6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. Nov 28, 2022 at 8:33 PM
    #361
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Yeah, that's where I'm at. I will try 275/70R17 next to see how they do before I look into re-gearing again.
  2. Nov 29, 2022 at 4:41 PM
    #362
    offroadtoyboy
    offroadtoyboy Well-Known Member
    Middle of nowhere Cali
    2006 Pre-Runner / converted to full manual 4WD / RC62 swap / Manual 4R trasfer case mod
    For any of you doing the swap if you need a shifter let me know I have a spare. It has had the epoxy infusion mod done by the member Coupe.
  3. Dec 1, 2022 at 4:33 PM
    #363
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    If I may ask: What is "the epoxy infusion mod" done by the member Coupe...
  4. Dec 1, 2022 at 5:52 PM
    #364
    offroadtoyboy
    Coupe could explain it better, but he drills into the lower bell portion of the upper half of the shifter and injects epoxy to ether repair the broken vulcanized rubber bond or prevents it from separating in the future. Additionally he does this when he shortens the shifter as well.
    They tend to be a little more noisier the a stock one but less then a typical aftermarket shift (B&M, etc.)
    I’ll see if I can locate the thread were he talks about it or maybe get him to reply to this thread.
    dborrer[QUOTED] likes this.
  5. Dec 1, 2022 at 6:14 PM
    #365
    offroadtoyboy
  6. Dec 1, 2022 at 11:13 PM
    #366
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    Do you have a spare to the new RC62F or the old Ra60F? I didn't think they were interchangeable, but I could be wrong.
  7. Dec 2, 2022 at 6:43 AM
    #367
    offroadtoyboy
    You are correct they are not interchangeable. I have spare because I bought another one and had it modified by Coupe again.
  8. Dec 5, 2022 at 3:57 PM
    #368
    dborrer
    Mr. Dan
    St. Augustine, FL
    Fantastic ! Thanks.... that gives me some ideas... I have a FJ Cruiser T-case swapped in and its (isolator portion of) shift rod was cut off and a new section of rod welded on with some bends to make it all fit in my stock shift console. With that section of isolator removed, it throws a fair bit of sound into the cab that is annoying.
  9. Dec 5, 2022 at 9:57 PM
    #369
    offroadtoyboy
    Not a problem
  10. Jan 11, 2023 at 1:50 PM
    #370
    super g
    garrett
    north carolina
    Is it the standard shifter or the TRD ss that you have? Am debating between the B&M or Core/Hurst and from what I've heard the TRD molded by coupe is great( but he doesn't have any).
  11. Jan 11, 2023 at 3:05 PM
    #371
    offroadtoyboy
    To my knowledge they did not produce a TRD SS for the 3rd gen tacoma. It is a stock shifter with Coupe’s epoxy mod done to it.
  12. Jan 11, 2023 at 4:06 PM
    #372
    super g
    garrett
    north carolina
    Got ya. Thanks. I really like the new B&M with what appears to be a split shaft coupled with an isolator medium like the OEM toyota one. Wonder what the difference in height is...
  13. Jan 12, 2023 at 5:40 PM
    #373
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I am currently running the core/hurst shifter for the third gen truck. It does make some noise. Other than that, it is firm and solid. No mush to it at all. I do wish that TRD made their own version for the third gen truck. I was extremely happy with my TRD shifter for the original transmission.
    Speaking of that, I’m tired of tripping over my original RA60F in the garage. If anyone here knows of someone who would be looking for one, please let them/me know. It’s got about 98K miles on it and works fine. No damage to the quill or anything like that.
    Rezkid and rheath08 like this.
  14. Jan 26, 2023 at 7:43 PM
    #374
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    finished the RC swap, I've already done about 15k miles on it.. There is a Vibration that's annoying since the install between 1700-2100 RPM, only when the driveline is loaded accelerating or decelerating, but gone if I float the gears.. Seems to be just 3rd, 4th & 5th..
    I did install a URD heavy flywheel.. is there a resonance vibe in that RPM range the engine and flywheel not balanced together? Bad Transmission? hate to put the factory flywheel back on but still the same.. It's tolerable but annoying, still worth the swap..
  15. Jan 26, 2023 at 10:56 PM
    #375
    BillDaCat8
    Jake
    PHX
    What’s the status of your carrier bearing and u-joints?
  16. Jan 28, 2023 at 7:18 AM
    #376
    hilux30
    PEI
    '15 4Dr SB 6MT
    zero Issues there, I checked them and greased them, the shop that cut it and balanced it said joints did not need replacing ... But I will take the Driveshaft off, drive in FWD see if anything changes.. and tripple check the joints/carrier..
    I did notice, that if I press the clutch, and RPMs dropped from say 3000 to 1500, that vibe is present as the revs go pass 2k or so..
    So it does it at times..
    Sometimes it doesn't vibe at all going through the gears... weird
  17. Feb 2, 2023 at 8:16 AM
    #377
    super g
    garrett
    north carolina
    Let us know what you find... am getting parts located and about ready to start this mod here very soon... am planning on replacing the 180k mile stock flywheel with the urd heavy as well. Would love to know if they're presenting with issues before dropping the money on one. Good luck isolating the cause.
    hilux30[QUOTED] likes this.
  18. Feb 3, 2023 at 8:43 AM
    #378
    hilux30
    PEI
    '15 4Dr SB 6MT
    I feel like the rubber is somewhat separated from the housing, or is than normal? pushing up you can see the rubber off the metal... Dealer part is $400 Canadian and month away, any recommendations on a good aftermarket?
  19. Feb 3, 2023 at 10:49 AM
    #379
    rheath08
    Russell
    Bakersfield, CA
    Any driveline shop can find parts. I have done that a couple of times. They can rebalance the shaft too. That will be a good thing to do.
  20. Feb 4, 2023 at 12:17 AM
    #380
    super g
    garrett
    north carolina
    He'll, you can get a brand new oem drive shaft including the carrier bearing from multiple toyota dealers for around 600.00!!!
