6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. Feb 22, 2021 at 4:00 PM
    #221
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Oh? What’re ya thinkin ?
  2. Feb 23, 2021 at 1:20 PM
    #222
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Design a shifter relocation setup so that it can come through the floor in the stock location. I've thought it over a bit and it seems pretty reasonable. That said, I'm way too busy with school right now to even think of taking on any new projects, haha.
    Jeff
  3. Feb 23, 2021 at 6:16 PM
    #223
    BillDaCat8
    Jake
    PHX
    Tease!
    Jeff Lange likes this.
  4. Feb 23, 2021 at 6:24 PM
    #224
    BillDaCat8
    Jake
    PHX
    That would be pretty cool. But, really, not all that necessary. Moving the boot was no big deal. Now that it’s all assembled, it looks and functions as if nothing ever happened. You’d never know I changed anything by looking at it. Or driving it for that matter. Save the different ratios. Which, I’m still in love with btw.
  5. Feb 23, 2021 at 7:17 PM
    #225
    Jeff Lange
    Calgary, Canada
    Yeah, it's really not a big deal, though I know there are probably some people who would probably prefer to skip doing so. There always are, haha.
    Jeff
  6. Feb 23, 2021 at 7:48 PM
    #226
    BillDaCat8
    Jake
    PHX
    What holes did you drill?
  7. Feb 23, 2021 at 10:53 PM
    #227
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I had to make a custom transmission cross member for the 4x4 conversion. I was talking about the trans mount bolt holes I drilled into the new cross member being the correct size for the RC62f mount. I don't remember what size holes I drilled. That was about 3ish to 4ish years ago.
    I apparently had a lapse written communication and failed to express myself properly. :anonymous:
  8. Feb 24, 2021 at 10:55 PM
    #228
    6 gearT444E
    Deep South
    Herculiner Hootus
    Maybe question was asked but missed it, did you order a clutch for the RA or RC transmission when replacing, and would they be interchangeable, i.e. either one would work? Does the bolt pattern on the pressure plate match the 1GR-FE and 2GR-FKS?
  9. Feb 25, 2021 at 4:22 AM
    #229
    BillDaCat8
    Jake
    PHX
    The clutch and flywheel I am running is all 1gr stuff.
    I believe that the 2grfks flywheel itself has a different flywheel to crank bolt pattern. So, that wouldn’t work. Just sayin.
    The 3rd gen 2grfks clutch bolts right up to the 1gr flywheel. If you plan to run the OE (RC62F) release hardware, then that’s the way to go.
    6 gearT444E[QUOTED] likes this.
  10. Feb 25, 2021 at 5:01 AM
    #230
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The pressure plates for both are listed as 311 mm P.C.D (Pitch Circle Diameter). Discs are 275mm with 21 spline 29.8mm dia. shaft. Flywheel step should be -1.5mm... but that needs verification.
    BillDaCat8[OP] likes this.
  11. Feb 25, 2021 at 7:28 PM
    #231
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Does your Spec clutch have noisy engagement?
  12. Feb 25, 2021 at 7:30 PM
    #232
    6 gearT444E
    Deep South
    Herculiner Hootus
    Thanks, that's what I thought but wanted to double check.
  13. Feb 25, 2021 at 8:24 PM
    #233
    BillDaCat8
    Jake
    PHX
    Yeah. It’s a bit rowdy. I’m hoping that it’ll mellow out with some use. @TodayWasTHeDaY had the same experience with this clutch.
  14. Feb 25, 2021 at 9:15 PM
    #234
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Mine had a howlingly noisy break in and at around 1800 miles it occasionally can be a bit noisy when slipping in first but is tamed down considerably both in noise and ease of driving.
    Jason J[QUOTED] likes this.
  15. Mar 9, 2021 at 7:57 AM
    #235
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    Hopefully you guys would have some info....
    Would anyone know the difference between an 07 FJ manual to a 2011 FJ Manual?
    Carpart doesn't list them as interchangeable. I have a lead on an 07 in texas I could grab up.
  16. Mar 9, 2021 at 9:27 AM
    #236
    rheath08
    Russell
    Bakersfield, CA
    As far as I know the only difference in internal upgrades or improvements. Hopefully someone can confirm that.
    j_sav115 and BillDaCat8[OP] like this.
  17. Mar 9, 2021 at 1:54 PM
    #237
    Jeff Lange
    Calgary, Canada
    There are differences in the clutch slave cylinder hydraulic line routing, the noise insulator and some small internal differences but they will bolt up the same and are pretty much fully interchangeable.
    Jeff
  18. Mar 9, 2021 at 5:46 PM
    #238
    j_sav115
    SC
    07 Silver TURD SPRT
    Thanks man!
  19. Mar 9, 2021 at 6:18 PM
    #239
    BillDaCat8
    Jake
    PHX
    I just got back home this afternoon from my first decent length trip with the new trans. Roughly 750 miles over three day period. Cruising at freeway speeds is so much nicer. Just quiet and mellow. Can actually hear the stereo without cranking it. I did 75-85 mph through the bulk of it. 2k-2500 rpm with a few jaunts up higher for passing. It’ll cruise happily at 90+ as well when you want to put some distance between yourself and that jagoff you just passed. It just glides along. Did some twisty mountain roads too on the way out. Lower gears there of course. The 1gr, even without getting into boost, does an admirable job of moving things along.
  20. Mar 19, 2021 at 6:10 PM
    #240
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    So jealous...Wish I had the technical know how, (and money) to swap in 3rd, 4th, 5th and 6th gear out of the RC into my RA's.
    I cruise at 70 mph at 2500 rpm, and notice my dad's truck (3rd gen) cruises at less than 2000 rpm at 70 mph.
    Great follow up, and thread all together!
