6 speed shenanigans. RA60F swap to RC62F
Discussion in 'Technical Chat' started by BillDaCat8, Jan 1, 2021.
  1. Jan 31, 2021 at 11:25 AM
    #121
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    That basic reverse switch design has been in use since the late 70's.
    I suspect this will be a common swap in the years to come.
    BillDaCat8[OP] likes this.
  2. Jan 31, 2021 at 6:04 PM
    #122
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I’m betting it will be.
    Currently I’m on the home stretch with this whole thing. I do have a couple of other things that need taking care of while the truck is up on stands. Primarily the cat on the LH manifold that needs replacing. I spent the bulk of my day futzing with that.
    VirusCage likes this.
  3. Feb 6, 2021 at 6:23 AM
    #123
    BillDaCat8
    Jake
    PHX
    Left hand catalytic converter is all replaced and welded up.
    Throwout bearing is completely installed and ready.
    Three bottles of gear lube on standby.
    Miscellaneous hardware and new exhaust gaskets acquired.
    I’m going to try to get this thing up and into the truck this weekend. Hopefully Sunday.
  4. Feb 6, 2021 at 7:11 AM
    #124
    Jowett
    Brian
    North Adams, MA
    There's a gear oil fill port on top of the transmission... allows easy fill and less mess as we can just wait for the oil to appear at the side fill/overflow. It's not easily accessible when the trans is installed.
  5. Feb 6, 2021 at 1:57 PM
    #125
    BillDaCat8
    Jake
    PHX
    That's handy. Thanks for pointing that out. I was planning to either dump it into the shifter hole or pump it from the side.
  6. Feb 6, 2021 at 3:48 PM
    #126
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    One thing you should do and this is coming from the fj case thread. Make sure the tcase input spline count and the transmission output spline count match up. The 2nd gen taco m/t tcase is 22 spline. The a/t is 23 spline.
    marlincrawler says the 3rd gen stuff is different. Just a heads up with all the talk about tcases in the FJ TCase thread and make sure you have everything correct.
  7. Feb 6, 2021 at 4:08 PM
    #127
    wrmathis
    Bonaire, GA
    parts and stuff
    Here’s what I’m talking about.
    We know that the ra60 is 22 spline. So I would make sure that the rc62f isn’t 19 spline like marlin keeps spouting. Especially if u go with A/T fj tcase or M/t awd fj tcase.
  8. Feb 6, 2021 at 4:26 PM
    #128
    Jowett
    Brian
    North Adams, MA
    They list it as 19 because several (should be 3, but I never counted) of the females splines on the transmission output do not exist. Toyota purposely omits them, leaving a path for oil flow into the center of the shaft. The 22 spline transfer input shaft slides right in.... always good to be careful, though.
    Jeff Lange likes this.
  9. Feb 7, 2021 at 9:31 AM
    #129
    BillDaCat8
    Jake
    PHX
    Like Brian says, spline count is skewed because of the three missing splines on the transmission side.
    RC62F output
    Transfer input
    They fit together no problem.
    For this round, I’m just putting the original transfer case back in behind the new trans.
    I do have dreams of the FJ’s M/T AWD case. But, that’s in the future.
    rheath08, Jeff Lange, samiam and 4 others like this.
  10. Feb 7, 2021 at 9:33 AM
    #130
    wrmathis
    Bonaire, GA
    parts and stuff
    and just like that, im glad someone finally has pics up for the third gen 6spd. should put alot of guess work and why cant i get a dang crawl box issues to rest
  11. Feb 7, 2021 at 9:39 AM
    #131
    BillDaCat8
    Jake
    PHX
    If you need more pics, let me know ASAP. This thing is going into the truck today.
  12. Feb 7, 2021 at 9:40 AM
    #132
    BillDaCat8
    Jake
    PHX
  13. Feb 7, 2021 at 10:12 AM
    #133
    wrmathis
    Bonaire, GA
    parts and stuff
    oh no, that should be fine. we know the bolt pattern is the same, its always have come down to output shaft spline people have questions about.
  14. Feb 7, 2021 at 11:21 AM
    #134
    6 gearT444E
    Deep South
    Herculiner Hootus
    is there even oil flowing that highs up at the input shaft? With seals on each end I did not even think oil was routed there
  15. Feb 7, 2021 at 11:35 AM
    #135
    Jowett
    Brian
    North Adams, MA
    There sure is... these trans have a really neat oil collection and distribution system.
    6 gearT444E likes this.
  16. Feb 7, 2021 at 11:36 AM
    #136
    6 gearT444E
    Deep South
    Herculiner Hootus
    thats good to know, thanks. Is the similar design on the oiling for the ra60f?
  17. Feb 7, 2021 at 12:37 PM
    #137
    Jowett
    Brian
    North Adams, MA
    Yes, same design.
  18. Feb 7, 2021 at 2:44 PM
    #138
    BillDaCat8
    Jake
    PHX
    Rolled it on under. Ended up pulling it back out and reversing the jack. I couldn’t get the angle I needed with it this way. I use an angle finder to set the angle of the trans to match the engine. Makes for a lot less futzing around when trying to stab a tranny.
    My progression trimming the hole in the floor to suit. I went slowly. It’s easy to remove material. Less so to replace it.
    I separated the rubber booties and reversed the lower/inner one. Here you can see roughly where it will now live.
    The floor editing continues. I rough cut a piece of sheet metal (stolen from the scrap of my bimmer project) and traced the opening I needed to close up onto that. Trimmed thusly 10mm larger and flanged it.
  19. Feb 7, 2021 at 2:46 PM
    #139
    BillDaCat8
    Jake
    PHX
    I will be using panel bond for this piece. Welding inside the truck would be an undertaking. Preventing spark damage and such. Panel bond is plenty strong. There’s really no big loads here.
    Here’s the body prepped as viewed from underneath.
    Upside down to show what it’ll look like from underneath.
    Test clamp. Ready for bonding.
    A quick console and boot check. Barely noticeable change.
  20. Feb 7, 2021 at 3:59 PM
    #140
    BillDaCat8
    Jake
    PHX
    Evidence
    3pooches, mav, Sociopenguin and 8 others like this.
