60+ mph vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jaren1512, Sep 10, 2012.
  1. Sep 10, 2012 at 3:42 PM
    Jaren1512
    Jaren1512 [OP] Well-Known Member
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    Deck plate mod, all chrome plasti dipped, 32" BFGs, fogs, 3" bilstein coilover 5100s/5150s in the rear, manaflow exhaust, smoked tail lights, rooftop lightbar, upgraded alpine sound.
    So I have a 98 sr5 4x4 with a 3" suspension lift. I got a diff drop put on but Im still getting a weird vibration when Im on the freeway or any time over 60 mph. I feel it in the wheel, on the pedal, and in the cab itself.
    Its nothing crazy. I mean I dont think its causing any major problems or anything. Im just wondering if it is something I should be worried about or is this just a yota problem.
    THANKS!
  2. Sep 10, 2012 at 5:00 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    not sure if the 98 has a CB? but you might look into this and get a drop bracket
  3. Sep 10, 2012 at 6:09 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Also, you may not need a carrier bearing drop bracket too. I got the smallest bracket offered, and it didnt help. I resorted to adding washers until it stopped.
    Just check your U joints, lube it and see how it is. If it continues, try washers first
    Edit: have you had an alignment done?
  4. Sep 10, 2012 at 6:10 PM
    rysully
    rysully Active Member
    Gainesville
    04 SR5 4WD
    Check and make sure your wheels are properly balanced. Whens the last time you rotated or balanced them?
  5. Sep 10, 2012 at 8:43 PM
    Wild Card
    Wild Card Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    Yup, wheels being out of balance was also my first thought.
    As the tread goes down, those weights on the wheels that were previously counterbalancing the not-perfectly-symmetrical weight of the wheel rubber tend to start throwing off the wheel balance themselves, when all of that rubber they were balancing out disappears....
    Easy to bring it to a shop and have them re-balance your wheels. Won't cost much, and you can rule that out later.
    Where do you feel it? Up front, or rear? Any sides?
  6. Sep 10, 2012 at 8:53 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    do you drive in mud/dust? have you washed out you inner wheels lately if so?
  7. Sep 10, 2012 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A lot of good suggestions so far. Too much axle angle can cause such a vibration.
    What gave you 3" of lift? Toytec Eibach coils? Where is the purch/coil bucket set on your 5100s? Lowest setting?
    Got any pics of your front axles?
  8. Sep 11, 2012 at 1:11 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    I got 5100s frOnt and 5150s rear. I think I'll start by getting everything realigned and balanced and see if that helps. Then I'll move on to the cb. Have we confirmed that I do in fact have a cb?
  9. Sep 12, 2012 at 2:45 PM
    TACO3
    TACO3 Deer Dropper
    Aaron
    VA
    03 tacoma 4wd 4 banger
    Mine did the same thing. i also have a 3 inch lift and 60+ it was just an annoying vibration/ shake.. im going tomorrow to get balance an alignment. keep us posted
  10. Sep 14, 2012 at 9:47 AM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    How'd it go?
