6 Speed Trans Fluid Change?
Discussion in 'Technical Chat' started by oneshot808, Oct 9, 2010.
  1. Oct 9, 2010 at 8:22 PM
    oneshot808
    oneshot808 [OP] Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    Anyone got any tips or any pics to help me me out? I'm planning to do the spark plugs and trans fluid on the same day.
    Help or tips would be greatly appreciated be4 i mess up the change.
    All I know so far from reading all the other threads is that 1. you need to buy a fluid pump and its located passenger side near the exhaust. anyone got a pic?
  2. Oct 9, 2010 at 10:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Fill plug is on the driver side, about 4" up from the bottom. IIRC, its the only large plug on that side. Torque is 27 ft- lbs, and the tranny holds 1.9 quarts.
  3. Oct 10, 2010 at 1:57 PM
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    thanks for the input chris! :bowdown:
  4. Aug 15, 2013 at 10:36 AM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
