6" to long travel
Discussion in 'Suspension' started by PLC721, Jan 6, 2011.
  1. Jan 6, 2011 at 9:17 AM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    is it remotely practical to remove my 6" procomp lift, weld the crossmember back in and go long travel?
    or should i build up the rear supension and settle with that set up?
  2. Jan 6, 2011 at 9:27 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Definitely worth it if you wheel. You'll have a lot of other welding to do it you go full long travel with bypass shocks so putting that cross member back in is a cakewalk.
  3. Jan 6, 2011 at 9:51 AM
    PLC721
    Patrick
    Chandler, Az
    i'm not thinking full caged long travel and what not, just like all pro or something up front and a decent set up in the rear
  4. Jan 6, 2011 at 10:02 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    it wont be that hard at all to put it.
    I kept my cross member just in case, I would just brace it around the joinys when you put it back, but that member is only in compression so it doesnt see that much load under normaly conditions. but if you are jumping it ( which I assume is a possibility with you going LT) I would brace it.
    Justin
  5. Jan 6, 2011 at 11:31 AM
    PLC721
    Patrick
    Chandler, Az
    yeah i'm just debating cloning your rear set up and then calling it done for my truck, or go lt. but i do want to keep it good for camping and hauling and stuff like that.
  6. Jan 6, 2011 at 11:36 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Putting a new one in wouldn't be all that hard. I say it takes longer for us to rebuild your CVs then welding a new crossmember in
  7. Mar 29, 2015 at 12:33 PM
    tacomaboyd
    tacomaboyd Member
    Brandon
    Northern alberta
    14 taco 6"fabtech
    6" fabtech, 17 x8.5 Fuel trophy rims, 35x 12.5 nitto trail grapplers, magnaflow catback
    Hey how did you make out with this? Im very interested in switching from my drop bracket kit to long travel or at least findingsome solution to get more travel on the front
