60" Hi-Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TeamLombardo, Sep 24, 2012.
  1. Sep 29, 2012 at 6:57 AM
    #41
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I topped out my 48" last night by myself stuck in a trail. And I don't listen to that 75% BS. I literally had it one hole away from coming off. Made me work much harder to get myself out.
    IMHO a 48" jack should never be purchased if you plan on going offroad.
  2. Sep 29, 2012 at 8:02 AM
    #42
    TeamLombardo
    TeamLombardo [OP] WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Yeah I have pretty much made up my mind to go with the 60". Concensus is 60" and it fits if you remove attachments, which I don't mind doing. Only thing that sucks is that the damn ATO mounts are more $$ than the hi-lift itself. That's kinda sad.
  3. Oct 15, 2012 at 8:44 AM
    #43
    IslandBoy86
    IslandBoy86 Well-Known Member
    Las Vegas, NV
    Anyone know if the hi-lift jack will work if I have the OEM side steps?
  4. Oct 15, 2012 at 11:20 AM
    #44
    BradyT88
    BradyT88 Well-Known Member
    Yeah the oem side steps bolt to the body so there is probably a chance (due to leverage) that you will actually do more body damage lifting from them than just lifting from the body itself. Plus I am not so sure they are up for holding the weight of the pickup, just people.
  5. Oct 15, 2012 at 11:22 AM
    #45
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Yes, just barely
  6. Oct 15, 2012 at 5:33 PM
    #46
    TeamLombardo
    Tony
    El Paso
    What is it mounted with?
  7. Oct 16, 2012 at 11:26 AM
    #47
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    x2:confused:
  8. Oct 16, 2012 at 12:01 PM
    #48
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    set of aluminum mounts. they have a bolt and wingnut to hold the jack, and probably two bolts on the the bottom of each mount going through the wheel well. looks homemade? hack saw, dril, and thread taps and you could easily make a set yourself.
  9. Oct 29, 2012 at 2:58 PM
    #49
    SoCaltaco65
    Home made Stand offs bolted to the well top
