6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. May 6, 2021 at 4:15 PM
    #261
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    My RC62F showed up. :D
    Now to make the AWD t-case fit.
  2. May 6, 2021 at 5:46 PM
    #262
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Looks like you’re gonna need the trans mount too.
    Did you get the T/O bearing and all of the release stuffs along with?
    rheath08 likes this.
  3. May 6, 2021 at 5:49 PM
    #263
    BillDaCat8
    Jake
    PHX
    There was a guy on the fj transfer swap thread that did some fancy scan deal and then 3D printed a template to use when “adjusting” the back of the trans to accept the fj case. We need that guy.
    rheath08[QUOTED] likes this.
  4. May 6, 2021 at 5:51 PM
    #264
    BillDaCat8
    Jake
    PHX
  5. May 6, 2021 at 8:14 PM
    #265
    rheath08
    Russell
    Bakersfield, CA
    Yes but it looks like the TO bearing has been separated. I have a new one on the way.
  6. May 6, 2021 at 9:41 PM
    #266
    rheath08
    Russell
    Bakersfield, CA
    One of these does don't look like the other. Lol!
  7. May 7, 2021 at 7:37 AM
    #267
    bravinci
    bravinci Well-Known Member
    Brent
    British Columbia
    First Gen 4 door Tacoma
    Here's the link to the google drive with a fusion 360 file (Free for personal use)
    Fusion 360 Personal:
    https://www.autodesk.ca/en/products/fusion-360/personal
    Google Drive:
    https://drive.google.com/drive/folders/1JrNnwKkB7NZrTJ24vJA3Fn3Y9bH2Cpon?usp=sharing
    You "should" be able to take this file to a local 3d printing company and get them to print it for you if you don't have a 3d printer yourself. I only say "should" because some 3d printing programs might not be able to import a file from fusion 360. In which case you'd have to download the program, export it into a suitable file format, and then send it to the 3d printing company.
    Just note, I left the Shift Rod dowels a bit long, since different people will have different preferences with how far they want to grind the shift rods down (please don't grind that far into your transmission :anonymous:)
    mav and BillDaCat8[QUOTED][OP] like this.
  8. May 7, 2021 at 8:09 PM
    #268
    rheath08
    Russell
    Bakersfield, CA
    So for the gents that are looking to do the AWD case with the RC62F it does not look promising at this point.
    The two shafts stick out 21mm ish. The one on the pass side of the case or has the taper in the pic has enough sticking out to trim down. It look like the max depth on the back of the RC is 14mm and that is starting to break through at the top edge. May be able to see in the pic.
    The shaft on the driver's side of the t-case does not look like there is room to cut it down. I may be able to tap the seal in farther but not sure on how much I could cut off. Not 7mm anyways.
    So I'm open for thoughts because I would love for this to work.
    P.S. pics are not in order.
  9. May 7, 2021 at 8:11 PM
    #269
    rheath08
    Russell
    Bakersfield, CA
    Sorry last pic is of the 21mm shaft measurement up to the back of the trans after the clearancing.
  10. May 7, 2021 at 8:52 PM
    #270
    6 gearT444E
    Deep South
    Herculiner Hootus
    That’s awfully close, I wonder between grinding the shift rails down a bit, honing out the trans area as much as possible and then if you make a small spacer between the trans and tcase. The biggest challenge there would be ensuring the transfer input shaft has enough spline engagement.
  11. May 7, 2021 at 9:14 PM
    #271
    rheath08
    Russell
    Bakersfield, CA
    I like the idea of a 3-4mm spacer, but I don't think it can go any bigger than that. You would run into the issue of the dowels not lining up the two parts.
  12. May 7, 2021 at 9:23 PM
    #272
    6 gearT444E
    Deep South
    Herculiner Hootus
    it would be easy enough to mock up using some washers to simulate the spacer and see if it would be enough.
  13. May 7, 2021 at 9:29 PM
    #273
    rheath08
    Russell
    Bakersfield, CA
    yeah that is true. If my quick math was right there is a 7-8mm "giving 1mm of leeway" that need to be made. The shaft on the drivers side sits flush with the front of the t-case when 4lo is engaged. That does not leave much of the shaft to trim. I may be able to tap the seal in farther, but I'm done for the night. Especially after the t-case falling on my big toe. I really want the to work.
    6 gearT444E likes this.
  14. May 7, 2021 at 9:35 PM
    #274
    BillDaCat8
    Jake
    PHX
    How much of the RH shaft protrudes when the shifter has it all the way rearward?
  15. May 7, 2021 at 9:43 PM
    #275
    rheath08
    Russell
    Bakersfield, CA
    @BillDaCat8 That is all the way rearward. So there is room to cut that one down. The other pic where they are equal is them all the way forward. The issue I see is the left shaft or drivers side. It sits flush with the front on the t-case when all the way rearward.
    I'm going to leave all the text here, but add, the pic you are quoting is both shafts all the way back.
    The alcoholic beverages my be impeding my communication skill now.:drunk:
  16. May 7, 2021 at 9:57 PM
    #276
    BillDaCat8
    Jake
    PHX
    How did you know!? :cheers:
  17. May 9, 2021 at 9:38 PM
    #277
    rheath08
    Russell
    Bakersfield, CA
    @BillDaCat8 do you have the heavy flywheel or the OEM? You have the stock gearing and tire size, correct?
  18. May 9, 2021 at 9:54 PM
    #278
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Not that it's particularly relevant, more so looking for the same answer you are than anything but I have stock gears, started ordering parts for 4.88's and the URD heavy flywheel.
    I think I will go back to a stock weight one with gears though.
  19. May 9, 2021 at 10:17 PM
    #279
    BillDaCat8
    Jake
    PHX
    Stock gears, stock flywheel. Not positive on tire diameter. What’s the diameter for a 285/60/18 ?
  20. May 9, 2021 at 10:24 PM
    #280
    rheath08
    Russell
    Bakersfield, CA
    Comes out to 31.5". If I remember correctly the stock tire came to 30.8".
