6' x 10' utility trailer build.
Discussion in 'Garage / Workshop' started by koditten, Mar 17, 2020.
  1. Mar 21, 2020 at 7:47 AM
    koditten
    koditten [OP] Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    h0R8DzNLxpQbIUluTiJe1zlJ8FU8eGhTvz5ZXB_M_45b9c390524686543ecafafbf1dbf84896fc3040.jpg Working on getting the corner uprights plumb. Once these are tacked in solid, I'll attach the top rail.
    It should be mentioned that I welded the top side of all the cross members before I work on the uprights.
    PzTank likes this.
  2. Mar 21, 2020 at 7:50 AM
    koditten
    Kirk
    Central Michigan
    Tossing op the front top rail. I gave the supplier the wrong size or the piece was cat the wrong length. It only slows me up a little, but it does annoy me.8gk2HSYuX7pS1BluocVPGxFRkrnC4R55U0yr9lD1_bcfb4605a19d01a25fc2800c943a47908375e03a.jpg
    PzTank likes this.
  3. Mar 21, 2020 at 7:51 AM
    koditten
    Kirk
    Central Michigan
    uIAEjCAMBZ_RuYYm9OMQfKGXYSAN_sEzL3ZgOMZO_6a0e70d1f67c08e39e56c2aba31e81660e17e5ac.jpg 12f4tCB40-jVDKXBXHhNLK_AxRTAYfl0CURqraX8_096729b0b773a63eb3fd96fcdc576bf723bb35d1.jpg
    Using my fabrication square to hold the upright in position so it remains plumb. These things work awesome!
    PzTank and tacoma16 like this.
  4. Mar 21, 2020 at 8:02 AM
    koditten
    Kirk
    Central Michigan
    4lJ-frdaMlzv050p_TQWI2yUuyz4L0LA0q5b9_ji_ff5ba4b635a82266b1014f9d842c60d236c56166.jpg
    It's looking like a trailer frame. I've moved along pretty fast. I can usually do the uprights, fenders and top rail in less than an hour. It is quite a bit of welding and you can tell by the amount of smoke in the air. The haze is not a dirty camera lense.
    Backing up a bit: Attaching the fenders is pretty straightforward. No rocket science here. All I do is sit on my roll around stool, support the fender with my hand between the tire and the underside of the fender. My hand is in a fist shape and I can eyeball it so the fender is level and rock my fist left or right to do this. I put a heavy tack on one side of the fender where it touches the frame. Still supporting the fender with my fist, I put a tack on the front of the fender where it meets the frame.
    Please ask If you would like more details.
  5. Mar 21, 2020 at 8:05 AM
    koditten
    Kirk
    Central Michigan
    iSNKWluga5-TnDh6fjxYBxazkbtEelj7T7yaeEMN_ed45deebda7f7bf3230374220647d985bfe4b5cc.jpg 9L8YLSB7t_ChtV6TZGNmnGUesfU8xsjpGtZ4_uW1_6defd942b94e93467ab5da069a077eb5dac5a9ba.jpg C-KwyewR7L831y7tCJF9chRGDgYlLLxrRWAh1U4J_298058a6a070e8223e0b89246801acc2ead12686.jpg AnOmHBp7v6vShhqlLPOmsyP9NfdWYj1P0X_jUhgt_ccd895cccc8604c75f90a34249556b8bde913167.jpg
    Boxes for the tail lights. I build these to stay built.
  6. Mar 21, 2020 at 8:08 AM
    koditten
    Kirk
    Central Michigan
    YEPMLVsanmbSuR9al3dxincndoqmfzTnGNLrZaCz_7919e0baeb48d0dfe7c14a104da9d91af6705031.jpg
    Tail light box and light attached. I had a previous customer thank me for building these boxes like I do. He slid his truck into the ditch while towing his trailer. His buddy attached his tow strap to the light box and pulled both truck and trailer out of the ditch. I wish I had a pic of that.
    PzTank and 0xDEADBEEF like this.
  7. Mar 21, 2020 at 8:12 AM
    koditten
    Kirk
    Central Michigan
    ILBhIcVMJ-5aZQbmiIPdmi8MZ3dO2YGc7z4IUR-v_5b7c353042db1ac8cff9b717fbc86621ee78cbf6.jpg XLwnLFfIsjjEiWpkE8gSAqvLuQMzBDiUqQ1EpJ7D_c3a716df430b306a2b43a4ec5c0f3a29018dde93.jpg 1EayiagCMKUFKBhR69dSH7ZzxwSlsS1if7yYvawo_94df351428ccc8084472721a91e8b7df79513d62.jpg
    I make my own bed tie downs. Just some excess sched. 40 pipe slices cut in half. I put this in the 4 corners as well as 1 on each side in the middle. I like things to stay put.
    tacoma16 likes this.
  8. Mar 21, 2020 at 8:15 AM
    koditten
    Kirk
    Central Michigan
    4C96s20nBpymx-LQAdm4tLAWPI9Pp6kzz6sZd9iD_bb4b285b6aa79f6b3ad155bdef5c5aff293802e3.jpg
    Dammit! This one is on them! I have never ordered expanded steel this narrow! I was pretty pissed, because this shut me down for the day as it was too late to ran after another sheet.
    Regardless, I did get the trailer ramp gate frame built, just couldn't attach the mesh iron.
    PzTank likes this.
  9. Mar 21, 2020 at 8:18 AM
    koditten
    Kirk
    Central Michigan
    QXCyftCOFOxu4BVJQJuO3qUYIuPOF-tWLYpnCSSW_029a4c070647bc9d8b2015fdaa4cce2aec57c143.jpg
    Next day:
    I got the proper size mesh placed inside the tail gate frame. You can see my mesh supports are not welded yet. Ill do that after I flip it over.
    PzTank likes this.
  10. Mar 21, 2020 at 8:20 AM
    koditten
    Kirk
    Central Michigan
    1jApB97JBtUeTT21WPdD8ne7wWZs4pUfRSyEUDdL_807b845c23891fe0020a6b11a125a6972c011b58.jpg
    Gate attached to the trailer. I make my own hinges. I just use scrap 1.5" x 1.5" angle with a 1/2" hole drilled in both. I blot them back to back and this becomes a strong, cheap hinge.
    PzTank likes this.
  11. Mar 21, 2020 at 8:22 AM
    koditten
    Kirk
    Central Michigan
    vQUAZF1ruuDsgkhzfuophqQpsRxNhHPGfqXVF8jw_de45b6bdef3e8e1f2abc6e4f3ddaa2486ec9cfb7.jpg
    Trailer tail gate latches being fabbed up.
  12. Mar 21, 2020 at 8:23 AM
    koditten
    Kirk
    Central Michigan
    jlSPKjQtOrD9NGGUXqViqRBWZDW2q-GOEfbV512b_34dd3a80044cca972f1a8826a9064b004c64a6e8.jpg
    Test fitting the latch pieces. It's just some scrap 2" band iron.
    PzTank likes this.
  13. Mar 21, 2020 at 8:24 AM
    koditten
    Kirk
    Central Michigan
    IS8R1tebFzKv2eNSQLnXG6twmrIpufyQQIDj9h1V_aaf590bc4eeba2d422a364b80eceba3b4d122ba6.jpg
    Latches installed and cleaned up with the flap wheel.
  14. Mar 21, 2020 at 8:27 AM
    koditten
    Kirk
    Central Michigan
    xepdr9fO8WPl3uu9c6FvjdBBxnkMdw1VamFTpAyY_ce3360503e7c468416304d0b4c1c9bd8e32a3412.jpg
    At this point, I have concluded all welding activities.
    You are looking at 4 hours and 4 beers to get to this point...as long as all parts are cut to the correct size. This was a 2 day project because of the wrong expanded steel.
    PzTank likes this.
  15. Mar 21, 2020 at 8:28 AM
    #35
    koditten
    Kirk
    Central Michigan
    r2jNUJMQ_affvEvmdhXPhxogw2EqnR7HMMJSOm7R_3a0e91ff311184a93eb76a9ef51b8d8006fd40f8.jpg
    Washing the trailer down to remove the mill oils. It's fun playing with the foam cannon.
    PzTank likes this.
  16. Mar 21, 2020 at 8:29 AM
    #36
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
  17. Mar 21, 2020 at 8:30 AM
    #37
    koditten
    Kirk
    Central Michigan
    I wheeled the trailer inside to dry. I got it on the hoist to make wiring the lights much enjoyable.
    I hope to never lay on the floor again if I can help it.Qk99PpwMwm00TfG0MuPENshAAz2OMoRk5gWryjEd_ef353b2224131fe1ff0ee734b0c2b792652998f1.jpg
    tacoma16, PzTank and 0xDEADBEEF like this.
  18. Mar 21, 2020 at 8:33 AM
    #38
    koditten
    Kirk
    Central Michigan
    wI18lBfEC6sZm8Ux7FQw8RuCp49WjTWW5E3MgM61_f6e7425b93643b8a64ebd3986c858a367a80eede.jpg
    Trailer painted. I use the Harbor Freight truck bed paint and roll it on. It goes on thick and seems to hold up very well. In addition, the extra paint left in the can does not harden up. You can do touch up painting for a long time.
    Be warned, the stuff does smell. I have to leave the doors open or I get a bad head ache.
  19. Mar 21, 2020 at 8:35 AM
    #39
    koditten
    Kirk
    Central Michigan
    XN29WBPA5bptMmsaEFkwEnXVjAEiDmOYR1VAGHOI_6d3ce592b41d041c3a20efb8ae42c8b02c599c60.jpg
    Trailer sides and floor lumber. Preparing to cut them all to size.
  20. Mar 21, 2020 at 8:37 AM
    #40
    koditten
    Kirk
    Central Michigan
    c3F3GO0kFrywTIibLQ-tSabgDwK4atWGfJBEj2Tw_6fa2350d3b8d828e4bb3931b348506f4283f475b.jpg
    Deck boards installed. I'm using the bar clamp to suck the boards together. There will still be gaps in the floor after they dry.
    PzTank likes this.
