$60 wheel spacers found online
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfInferno, Jan 18, 2011.
  1. Jan 18, 2011 at 9:04 PM
    SurfInferno
    SurfInferno [OP] Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
  2. Jan 18, 2011 at 9:06 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    PP has some good shit. Damn thats a great deal!
  3. Jan 18, 2011 at 9:09 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    THose will be fine. There isn't much science to a wheel spacer. I have a set like that on my truck.
  4. Jan 21, 2011 at 6:39 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    im thinking im going to buy these, is there anyone out there thinking i shouldnt?
  5. Jan 21, 2011 at 6:51 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    im iffy on spacers for a DD.i have the fear of them cracking and my wheel falling off. i never heard of it happening but its still a fear.
  6. Jan 21, 2011 at 6:53 AM
    97yota4wd
    Eric
    Mesa, AZ
    you think thats possible?? has this ever happened to anyone?
  7. Jan 21, 2011 at 6:54 AM
    paintdiddy
    shithead
    silver bullet
    i assume its possible with cheaper ones made out of poop.maybe hardcore offroading could break/crack a spacer
  8. Jan 21, 2011 at 6:56 AM
    97yota4wd
    Eric
    Mesa, AZ
    so i should probably go with steel? are these ones cheeply made?
  9. Jan 21, 2011 at 7:08 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Those are not hub centric
  10. Jan 21, 2011 at 7:14 AM
    97yota4wd
    Eric
    Mesa, AZ
    whats that mean?
  11. Jan 21, 2011 at 9:34 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    running spacers is fine, just make sure you use loctite and check them regularly. hubcentric spacers make them less prone to vibration. I have non hubcentric spacers for the past 3 years in the rear, no problems.
  12. Jan 21, 2011 at 9:35 AM
    amaes
    Alex
    Chandler, AZ
    2011 FJ Built
    THe main reason one would break is it wasn't installed correctly. Meaning they over torqued it and they didn't tighten it down in a star pattern just like you do when changing a tire. Also it isn't the spacer that cracks its the studs on the spacer.
    Also for it not be hub centric as long as you know how to change a tire properly it isn't an issue.
    Eric you will be fine with these.
