60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Jun 7, 2012 at 3:28 PM
    #3801
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :wave: afternoon all
    Liquid sunshine is gone from here for a few days. Been nice last few days... little cooler than it's supposed to be. :woot: for not needing the ac
  2. Jun 7, 2012 at 3:38 PM
    #3802
    RoyR
    RoyR Well-Known Member
    San Diego, CA
    Billies, TSB
    GEEZUZ, YOU GUYS STILL ALIVE??? :)
  3. Jun 7, 2012 at 4:36 PM
    #3803
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    How do you like the rear view mirror bracket?
    I need to check my Tacoma but I think my alarm system has a monitor located where the bracket would be located. I have an aftermarket alarm system
  4. Jun 7, 2012 at 4:44 PM
    #3804
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I had the same problem in my 66 Vette with the L72. The torque is amazing with the L72.
  5. Jun 7, 2012 at 4:49 PM
    #3805
    ImpulseRed008
    Susan
    SC
    I like it although I think the field of vision (out the back) is a little less, but that's ok. I can see more out the front
  6. Jun 8, 2012 at 3:18 AM
    #3806
    johneman
    johneman [OP] Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    Morning all...mostly sunny with some of the liquid sunshine in between...
    Quote:
    Originally Posted by RoyR [​IMG]
    GEEZUZ, YOU GUYS STILL ALIVE??? [​IMG]
    __________________
    Luv the "Get off my lawn" poster...kinda looks like me when I get mad...Ken
  7. Jun 8, 2012 at 3:25 AM
    #3807
    johneman
    Ken
    Warwick,Bucks PA
    Hi Carl, get the 66 all spick and span and come on down to Doylestown on July 8...the local chapter of Road Angels is having a car show at the Moravian Tile Works on Route 313...Ken
  8. Jun 8, 2012 at 3:20 PM
    #3808
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    evening all: really dont go to too many car shows, usually go to local cruises.
    still got to go over those darn valves, then should change oil, and should change rear fluid. once the valves are set right, then can tweek timing, carb., etc. THEN CAN CLEAN WHAT "WAS" A CLEAN ENGINE, AFTER ADJUSTING VALVES. I have the little clips to stop the oil from really shooting all over, but they don't totally keep it from running down over the motor.
    then there's the tacoma, that should have all the fluids changed.
    then there"s the "BOATS", and the lawn, and the doors that I should fix! :eek:
    as posted before, way too many projects!!! Or maby too many naps!
  9. Jun 8, 2012 at 3:23 PM
    #3809
    ImpulseRed008
    Susan
    SC
    tgif!!
    been thinking about re-financing my house and putting a screened porch on the back :goingcrazy:
  10. Jun 8, 2012 at 3:50 PM
    #3810
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    If you have a sizeable IRA you might want to look into taking some out rather than a refi.
  11. Jun 8, 2012 at 3:52 PM
    #3811
    ImpulseRed008
    Susan
    SC
    IRA's not that big... I'd get a better interest rate and go down to a 15 yr mortgage :notsure: Was thinking about a re-fi even without the screened porch
  12. Jun 8, 2012 at 4:23 PM
    #3812
    boatswain
    carl
    palmerton,PA.
    Hi sue! :wave:
    can't really help on this.
    If intrest rate is that much lower, it may pay to refinance.
    Once I owned my house though, I would never borrow against it and risk losing it, although lots of people do!
    I'd want to pay off the house ASAP, and go from there.
    there's something in my brain that just doesn't like paying interest. must be the Scotch Irish part :D.
  13. Jun 8, 2012 at 5:13 PM
    #3813
    ImpulseRed008
    Susan
    SC
    thanks Carl. I would never, except in a DIRE EMERGENCY borrow against my house if it was paid off. My folks lost a house that way :( I have been paying extra on my payment every month, to get it paid off sooner than 30 yrs. I'd also go with a 15 year mortgage. Not sure what interest rate I'd get, but it could be as much as 2% less...
  14. Jun 8, 2012 at 8:11 PM
    #3814
    boatswain
    carl
    palmerton,PA.
    Read alot on that subject.
    they always seem to tell you to take the 30 yr. mortgage, and double up on payments. that way if anything happens you have less of a payment on the 30 yr., but if everything stays OK, you will have pd. it off in 15 yrs.
    gives a little wiggle room if something should change!
    :notsure: but gives you something to think about. It does make sense!
  15. Jun 9, 2012 at 4:06 AM
    #3815
    johneman
    Ken
    Warwick,Bucks PA
    Sounds like you have a full plate Carl...always hated adjusting the valves cause of the mess the oil leaves...but like they say, "if you want it done right, do it yourself". I don't know how many hours I spent getting it right until I was happy with the way it ran...those were the days...Ken
  16. Jun 9, 2012 at 4:33 AM
    #3816
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I used to bump the engine until the valve I needed to adjust was in the correct position. Not as much mess that way. Seems like I always had one valve ticking after 100 miles of operation. I had cork valve cover gaskets to make it real easy to remove the valve covers.
  17. Jun 9, 2012 at 6:42 AM
    #3817
    boatswain
    carl
    palmerton,PA.
    morning all:
    always have do that on initial adjustment, after that I've always gone over them while running. I know that's another option, and less of a mess.
    these old habits are hard to change!
  18. Jun 9, 2012 at 6:43 AM
    #3818
    ImpulseRed008
    Susan
    SC
    :thumbsup: I was thinking that very thing.... interest rate on 15 yr are usually a little less :notsure: I just started thinking about this the other day, when thinking it would be super nice to have a screened porch :eek:
    :wave: morning all
  19. Jun 10, 2012 at 6:35 AM
    #3819
    zapper
    zapper Well-Known Member
    Paul
    Erie, PA
    2012 SR5
    We refinanced once, in 2004 to have the house sided and some new windows put in. We did home equity, and doubled up on montly payments. Our home will be paid off in less than a year, then we work on a car payment. After that, we are looking forward to Medicare and retirement. Susan, life is short, I think you deserve a nice screened in porch. Do it!
  20. Jun 10, 2012 at 6:42 AM
    #3820
    ImpulseRed008
    Susan
    SC
    :thumbsup: Thanks for the vote Paul.
    I'm looking at this two ways.... one - I would love a screened porch and if I re-finance, well, I'll be financing less than I originally financed and the interest rate is a lower. Two - not sure how long I will stay here, and it should help with the sale.
