6 speeds, can we drop out interstate rpm's with differential gearing ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishaRnekEd, Jan 27, 2014.
  1. Jan 27, 2014 at 10:35 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    So I have a 2005 dbl cab, sr5, 4x4, 4.0L, 6speed.
    I have searched on here and found answers like "drive slower"
    but thats not really an answer. if thats your answer, then you are not helping the situation.
    If we change from 3.73 to maybe 3.55 or 3.42 wouldnt this keep our rpm's lower? Assuming that we run stock tire size, and dont need to tow anywhere the limit. The v6 has plenty of power.
    Seeing how all the gears in this 6speed are really low would this be the answer to high freeway rpm's?
    The problem is I can find plenty of info and parts to gear for larger tires, but what im asking is essentially backwards :confused:
  2. Jan 27, 2014 at 10:45 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Actually driving slower is an answer it just may not be for you. That being said, yes changing the gearing will lower RPM and it may improve MPG depending on the person doing the driving.
    If you do it let us know how much you gain or lose.
  3. Jan 27, 2014 at 10:49 AM
    FishaRnekEd
    New Orleans, LA
    ^ I know what you mean, but Keeping it under 55mph to save gas when the flow of traffic including tractor trailers is 80mph. Thats just a bad idea idea...
    My googling, has only led me to find more extreme ratio gears. Im wondering what to look for. anyone know of a brand or search words?
  4. Jan 27, 2014 at 10:52 AM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Larger diameter tires effectively changes the final drive ratio
  5. Jan 27, 2014 at 10:53 AM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    And increases rotating mass and unsprung weight. In most cases those factors outweigh any positive gain.
  6. Jan 27, 2014 at 10:54 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    big tires
  7. Jan 27, 2014 at 10:56 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Swap in a ring gear from a 5lug and you should be golden. I actually want to swap to 3.73's. Wanna trade? I got dibs on you sending me your stock ring gear first.
  8. Jan 27, 2014 at 10:57 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Yeah, swapping the rear gears is probably your only option. Like someone else said, putting on bigger tires will do much more harm than good.
  9. Jan 27, 2014 at 11:00 AM
    catsman50
    catsman50 Well-Known Member
    Jupiter, FL
    white prerunner 6speed
    Just add a 7th gear to the tranny and you'll be set! I've heard it's easiest to contact Harry potter for the work.....
  10. Jan 27, 2014 at 11:07 AM
    FishaRnekEd
    New Orleans, LA
    ^ no shlt thats what this search seems like... quarter of a million places want to put 4.10 but never heard of someone going the other way.
  11. Jan 27, 2014 at 11:10 AM
    FishaRnekEd
    New Orleans, LA
    I have never actually done the work myslef... Where is the write up on that LoL? What year 5lug? any year 4x4? what ratios do they have?
  12. Jan 27, 2014 at 11:11 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  13. Jan 27, 2014 at 11:15 AM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Just remember that changing your rear axle ratio will definitely drop your rpm at highway speeds, but it will also effect the performance at takeoff and when going uphill. I think having a standard will be a benefit if you do it.
  14. Jan 27, 2014 at 11:19 AM
    FishaRnekEd
    New Orleans, LA
    1st gear is so low on this thing, I didnt even need to use it with a motorcycle and generator in the bed. 2nd gear take offs are almost where 1st gear should be for street use.
  15. Jan 27, 2014 at 11:20 AM
    BKill
    Bill
    College Station, TX
    Sounds like new gears might be just the thing for you.
  16. Jan 27, 2014 at 11:23 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Here is a link on the axles, I believe X runners are @ 3.15ish, I think bases are around 3.30's, and then 6lugs are at 3.73.
    http://home.4x4wire.com/erik/diffs/
  17. Jan 27, 2014 at 11:23 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Changing the gearing can lower the RPMs but depending on what speed you want to cruise at, you might lower the RPMs to where you are out of the best efficiency part of the torque curve and actually use more gas. Too many variables (tire size, desired speed, differential gear ratio, transmission gear ratio, mods that add weight to your truck, fuel quality, aerodynamics, etc....) to be certain of what is going to be the best solution for your fuel consumption goals.
  18. Jan 27, 2014 at 11:34 AM
    FishaRnekEd
    New Orleans, LA
    back to google...
  19. Jan 27, 2014 at 11:35 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Dont put it in 4x4
  20. Jan 27, 2014 at 11:56 AM
    FishaRnekEd
    New Orleans, LA
    Ya, looks like i cant find anything for the front diff. Im sure there is a setup out ther from something.
    All the shops here are quick to say "no, nothing would work"
    guess they dont know what they are doing down here. I might have to call back home to Cali and talk to an expert.
