60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Sep 30, 2020 at 11:55 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Are you sure it's the pressure tank? If the pump is pumping, you should have some water.. maybe not full pressure. Could be the pump control box, if no water. Relay, starting capacitor inside go bad. A new control box is a fairly fast, cheap easy fix, just to see. If not, you have a spare for when it does. I keep a new one handy. Mine failed on a Sat. night years ago. Drove 60 miles on a Sun. morning, hoping Menards had one for a 1/2hp submersible, they did, but only one! Got lucky.. now I keep a spare. There are cheaper ones, but this is the one I keep on hand. Made in USA.
    https://www.amazon.com/gp/product/B00T3T5GUS/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
    If you're replacing the one above with the same one, turn off the well circuit, one screw removes the block (capacitor and relay), plug in the block from the new one, install the screw, turn well breaker back on, done. :thumbsup:
    johneman[OP] likes this.
  2. Sep 30, 2020 at 1:43 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Having worked with water systems for almost 50 years, I have one suggestion. If you aren’t well in versed pumps and controls. Hire someone who is.
    I can think at least a dozen causes with just the flimsy info given. That and knowing that most often clients are wrong in their diagnosis would prevent me from making a determination of cause. And it could be more than one problem or it may even be the start of a cascade failure event.
  3. Sep 30, 2020 at 1:57 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Afternoon all:
    Beautiful fall colors Mark, not much color down here yet.
  4. Sep 30, 2020 at 2:51 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The pictures are great Mark, absolutely beautiful. The fall colors are one of the many things my wife misses about her home state of Pennsylvania. (She doesn’t miss the winters though, she’s not a snow and ice gal)
  5. Sep 30, 2020 at 4:02 PM
    MtnAltitude
    MtnAltitude AKA: Grump-a-saurus
    Colorado Mtns
    2020 Tacoma TRD Pro AG, 1971 FJ40 - all MT
    It ended up being the control box after all. Thankfully I did shut off the pump so it would not run when the boiler was calling for heat. Everything is back up and running. I did have water before the tank so I was able to narrow down it either being the tank bladder failing or the control panel.
    06Tacooo[QUOTED] likes this.
  6. Sep 30, 2020 at 4:05 PM
    MtnAltitude
    Colorado Mtns
    Beautiful colors and beautiful property - our fall color is not the same here. Only the aspen change and that is to a yellow/orange color - still pretty but just not the same.
  7. Oct 1, 2020 at 3:09 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    Great news! Gotta have water, heat. My pressure tank has been on the fritz a couple weeks, I'm on the list waiting for a new tank. Still have water and pressure, but can't set correct air pressure in the bladder. I drain the tank, check/set pressure once a month.. noticed it will only take 27lb., should be 38lb. Bladder is waterlogged. They are replaceable, but these days it's more work than these old bones want to do. Something this important, I'll just replace the tank. The old tank is original, 30 years old, and it's a big tank.
    I have a good well guy finally. They're scarce around here these days, with the city expanding water lines, not much call for a driller anymore. This father-son team should hopefully be around when we need. Regardless, I'll learn everything I can about wells, controls.. even helping install this one when we built. OJT :thumbsup:
    New tank is in, operating perfect. Happy camper!
    MtnAltitude[QUOTED] and 95SLE like this.
  8. Oct 1, 2020 at 3:42 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Hope the problem gets resolved quickly.
  9. Oct 1, 2020 at 5:51 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I want to know how this jerk got picked for this gig. I would have preferred anyone else but this Marooon.
    pudge and johneman[OP] like this.
  10. Oct 1, 2020 at 6:12 AM
    MtnAltitude
    Colorado Mtns
    Our well pump and tank are only 19 years old but we have so much sediment (decomposed granite) that the normal life span is not realized here. We have three well diggers in the area - the one I use is hard to get but they are the best in this area. They were able to get the tank back to 38psi and everything seems to running well (pun intended LOL). I agree, these days the replacement bladder and time it takes to mess with is not worth it as the cost of these tanks have come down over the years - at least here.
    Have a great day everyone.
  11. Oct 1, 2020 at 6:52 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I would like to see Media as the moderator for the next debate.
  12. Oct 1, 2020 at 7:08 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    yes they are, beautiful country, would love to be able to go deer hunting with that kind of background too look at.
  13. Oct 1, 2020 at 12:21 PM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    I guess we're lucky, all we have is some red iron, which I filter out with 2 standard 10" 1 micron filters per month. I also installed a sealing type cap on the well to keep bacteria to a minimum, and I add 2oz. of bleach to the 250gal. of standing water in the well once a month. Percentage wise, it's a very small amount.. 00625%. If you ever add bleach, be aware most water softeners can only handle up to 2% chlorine, municipal water is around 2%. I have the county test it yearly for bacteria, so far so good. :thumbsup:
  14. Oct 2, 2020 at 4:31 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning, all. Beautiful day yesterday - some light showers this morning but the rest of the weekend is looking good. Going to extract some honey on Sunday! Yum!!
    06Tacooo and MtnAltitude like this.
  15. Oct 2, 2020 at 4:51 AM
    OverlandExpress
    OverlandExpress Well-Known Member
    NE Ohio
    2020 Taco TRD PRO
    Time to turn on the heat here in NE Ohio....
  16. Oct 2, 2020 at 6:50 AM
    JEEPNIK
    Well we can all sing along again. We’re having a heatwave”. But hey, it’s been really nice at the beach.
    06Tacooo likes this.
  17. Oct 2, 2020 at 7:39 AM
    MtnAltitude
    Colorado Mtns
    Good morning all. Who knew that I would look forward to a Hygienist appointment but I did and glad I got my teeth cleaner yesterday, oh what a feeling - LOL
    Smoke is back heavy today, we found out our 3 yr old Golden is allergic to the smoke - had an issue two years ago as well due to fires in the area with him but now we know for certain why his eyes get runny and his third eye is affected.
    Headed out to scout / glass for elk on Monday be gone the whole week in the high (higher) country. with all the fires in the area where I hunt we want to scout the herd migration changes the fires has caused.
    Have a great week everyone and by all means be safe
  18. Oct 2, 2020 at 12:54 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Going fishing today...or rather going drinking down at the beach.
    wdb, robin303, 12retire and 1 other person like this.
  19. Oct 2, 2020 at 1:00 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    any particular order these activities are being done in
  20. Oct 3, 2020 at 1:55 AM
    Devious6
    Mark
    Good morning, all. Looks to be a nice fall weekend for us here in northeast, PA.
