6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. Jan 7, 2022 at 3:50 PM
    #301
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    huge relief thanks, Transmission from a 2018 on the way with everything associated with it .. temped to also install the URD heavy flywheel, it was on my list for the RA ..
  2. Jan 7, 2022 at 3:53 PM
    #302
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I have a urd heavy flywheel. PM if your interested.
  3. Jan 25, 2022 at 11:59 AM
    #303
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Well was pointed to this thread from another thread. Been asking for a while if anyone has done this, glad to see some finally have and that its awesome. I have had the lovely chirp chirp for a few years and didnt like how none of the "fixes" seemed to last or actually fix it.
    My chirp hasnt got super bad, so just waiting for the clutch or something to go out (currently 170k on it), before i try anything. But will probably have to go this route, once it goes out, if i can gather the funds by then, lol. :rofl:
    Edit: Question, have y'all noticed an increase in your MPG's? I figure you would.
  4. Jan 29, 2022 at 7:01 AM
    #304
    hilux30
    PEI
    '15 4Dr SB 6MT
    Question:
    So if understand correctly, the A750F is an inch longer than the RA60F? meaning I could possibly source a rear driveshaft from a 2nd gen Auto? instead of cutting down my DS? or the flanges are different?
    I did also get the front DS from a 2nd gen Auto..
  5. Jan 29, 2022 at 7:03 AM
    #305
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yes it is. I have an RA60F and swapped t-cases for one that is an inch longer and i used driveshafts out of a 2nd gen A750F truck
    carrier bearing mounts in the same place, just the front half is an inch shorter
    Jeff Lange and TodayWasTHeDaY like this.
  6. Jan 29, 2022 at 7:12 AM
    #306
    hilux30
    PEI
    '15 4Dr SB 6MT
    good stuff thx, current DS has tiny of bit of play at the splines, DS shop might not want to cut it...
    It would be nice to find a clean 1st Gen Tundra DS and send that to the shop..
  7. Jan 29, 2022 at 9:56 AM
    #307
    rheath08
    Russell
    Bakersfield, CA
    When I first did my 4x4, I just went with a complete new driveshaft and put a double cardigan on the front of the rear half. I have not had vibration issues. This would be my recommendation instead of getting a tundra shaft and modifying it.
    hilux30 and Key-Rei like this.
  8. Feb 10, 2022 at 2:04 PM
    #308
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    BLtheP, GilbertOz, dborrer and 6 others like this.
  9. May 21, 2022 at 7:39 AM
    #309
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome thread!
    I've got a clean, low-mile 2014 DCLB that I like well enough but the words I use can't begin to describe how deeply I loathe the A750auto trans, even with Justin/Ben's tranny tunes.
    Thanks for doing the work and putting this thread together @BillDaCat8. Waiting patiently to see how the FJ AWD case plays with the RC62 and with those future additions might have a truck I love as much as I did my 1st gen :D
  10. May 31, 2022 at 6:27 AM
    #310
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Good morning @BillDaCat8, @gearcruncher or any other RC62f tranny gurus:
    Can you tell me specifically what the update to the RC62f was in 2018 and later years and what the part number is and/or when the change occurred in 2018?
    Thanks so much!!!
  11. May 31, 2022 at 7:44 AM
    #311
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The transmission part number split is 11/2017 and newer. The detent ball, shift interlock, and mid case have updated numbers... the remainder of the transmission appears to be the same. Are you considering new or used?
    Transmission part numbers...
    33030-04060 RC62F (08/2015 - 10/2017)
    33030-04070 RC62F (11/2017 - 08/2019)
    GilbertOz and BillDaCat8[OP] like this.
  12. May 31, 2022 at 7:56 AM
    #312
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Just the info I was looking for! Thanks Brian. I'm likely looking at used so looking for the most updated version. Now I can do that. Thanks again.
  13. Jun 6, 2022 at 8:13 AM
    #313
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Are the changes (updated detent ball, shift interlock and midcase) important enough to try skip over the 2016 and 17 trucks? Kaizen and all aside, I'm just curious...
  14. Jun 6, 2022 at 8:26 AM
    #314
    Jowett
    Brian
    North Adams, MA
    The 2016 has T-SB-0088-16 to update the detent ball. The detent ball is super easy to swap should you buy an early transmission. From 03/2016 the interlock plate was updated, from 05/2016 the detent was also. The case was updated at 11/2017. Are the interlock and case worth going later? That I do not know.
    DesertRatliff likes this.
  15. Jun 6, 2022 at 8:31 AM
    #315
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    There's a wrecked 2017 a few hours north from me. I'll see if he's responsive and willing to take a pic of the VIN. Thanks again for the info, Brian.
    Jowett likes this.
  16. Sep 27, 2022 at 1:09 PM
    #316
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    Has anyone done this on a stock (non tuned/boosted) 4.0??? Have approx 175k on my 09 and either the clutch took a shit or whole tranny is shot. Wondering if anyone has any thoughts or data on any mpg increases ( do mostly highway driving) and if 1st is a big difference for any off roading. I have the 2lo mod already so reverse isn't a concern. And where are yall finding these RC62F transmissions? I'm in middle TN and seems like they are very few and far between.
  17. Sep 28, 2022 at 6:15 AM
    #317
    super g
    garrett
    north carolina
    .64 6th ( plus double overdrive) would be great. Does anyone know the differences in length between the RC60F/RC61F and the RA60F as well as if the bell housings use the same bolt pattern?
  18. Sep 28, 2022 at 7:12 AM
    #318
    Jowett
    Brian
    North Adams, MA
    Keep reading this thread, most of the info you seek should be contained. As for the RC60F and 61 transmissions that are installed in the diesels, the lengths of the cases, bellhousings, and input shafts are all the same. Only that 5th gear ratio is different. If you want the Diesel ratios, you'll have to buy a complete transmission and swap the input shaft, bellhousing, and front bearing retainer/quill.... that's the best way at the moment.
    Eventually, we might be able to buy an RC62 and rebuild it with the Diesel gears.... but by the time source all the indivual parts, they may add up to more $$$$ than just using 100% new.
  19. Sep 28, 2022 at 8:55 AM
    #319
    super g
    garrett
    north carolina
    Well I guess the best option for a more or less plug and play unit option to replace the RA60F is the RC62F then( on a time and budget crunch) and then play around with the RC60F/RC61F options as time and funds permit. Would be nice if we could get a gear swap kit or something for the better cases. Thanks again for the great info and help.
  20. Sep 28, 2022 at 9:04 AM
    #320
    super g
    garrett
    north carolina
    @BillDaCat8 what clutch are you using for the RC62F and where did you get it? I have a mostly stock 1GRFE and URD USA does not have any clutches listed for the 3rd gen 3.5l tacomas. Wasn't sure what other reputable companies there were out there for the tacomas and 3rd gen clutches. Thanks for all the great info.
    Athlaos and Sociopenguin like this.
