6-speed tranny problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tflorida, Oct 8, 2008.
  1. Oct 8, 2008 at 2:35 PM
    tflorida
    tflorida [OP] Member
    08 Sport SR5 Double Cab
    Hey all. I just bought an 08 tacoma. I only have 500 miles on it, but I have been having problem after problem. My current problem is that it shifts rough between 2nd and 3rd gear. All the other gears shift smoothly, but that shift catches, or makes a little crunch. I can hear it, and sometimes it jolts the truck a little. It doesn't help if its warm or cold, or if I pause between shifting. I took it to the dealer and they noticed it, but they said they don't have a fix for it, so they have to report it to Toyota and get instructions from them. Has anyone else had this problem? Or better yet, has anyone had this problem fixed? I'm afraid that toyota corporate will tell them that it is normal and no fix is necessary, or I'll just never get an answer.
  2. Oct 8, 2008 at 2:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not sure how much it will help, but what about changing the clutch fluid over to synthetic?? may'be that will help it out some.
  3. Oct 8, 2008 at 2:45 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I think that's just standard on these... My '09 has it too. It's supposed to go away once the tranny is broken in 5k miles or more.
  4. Oct 8, 2008 at 3:06 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    my 6speed shifts a little rough when cold but is smooth when warm. i think there's really a learning curve on driving these 6pseed manuals so thats probably most of if.... you just havent got the experience in how to best drive this tranny yet
  5. Oct 8, 2008 at 3:26 PM
    Yaberries
    Yaberries Well-Known Member
    SoCal
    Was 08 PreRunner Off-Road, Now 2015 TRD Off-Road Super White
    Front D-Rings, Blacked out grill & surround
    I've got almost 10K miles now and the shifting has been getting smoother as the miles go by. Its pretty nice now, when new it was catchy everywhere. I was worried about installing a short shifter, but now its fine even with the SS. 2nd to 3rd was the worst when it was new.
    As long as you have a record of the complaint with the dealer I think your covered if something goes really bad later...
  6. Oct 8, 2008 at 3:32 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    My first introductin to synthetics came as a result of me complaining years ago about hard shifting on my old Ford truck. The mechanic had some experience with Amsoil gear lube and suggested I change it over.
    I changed it to Amsoil, problem was immediately solved. Even tho it sounds like this might be a problem that gets better with time, you might consider synthetics as something that could help right away.
  7. Oct 8, 2008 at 4:05 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    Mine is rough from 1st to 2nd.... but now after aobut 1000 miles, it's really starting to smooth out. Give it some time, don't change the oil just yet. Break it in, then change to synthetic, that way you get all the metal shavings out.... I'll probably do mine at 10 k or so.
  8. Oct 8, 2008 at 4:11 PM
    billybobsgoat
    billybobsgoat Member of the Goat Army
    2020 TRD OR CCSB Graphite
    When I first got mine for about the first 1200 miles or so sometimes it wouldn't go into first from a stop i needed to put into second then it would go into first, But now I have about 2300 miles on it and that problem has gone away. I'm sure it is that your trans needs more miles put on it.
  9. Oct 8, 2008 at 4:54 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    does anyone use amsoil for auto transmission?
  10. Oct 8, 2008 at 5:54 PM
    Gerry Pope
    Gerry Pope Well-Known Member
    San Diego
    07 4X4 PreRunner
    Hi all,
    Mine has a similar problem.. I can shift through to 3rd smooth as silk when I first start off. As it warms up I get the ole, is this gonna grind feeling..
    I bought this 07 AC 4X4 Sport with 16K and it now has 17.5K... Was gonna have the dealer check it out when I go get the TSB for the springs done. Sounds like it may be but most likely not be an issue.. How is that for a firm Stance [​IMG]
  11. Oct 8, 2008 at 6:04 PM
    tflorida
    Gerry,
    Keep me posted on what the dealer tells you about yours. It bothers me a little that you are at 17k and still have the problem. It seems that you should be past break-in. You described it perfectly ... the "is it going to grind feeling".
  12. Oct 8, 2008 at 6:15 PM
    Gerry Pope
    San Diego
    07 4X4 PreRunner
    Tflorida,
    No sweat.. Will let you know..
    I was a little unsettled myself after hearing others tell of a break-in period. I am also aware of the learning curve with the taco 6-speed. I went from a 89 Nissan pickup that never gave me problems..
    That thing shifted sweet with 220k hard miles.. I can't imagine it would be an user issue. Will find out I suppose..
  13. Oct 8, 2008 at 6:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the new tacoma transmissions, they use a special "ws" oil from the dealer.....and im really not sure if anyone makes anything that matches it yet.
  14. Oct 8, 2008 at 6:34 PM
    hate2work
    Washington State
    06 standard cab
    Feeney, it all depends on which tranny you have. On my 06 standard cab with the 2.7 L I have the older, more typical type of auto trans with a dipstick that uses the type IV fluid. A few weeks ago I did a "drain and refill" of my fluid and I used the Amsoil Universal ATF, which is completely compatible with type IV. ( btw, it takes 4 quarts to do this, not the stated 2.3 in the OM )
    The ws oil ( world standard ) is used in the sealed auto trannies. It's supposed to be good for 100,000 miles or so. There is a way to drain and refill that type as well, but it's a little more difficult I think. The Amsoil ATF is not compatible with this type of fluid.
    The easiest way to find out which you have is to look and see if you have a dipstick for your tranny fluid. No dipstick, you have the ws type. If you have a dipstick, you have the more typical style that takes type IV fluid.
  15. Oct 8, 2008 at 6:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    guess i shoulda added v6 tacoma transmissions:rolleyes:
    i posted what i did because i already know what transmission he has.:)
  16. Oct 8, 2008 at 8:03 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    My '08 V6 6spd has 11,600 miles now. The clutch/tranny did break in a little but it still rough shifting. For me 1-2 is a bit rough, as in you can really feel it going in to gear, 2-3 goes in to gear fine but the problem is when you let the clutch out. As you've described, it can make a noise and jolt the truck. The 2-3 shift is also worse when the A/C is on. Also, when my truck is cold and I go to make the first 1-2 shift of the morning I will occasionally get a nasty noise and jolt when I push in the clutch. If I lived in the city and had to drive this truck in traffic, I would have sold it a long time ago. Toyota REALLY dropped the ball on the 6spd.
  17. Oct 9, 2008 at 5:55 AM
    DMagoo147
    DMagoo147 Well-Known Member
    Dan
    MA
    08 TRD OffRoad A/C
    CBI off road fab sliders with kickout, K&N performance air filter, BriteAssLED headlight bulbs, Delta Pro tool box, 20% window tints in front, 20% window tints added onto rear windows. Lou's Custom Exhaust: SS pipes and dual tip. LED backup lights. Prevent tailgate theft mod. Plastidip stock wheels, lower valence rear bumper and grill. bedside bottle opener. RAM-X phone mount. GTA car kits iphone/aux adapter.
    also have v6 6spd tranny, noticed rough shifting between 1-2 as well...not really noticing it as much now and am around 4300k miles.. definitally feel it in the cold though. I would conisder myself a good driver and i get the jolts everyonce in awhile when i let out the clutch a little to hard. still love it though, would be nicer if it was smoother. I would dread having to go into the city with this, when i first bought mine i had to drive if pretty far to get home and the last hour on the highway i got stuck in bumper to bumper traffic( i thought my legs were going to fall off i was working them so hard just trying to get used to the tranny).
  18. Oct 9, 2008 at 9:36 AM
    RelentlessFab
    Eric
    Sparks, NV
    my truck has almost 20,000 on it and the only roughness i get is sometimes down shifting from 2-1 and 6-5. my tranny is nice and smooth otherwise. im running synthetic in it since about 12,000.
  19. Oct 9, 2008 at 9:52 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Was a little notchy when new, but otherwise zero shifting/gear issues in 4 yrs. Swithced to syn at 20K, not that it really made much difference.
  20. Oct 9, 2008 at 10:59 AM
    papabear050
    Hey does ya'll tranny clunk sometimes when you press the clutch from a complete stop to shift to 1st...
    I have 4X4.... normal?
