60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. May 27, 2021 at 4:47 AM
    gliderpilot
    gliderpilot Well-Known Member
    Tex (Mike)
    Central Texas
    19 Tacoma TRD Off-Road 4x4
    Thanks Tacoma Mike and roundrocktom for the response to my question about the A/C TSB. Would have said this yesterday but was busy in the yard taking advantage of an afternoon with no rain. Guess for now I'll just monitor the A/C cooling situation.
    roundrocktom, I did fly with the Fault Line Flyers 2010-2016. Was even on the BOARD a couple of years. Late 2016 I decided I was doing more work for/at the club than flying, so I sold my glider and left the sport behind. After 22 years, it was time. No regrets.
    Tex
  2. May 27, 2021 at 5:09 AM
    Tacoma Mike
    Southern Maine
    So got a text yesterday and had to go to the shop.
    They gave me this..
    And a card that everyone signed..
    Wasn’t expecting anything and was a nice surprise.
    Automotive field is not known for parties and such.
    More of “ get your shit and get out”.
    ImpulseRed008, 95SLE, wdb and 9 others like this.
  3. May 27, 2021 at 5:42 AM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Morning all:
    WHAT, no gold watch Mike, I would be happy to received that mug and shirt, now just don't get any grease on it! :D
    Talking about gliders, there is a small grass airport near me (Beltz's airport AKA Beltzville airport), where they fly gliders out of, last week I would hear the louder sound of a plane engine, look up, and there was a plane towing a glider. I don't know if they use a specific plane to tow them, but the engine sounds really loud compared to normal and seems to be going really slow.
  4. May 27, 2021 at 7:13 AM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
    Good Morning everyone.
    The AC TSB has me down the rabbit hole.
    I planned on mounting a second battery box in the back corner of my engine compartment. However, Underhood so flooded cells are best to resist heat, AGM's are better for vibration of off-road but don't do well with heat. Lithium underhood is not good, just too hot.
    You can get a Marine battery, and it would be happy with my fridge and CPAP. Charge while driving (DC/DC convertor like the Redarc 1225), or use solar when parked for more than a day. That was my plan. The TSB shows the Toyota guys will use those two 6mm fender holes for a bracket for an auxiliary fuse panel and relay. Viola, don't put a battery there until I get the supplemental AC fan addressed. More rabbit holes, I'll make my own version of a Jackery 500. I want 12V to be used for charging, but a simple relay will switch power from car battery to lithium-ion battery when I stopped.
    I need to do some research as I keep seeing "Alternator should be set to a higher voltage to charge an AGM battery fully." However, I'm questioning that as the charge profile needs to specify "at this temperature" Making it worse is rebranded suppliers list a voltage/but not a temperature. There are five manufacturers; most batteries are just "relabeled" from one of those suppliers. One has double the price, but a great warranty. They are just sourcing their batteries and hope for less than 10% returns under the warranty period or deny claims! Even Autozone realized "convenience is why people buy from us," so they doubled their price as most customers have a stranded vehicle!
    @95SLE The modern computers should drop AC when accelerating. Full throttle; turn off AC, turn off the Alternator (battery only) while getting on an onramp. Load shedding has been designed into vehicles for a few years. However, the newer Toyota uses LIN (Local Interconnect Network) for communication to the alternator. 130 Amp Alternator is less than 3hp drag, but everything adds up, hence load shedding.
    For anyone wanting to learn more, ST is one supplier of Automotive Car Alternator Voltage Regulators. Denso makes their own but doesn't publish details. However, this should give insight into the modern alternators and how they are evolving.
    L9496 Car alternator voltage regulator (2000's)
    http://www.st.com/web/en/resource/technical/document/datasheet/CD00055101.pdf
    Newer Generation device has more intelligence.
    Alternator voltage regulator with load response control (2014)
    http://www.st.com/web/en/resource/technical/document/datasheet/DM00046326.pdf
    LIN device (hint all done via software setpoints) (2016)
    https://www.st.com/resource/en/datasheet/l9924l.pdf
    NVM = Non volatile memory. This allows Tech Stream type control of parameters. Yes, there is another microprocessor inside the alternator, LIN communications with the ICU.
    Too many espressos. I need to go to Kyoto! (Missed a symposium in 2019, my wife had surgery) Cherry Blossom Festival.
    06Tacooo, johneman[OP], Sprig and 2 others like this.
  5. May 27, 2021 at 7:30 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Nice awards Mike. Well deserved I'm sure. Like Boats says, NO GREASE on it! I hate when I wreck my cool shirts.
    I'm thinking I'm glad my 2007 is from the stone age!
    :pccoffee: Good Morning Porch People! Looks to be a suitably hot and muggy day to mow. Then we're going to jack up the son's Prius, and fix that split chin before it gets worse. (He's good at maintenance if I bug him enough.) Here's a look at the total pepper fail - guess I will go shopping for some replacements tomorrow.
    Last Saturday coming out of the greenhouse, and today....
    :notsure:
    johneman[OP], roundrocktom and Sprig like this.
  6. May 27, 2021 at 7:38 AM
    roundrocktom
    If the tow plane "looked funny" with just one person cabin, most likely a Piper Pawnee. Commonly used for crop dusting, but make a great tow plane.
    One of my neighbor's friends came into our 3000 ft strip with a glider. I was thinking "when is the tow plane showing up?" It was a motor glider! Self-launching, motor pops up, and off you go (less than 1000' feet to launch). Well, clear off the neighbor's house at the end of the runway! House drops off from the runway, but on hot days that chimney looks too close. Density Altitude! It's Hot and humid this week so takes much longer to get airborne.
  7. May 27, 2021 at 8:06 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Good Morning Cool Old Dudes and Susan :wave:
    Heading to MonkeyMountain mid-morning. Trail report is good so we're going in with trucks & trailers. I'm hauling in the enclosed trailer we'll turn into a mobile tool crib complete with welder and generator. Danny hauling in little trailer that has been housing new young chickens in his garage the last month, stirring up quite a dusty mess he'll be happy to get clear of. I'll try to remember to grab a couple "wagon train" pics. Weather looks 50/50, so we'll hope for the best and deal with whatever the fickle witch throws our way. :)
    :hattip: Dave
    This smart phone internet based society we're becoming is a complicated double edged sword that cuts both ways ... convenient but heavily impersonal which tends to get highly aggravating. :notsure:
    :hattip: 6
    Take it easy with that pinched nerve Mark.
    :hattip:Tom
    My 2007 was that way the few times I needed to use AC, I think it's characteristic of the 4cyl for obvious reasons; happy to have the manual trans in those moments. ;)
    :hattip:Howdy Tex :)
    :hattip: Mike
    So glad they recognized you. :cool: You made a difference and the ones that matter will miss you. :thumbsup:
    :hattip: Carl
    :hattip: Wow, glad it don't get that hot here, or if, very often.
    Because all of this is :boom: for me.
    Good luck :fingerscrossed:
  8. May 27, 2021 at 8:52 AM
    johneman
    johneman [OP] Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    Good Morning Folks.
    Root Canal day this afternoon. Not looking forward to having it done, but I need to.
    That is a really nice gift Mike. Love the mug:thumbsup:. And like others have said about the shirt, "just don't get any grease on it". Not yet any way:).
    Take it easy at golf today Mark, don't want to aggravate the nerve in your neck.
    I had the same speed issue with my 2.7 L when using the AC or going up a hill with or with out a load Tom. Thankful I had a manual to down shift so I could maintain a steady speed.
    Have a great day folks and be safe.
    Oldie2007 likes this.
  9. May 27, 2021 at 9:20 AM
    Harry2015
    Harry2015 Well-Known Member
    Harry
    N.E. PA
    That's cool!!
  10. May 27, 2021 at 9:21 AM
    gliderpilot
    Tex (Mike)
    Central Texas
    Yep, there are many different types of towplanes .... Pawnee's, Cessna's, Callair's, L-19's (Birddog), etc.. In hot climates (best for gliding) the more horsepower the plane has the better, especially if it's pulling a heavy glider with water ballast. Filling the wings with water lets you achieve your max L/D at a higher speed .... important in contests or trying to set some record flight. The tow pilot will tow you at the speed you ask for based on your glider and weight. Typically 50-70 knots.
    And you're right. The trend the past 20 years has gone to motorgliders (think $$$$$). Two types -- self-launching and sustainer. A sustainer engine might be 15-20 HP and is only used if you're far away from a landing spot and need to gain some altitude to "make it back". Thing to keep in mind is with the engine extended your drag increases big time!
    Fun facts to know.
    Tex
  11. May 27, 2021 at 9:34 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :eek: Root Canal?
    https://youtu.be/z5xGL6SVukw
    Hope it goes well for you.
  12. May 27, 2021 at 9:45 AM
    Tacoma Mike
    Southern Maine
    Gold watch?
    Yea Right..
    the noise you hear is from a hi performance airplane. AKA more than 200 hp. It has a variable pitch prop so power and economy can be adjusted. The noise you are hearing is the prop in the take off/ power mode..
    Yes I am a pilot lol
    MQQSE, wdb, RustyGreen and 3 others like this.
  13. May 27, 2021 at 10:51 AM
    Tacoma Mike
    Southern Maine
    Well, I think polishing and cleaning for 12 hours is enough.
    But I’m retired. I have the time now lol.
    You can only polish a turd so much.
    Was real bad from the winter...
    So it will be full of pollen by this evening but at least I have a pic to prove it was clean
    At one time
    06Tacooo, wdb, RustyGreen and 4 others like this.
  14. May 27, 2021 at 12:20 PM
    Oldie2007
    Kurt
    Lockhart, TX
    Hardly a turd, Mike! And we all know it's well cared for.
    MQQSE, MtnAltitude, Sprig and 2 others like this.
  15. May 27, 2021 at 6:38 PM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    Yes! Fantastic store. They opened another in Douglassville and it’s not too shabby either.
    We’re renting the Mighty Ox this weekend to (hopefully) finish converting our poor ash trees into firewood. Supposed to get some rain but as long as it’s not pouring I’ll probably be out there. Will take a pic or two.
  16. May 28, 2021 at 1:24 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning, everyone.
    No golf for me yesterday - pinched nerve flared again in the morning so it was a slow day all around. Still bugging me this morning a bit. Ugh.
    Rain on the way - looks to be a wet, cool weekend.
    Stay safe out there!!!!
    Sprig, Oldie2007, MtnAltitude and 2 others like this.
  17. May 28, 2021 at 2:04 AM
    Tacoma Mike
    Southern Maine
    Morning
    Going to drop some more tools off at the boys house early this am.
    Then get some me time fishin in.
    Back to his place to feed and water the chickens.
    I asked him how long I need to chase them around for exercise.
    Lol.
    Sorry your having issues Mark.
    Pinched nerves suck
    wdb, Sprig, Oldie2007 and 4 others like this.
  18. May 28, 2021 at 3:07 AM
    johneman
    Ken
    Warwick,Bucks PA
    Good Morning Folks.
    Sorry to hear the nerve is still giving you issues Mark Hope you get relief soon.
    Isn't retirement great Mike. Especially the "me time". Enjoy the fishing.
    Easiest root canal I ever had (5 previous ones). No issues even after the feeling returned to my lips and mouth. Pick up the Tacoma from the body shop today. They were waiting on the black fender flare to come in. I hope they didn't use Amazon LOL.
    For those still doing the 9 to 5, have a great 3 day weekend. For all of us retirees, have a great weekend and most important, BE Safe.
    MQQSE, wdb, ImpulseRed008 and 5 others like this.
  19. May 28, 2021 at 4:43 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Mike: Nice gifts from your coworkers. You are starting into retirement correctly. I look forward to more racing pics for the races your team enters this summer season. Pit pics are always interesting.
    Ken: Glad the root canal went well for you yesterday.
    Today is easy but sort of busy. First hearing aid adjustment at 11:20 this morning. Need to do three errands before the appointment. I might be able to rehang 2 shed doors in the afternoon but that will probably wait till Sunday due to weather. Ribeye's on the EX6 for dinner tonight.
    Have a great day everyone.
  20. May 28, 2021 at 6:14 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    The closest "shipping point" to me is a Hub... and they won't accept the labels usually given by Amazon for returns. They "can't scan them"... so I have to jump through hoops to get something shipped back. The last time was when I ordered my Geolandars and they sent P tires instead of LTs. What a nightmare. How hard is it to have a scanner for returns?
    Good luck with your's.
