60,000 Mile Service Cost!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ConantTaco, Aug 21, 2025.
  1. Aug 22, 2025 at 3:30 PM
    #61
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    BLUF: I paid the shop I go to $1340 for the 60K service -
    I know the guy and he let's me in the shop while he's working on my truck and shows me what he is doing. Anyway Definitely the spark plugs and all the fluids - diffs, x-fer, trans, break, (oil, filters I did myself) and check everything. That's the major stuff I can think of. Also rotated the tires (I am not good at doing that like I should) and did an alignment (I just felt I go off road a lot and pretty sure I probably knock it out of alignment on the rocks). He also re-torqued the U-bolts for me and took off the skid plates all the way back and cleaned them up and put them back on. He found what was causing the clunking noise that was driving me nuts (a hitch pin got under the cargo bin that is under the back seat) and replaced the the missing and mismatched screws holding on the licence plate.
  2. Aug 22, 2025 at 3:32 PM
    #62
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    $65 of that $2,970.69 is probably a cabin air filter change and them inspecting the floor mats xD
    Speedbird, kahanabob and Black97v6MT like this.
  3. Aug 22, 2025 at 3:34 PM
    #63
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    …. Don’t buy a Lexus any time soon.. at op:rofl::rofl::rofl:
    shakerhood and b_r_o like this.
  4. Aug 22, 2025 at 3:54 PM
    #64
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    You will never know how easy these things are to do if all you can do is doubt you can do them. The most difficult part of replacing the inside air filter is cleaning out your glove box. You can Youtube almost anything and see what it takes... and just do one at a time or schedule a day and do the ones that are important. You'll get some satisfaction just by realizing that you've done something you feared... and for little reason. The worst thing amateurs do is over tighten things. Snug is good enough in most maintenance and you can find torque specs easy enough if you're worried.
  5. Aug 22, 2025 at 6:53 PM
    #65
    Okiedokie59
    Okiedokie59 Well-Known Member
    As with teaching children, any and every task complete is knowledge ability power and confidence.
    Give a man a fish , he eats for a day.
    Teach a man to fish, he eats for life.
  6. Aug 22, 2025 at 7:54 PM
    #66
    Tacosauro
    Tacosauro Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
  7. Aug 23, 2025 at 6:26 AM
    #67
    Williston
    Williston Non Spring-Chicken Member
    2014 Tacoma DC 4x4 V6 040 [SL] SR5 4x4 [ED] Entune Audio Plus [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Gentex Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter)
    Maybe a previous owner did an engine swap?
    Check around under the hood and look for any stickers, badges, enameled emblems or castings on the engine that say:
    "Ferrari". :D :proposetoast:
    Speedbird and Travlr like this.
  8. Aug 23, 2025 at 7:55 AM
    #68
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    After you purchase a new vehicle there's no reason other than warranty work to ever return to the dealer. Quoted me over $1200 if I remember correctly to do diffs and transfer case fluids. I would not be surprised if they charged me and never even did the work anyway. I only called them to see how much money I just saved doing it myself. Under $200 for the diffs. T/C I'm doing at 50k. I despise car dealerships. Criminals imo.
    Travlr and Okiedokie59 like this.
  9. Aug 23, 2025 at 8:21 AM
    #69
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
    That looks like a Bay Area, California price. Everything is overpriced here. I use an independent mechanic that charges about half what the dealer does.
  10. Aug 23, 2025 at 8:22 AM
    #70
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    At the end of the day, many (but certainly not all) dealer service departments make a lot of money off the uninitiated. I think calling this approach "criminal" is a bit harsh, but they definitely have no issue recommending stuff to people that are plausible needs at best.
  11. Aug 23, 2025 at 9:33 AM
    #71
    Okiedokie59
    Righty tighty lefty loosey.
  12. Aug 23, 2025 at 9:33 AM
    #72
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The most expensive part of any stealership service is the floor mat inspection.
  13. Aug 23, 2025 at 9:34 AM
    #73
    Okiedokie59
    BOHICA.
  14. Aug 23, 2025 at 11:56 AM
    #74
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    I kind of agree with you. I started my military career as a helicopter mechanic so it's not like I don't know my way around a tool box so to speak. And I have done lots of that stuff myself with the exception of welding (I did a couple of practice/learning exercises and really stink at it). I also get the part not trusting the dealer - no way in hell i'm taking my truck to the dealer. I do trust the shop I go to though because I can see the work getting done. But the big thing for me is time and convenience vs $$$$.
    Start with I don't have a lift - not a big deal for say an oil change or when I did the U-Bolt flip and changing cabin and engine filters is stupid easy, but the diffs xfer case, breaks I have done on an individual basis. Never the transmission, (which btw I guess I could do but it seems a little more tricky than just drain and refill - and yes I have seen the YouTube how to). Then there is changing the spark plugs (which is nothing like it was back in the day) - I just do not feel like spending half the day crawling around under the truck . Same with the power steering flush (I have done remove and replace little by little but that takes too long) and the shop has stuff to do it much faster.
    So yeah I did pay $1340 for the 60K but added a few things like an alignment, pulling all the skid plates and cleaning them up find a rattle and a few other things so probably more like $1100 or $1200 maybe even less. Strip out what all the fluids and a few parts cost and what we are talking ~$500 in labor? Some of that labor cost is stuff I can't or don't feel comfortable doing myself (spark plugs - transmission). The rest is going for stuff that just made my life a lot easier and going to a good guy who I trust - so I am OK with it.
    Travlr[QUOTED] and Williston like this.
  15. Aug 23, 2025 at 1:04 PM
    #75
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Not just California. It's the way of the world now...
    wishing you all good tidings of corruption and greed
  16. Aug 23, 2025 at 2:40 PM
    #76
    eaglehawaii
    eaglehawaii Well-Known Member
    Hawaii
    22 Super White.. ... 18 Magnetic Gray ... 02 Gold RIP in 25
    Getting ready for the 60K service for my 2018.
    I actually just did the oil change on our RX350. Pretty much the same procedure. Easy and straightforward provided you have the basic tools.
    What made it even easier are the following:
    • Rhino Ramps
    • Oil Drain Container
    • Drain valve tool
    I also installed the Fumoto Valve so that it would be even easier and less messy the next time.
    Speaking of less messy ... I covered the pan area of the drain container with aluminum foil. Punched a hole for the drain hole. Opening up the vent on the top side seems to help speed up the oil drain into the container.
    After the oil change, I folded up the foil along with the old filter, washer and O-rings and disposed of them.
    Minimal clean-up on the drain container with shop/cleaning towels.
    Will likely do the Taco in the next couple of weeks.
    P.S., I had to use a 3 foot pole to act as a breaker bar to help release the round metal disc and the filter housing itself. They were definitely overtorqued by the dealership.
  17. Aug 24, 2025 at 8:49 AM
    #77
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    Hope that came with a happy ending
  18. Aug 24, 2025 at 9:27 AM
    #78
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    It's the really hard items like "Inspect proper installation of drivers floor mat" and "Change cabin air filter"where you need the dealer and they know it :cookiemonster:
    (Anecdote: few months ago I was at the dealer getting state inspection and road-force balancing; poor guy in the waiting room was getting quoted ~$1,000 for freaking brakes for a Corolla :eek:. I could hear the guy giving him the safety speech... The guy concedes he will take pads on the front only for a few hundred. After the 3rd rejection the advisor say ok, but "You will be back in a few months and it will cost you even more and you will be placing safety at risk". What a cock; but he was obviously trained to do this.)
  19. Aug 24, 2025 at 1:07 PM
    #79
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    So much depends on how much and how you use your truck. I was talking to a guy the other day about his 2016 Taco that still has less than 50K on it and never takes it off the pavement and it is bone stock compared to my 2022 that has tires and suspension it was not really designed for and has gone over 60K not to mention gets beat to crap off road does lots of stop and go local driving mixed with a couple of long Interstate drive a month. I bet that guy with the 2016 could go 100K and never do any of the 60K diff x-mission etc. fluid changes spark plus etc. and as long as he was just doing the recommended 10K oil changes his truck will be in much better shape than mine at 100K and I'm doing all the scheduled maintenance plus changing the oil every 5K.
  20. Aug 24, 2025 at 1:22 PM
    #80
    ConantTaco
    ConantTaco [OP] Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Sorry I didn't post all of the details.
    Basically all fluids changed, Spark Plugs changed. Drive line bolts torqued, Battery Terminals cleaned, various filters changed. That's most all of anything significant.
