60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Feb 1, 2022 at 11:46 AM
    gliderpilot
    gliderpilot Well-Known Member
    Tex (Mike)
    Central Texas
    19 Tacoma TRD Off-Road 4x4
    Well, there's the National Electrical Code and the International Residential Code you need to follow. Would also be good to know how long the run is since there can be significant voltage drop at high currents over long runs.
    Assuming not that long a run I'd recommend 1/0 wire (3 wires plus ground since 240v). Put it in conduit (CANTEX) that's rated for underground. Depth -- depends on your local codes, but typically a minimum of 18 inches.
    How do I know -- BSEE and former professional home inspector in Texas.
  2. Feb 1, 2022 at 11:48 AM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    Thank you for that, I get it. I have ridden motorcycles on the street longer than cars, lol. I'm also a cdl truck driver for a living. So I totally understand idiot drivers. One of the reasons I got this bike is because it is a bike and I don't have to ride it out in traffic. It's a class 2 ebike so I can even ride it on the sidewalks which is what most motorist prefer. But it's also OK to ride in the bike lanes or to the right of the road. I'll be careful and observant as always and I will wear a helmet since it's a little faster than most bicycles.
  3. Feb 1, 2022 at 11:48 AM
    Tacoma Mike
    Southern Maine
    Hi Mike
    :wave:
  4. Feb 1, 2022 at 12:01 PM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    If your contractor is pulling a permit, be aware that your trench will need to be inspected as well. Even if he isn't pulling a permit, he may refuse to use your trench if not compliant. I would definitely use the approved conduit, and do the 100 amp service. Welders and compressors, electric car chargers, don't limit your service to save a few bucks now just because you don't at the moment have need for the added capability.
    Oh, and yes, four or six gang outlets everywhere. No sense running power to a two gang and have to piggyback add-on outlets after the fact, which is sketchy at best and unsafe at worst.
    Travlr[QUOTED] likes this.
  5. Feb 1, 2022 at 12:20 PM
    gliderpilot
    Tex (Mike)
    Central Texas
    :hattip:
  6. Feb 1, 2022 at 12:37 PM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Not enough information, but here goes. 100A. 4-wire (2 hots, neutral, ground) circuit would require #2 AL, or #3 CU., and a #6 CU or equiv. ground, providing your house service has enough unused capacity. Most home services cannot handle an extra 100A., since they aren't overbuilt originally. To find out, do the load calculations for your home as set forth in the current NEC. The easier way is to hire a licensed electrician. Make sure they get a permit and all the required inspections, so the project doesn't come back to bite you when you want to sell the house. Last but not least, talk to your insurance agent, bring your policy up to date.
  7. Feb 1, 2022 at 4:28 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Evening all:
    Was just watching a video of a plane trying to land at London's Heathrow airport, this could have ended badly!
    There were high winds and it looked like it may flip over at one point as it touched down and then decided to make a go round and try again, in the meantime it appears that it grazed the runway with the fuselage as it aborted the landing and tried to take off again. :eek:
    It's a good reminder as to why I don't like to fly!
    I think this is the same airport where I saw only the runway, than only the sky several times as we were wobbling in for a landing, it was either Heathrow or Prestwick, I had posted about that.
  8. Feb 1, 2022 at 5:15 PM
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    . Good batch of Pappy's super secret chili ready to go for tomorrow! I like to line the top with pepperoni and let flavor soak down in. Going to be a good Wednesday. My Dad's 84 birthday!
    wdb, woodtickgreg, Devious6 and 5 others like this.
  9. Feb 1, 2022 at 5:23 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Hmmm.... I happen to have some Pepperoni stashed for pizza....
    Devious6 and Sprig like this.
  10. Feb 1, 2022 at 5:25 PM
    MoneyMan55
    Doug
    South Central PA
    Give it a try Kurt you will not be disappointed if cooking in the slow cooker. Don't stir until later in the cooking process.
    Devious6, Sprig and Oldie2007[QUOTED] like this.
  11. Feb 1, 2022 at 5:41 PM
    Oldie2007
    Kurt
    Lockhart, TX
    How'd you know I was going to crock pot? I may not use that much though! Have to see what the victim...uh, wife thinks!
    I watched Alaska Air make FIVE passes at a totally socked in Juneau back in my Field Service days. Juneau is a bowl if you don't know. I saw the side, the top, the bottom, and the other side come out of the fog. The fifth try was a stuck landing! All of us in the departure lounge gave a standing ovation. You should have seen those people coming down the jetway! White as sheets!
    Then, we all got on. Coming back into the mainland, we hit turbulence that pushed me out of my seatbelt, and my head into the bulkhead! OW! Then I looked out the window, and the tip of the wing was above the top of the window! I closed the blind. There is a difference between knowing something is "supposed to do that", and wanting to see it!
  12. Feb 1, 2022 at 5:42 PM
    wanna taco
    alan
    SF Bay Area
  13. Feb 1, 2022 at 6:07 PM
    MoneyMan55
    Doug
    South Central PA
    Naaa 6 quart crock. 6 oz of pepperoni who's belly can't handle that?
  14. Feb 2, 2022 at 1:29 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Good morning fellow Porchatonians! Our temp is actually supposed to get above freezing today!!! Woo hoo!! I have a few projects for the truck but it's just been too cold in the garage for me.
    Stay safe out there!
    Oldie2007, MoneyMan55 and Harry2015 like this.
  15. Feb 2, 2022 at 2:05 AM
    woodtickgreg
    Greg
    Michigan
    8 to 10 inches of so for today, winter storm warning.
  16. Feb 2, 2022 at 3:55 AM
    Harry2015
    Harry2015 Well-Known Member
    Harry
    N.E. PA
    1st it's going to rain then sleet then freezing rain then snow!! ugh:censored:
    Oh well, we'll get through this.
  17. Feb 2, 2022 at 4:33 AM
    Tacoma Mike
    Southern Maine
    Yeah, that sounds familiar
    Devious6, Sprig and Oldie2007 like this.
  18. Feb 2, 2022 at 5:24 AM
    woodtickgreg
    Greg
    Michigan
    Pretty much the same thing here, then 8 to 10 inches of snow. And I'm a truck driver so I gotta drive in it, gonna suck today.
  19. Feb 2, 2022 at 5:38 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Lots of decent choices for an upgrade. When I put fog lights on my 09, first go round, I used a set of CIBIE. Great pattern and really cut through the rain/fog/snow. When I added round fog lamps to the existing cut out in the bumper, I went with PIAA. Both were halogen and decent choices. Seems that when a manufacture sells a LED unit as a fog lamp the beam pattern is more floodlight which is a solution you do not want, unless you are off roading. When I was looking to upgrade, I was surprised at what the makers of LED lights were touting as fog but resembled more of a flood pattern.
    Low Beams? LOL
    At least 2-gauge 4 conductor. This is a link, expensive option, IMHO, to an aluminum solution. 100' Aluminum URD Dyke 2-2-2-4 Cable Direct Burial Quadruplex Secondary Wire - Electrical Cables - Amazon.com
    Running out of home winter projects. Think I might paint my music/computer room.
    Devious6, 06Tacooo, Sprig and 2 others like this.
  20. Feb 2, 2022 at 5:43 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Alan: TY for the suggestion. I will look into the option. This is a link to my providers webpage on the lenses. The practice does offer the option. ICL Surgery in Greenbelt, MD | Dr. Jonathan Solomon (solomoneye.com)
