60 vs 65 series...price difference?
Discussion in 'Wheels & Tires' started by black cx, Jan 20, 2020.
  1. Jan 20, 2020 at 6:51 PM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
  2. Jan 22, 2020 at 8:23 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
  3. Jan 22, 2020 at 4:35 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Not the same tire. The LT285/65r/18 is a taller tire vs the 285/60/18 and might be E rated vs C rated. Post up all the details showing the full tire size, rating, etc.
  4. Jan 22, 2020 at 7:30 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
  5. Jan 22, 2020 at 7:54 PM
    JL8Jeff
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    C load rating is a 6 ply tire and the E load rating is 10 ply. So the E rated tires are heavier and less prone to damage on trails. They cost more as well. If you're just looking for street tires, go with the C rated tires. The LT 285/65R18 is an E rated tire.
    From Nitto's website, both the LT tires are E rated. The 265/65 is 1" taller than the 265/60 tires.
    Tire Size Rating Stock Number Tread Depth Diameter Width Approved Rim (Measuring Rim) Width (In.) Load Press Weight
    LT285/60R18 E 122/119S 215310 15.6 31.46 11.50 8.0-(8.5)-10.0 3305/3000 @ 80 52.95
    285/60R18 120S XL 215050 13.6 31.46 11.50 8.0-(8.5)-10.0 3086 @ 50 49.30
    LT285/65R18 E 125/122R 215130 17.5 32.56 11.50 8.0-(8.5)-10.0 3640/3305 @ 80 55.69
