarillas and TodayWasTHeDaY like this.
  5. Feb 17, 2021 at 1:22 PM
    #205
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I've been following both threads and it's making me think about the Mustang hydro bearing retrofit that URD used to make (which I do have in my truck now). Wondering how possible it would be to adapt that kit. Based on the pictures you've posted, I can see my hack abilities making that work.
  6. Feb 17, 2021 at 1:36 PM
    #206
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Couple questions for other people that might want to consider doing this to their trucks.
    1. Was there a reason you shortened your rear shaft instead of also getting the rear shaft from an A750F truck? I think it was mentioned, but then you ended up only doing the front shaft.
    2. Was there a reason you went with the hydraulic throw out bearing instead of using the original release bearing setup from the RC62F beyond having already looked into/worked on it for your RA60F? Perhaps I should read the other thread.
    Jeff
    BillDaCat8[OP] likes this.
  7. Feb 17, 2021 at 2:41 PM
    #207
    BillDaCat8
    Jake
    PHX
    Are you speaking of their U-fix kit that had you cutting off the quill and using a baseplate that clamped on the pivot ball end and affixed to the hole for the slave cylinder?
  8. Feb 17, 2021 at 4:19 PM
    #208
    BillDaCat8
    Jake
    PHX
    I had surmised that there was likely an OE rear shaft that would be a straight bolt in. (I was thinking from a 3rd gen though.) I doubt I could've found one for less than the $120 that I paid to have the shaft shortened, balanced, and the u-joints replaced though. So, I never pursued that option.
    For the very brief period that my previous hydro bearing was working well, I really liked the feel of it. I've heard third gen guys complaining of issues with their stock release hardware too. I figured that this setup should be fairly trouble free if I did it right. Time will tell I suppose. I did save all that stuff. So, if things go sideways, I'm ready.
    Jeff Lange[QUOTED] likes this.
  9. Feb 17, 2021 at 4:38 PM
    #209
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I'm not sure how many people have their trucks from 2wd to 4wd, but due to the carrier beating being in a different location the driveshaft will need to be custom. That is if they are doing a both conversions at the same time, other wise just take the existing shaft to have shortened. Hope that gives you some of the info you're looking for.
  10. Feb 17, 2021 at 5:08 PM
    #210
    Athlaos
    Leigh
    Edmonton
    Yeah exactly.
  11. Feb 17, 2021 at 5:15 PM
    #211
    Jeff Lange
    Calgary, Canada
    Yeah that's probably true, plus you know yours is nicely balanced as well.
    Jeff
  12. Feb 17, 2021 at 6:05 PM
    #212
    BillDaCat8
    Jake
    PHX
    I believe that what Jeff is pointing out is that the way I went about this is is not the only way that it can be done. The OE 3rd gen release stuff will work as long as you use a 3rd gen pressure plate. I’m betting the driveshaft he mentions would work right out of the box as well. The more information that’s out there, the better. I’m totally cool with that.
    This is the first time I have performed this swap. Heck, it might be the first time anyone has. We’re all going to learn more about doing it as others give it a try.
  13. Feb 22, 2021 at 10:37 AM
    #213
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    From what I'm understanding with regards to length of transmission, is that the RC is 1" longer than RA. Meaning that the auto front and rear shafts should work? Also the cross member mounting doesn't need any fab work?
    My apologies if this has been answered been digging for a little. I want to manual swap my second gen auto long bed. Deciding on the right transmission right now.
  14. Feb 22, 2021 at 10:42 AM
    #214
    rheath08
    Russell
    Bakersfield, CA
    Yes that is correct. but, the cross member needs the bolt holes drilled out to a larger size. 10mm I believe.
  15. Feb 22, 2021 at 10:46 AM
    #215
    j_sav115
    SC
    07 Silver TURD SPRT
    Seems my aspirations just got more expensive lol
    rheath08[QUOTED] likes this.
  16. Feb 22, 2021 at 12:23 PM
    #216
    BillDaCat8
    Jake
    PHX
    No drilling was required actually. The holes in the crossmember were fine for the 10mm bolts. Went right together like it was made for them.
  17. Feb 22, 2021 at 1:13 PM
    #217
    Jeff Lange
    Calgary, Canada
    The only real modification this swap requires is going to be the shifter or shifter hole, and then some small brackets here and there. If you buy the right parts, it's basically a slap it together type of a situation.
    I might do something about that shifter if I find the time...
    Jeff
    BillDaCat8[OP] and j_sav115 like this.
  18. Feb 22, 2021 at 1:17 PM
    #218
    j_sav115
    SC
    07 Silver TURD SPRT
    I gotta cut a new hole anyway! At least I think I do lol
  19. Feb 22, 2021 at 1:21 PM
    #219
    j_sav115
    SC
    07 Silver TURD SPRT
    Carpart prices between these model transmissions seem to be pretty damn close. May be worth it to swap to a newer one.
  20. Feb 22, 2021 at 2:01 PM
    #220
    rheath08
    Russell
    Bakersfield, CA
    Well this just keeps getting better. Lol! I hope I drilled the holes large enough the first time.
