60+ year old thread.
Discussion in 'Off-Topic Discussion' started by johneman, Jun 23, 2011.
  1. Aug 1, 2022 at 4:15 AM
    woodtickgreg
    woodtickgreg Well-Known Member
    Greg
    Michigan
    Well we are on day 5 of covid, yesterday was up and down. Fever comes and goes, its low grade but takes me from freezing and shivering to sweating. But at least the headache is gone. Still coughing up mucus but it seems to be in my throat and not my lungs. I'm not having any trouble breathing. Just feel like crap still. I have improved some but not out of the woods yet.
    My Betty has it to so we are both home sick and in bed. Her symptoms are milder than mine, I have it much worse. Slow improvement.
  2. Aug 1, 2022 at 5:13 AM
    lynyrd3
    Bill
    East Central Upstate NY
    :annoyed:Get well soon :thumbsup:
  3. Aug 1, 2022 at 5:19 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Looks like a distant picture of Somerset, PA. Those generators have been there for 20 years. the age may be telling. Up in the Thumb of MI. They are everywhere over on the Bay side. Mostly on agriculture farms. Local farmers, in Huron County, went to DTE about 20 years ago and DTE just laughed. A couple of farmers put one up on the farm, a smaller one, and the rest is history. DTE is not laughing so much now.
    I have a friend that lives in Phoenix. He once told me that when it is 105 outside, he does not go out. I cannot blame him.
    Today is an easy day. Just laundry and guitar practice.
    Oldie2007[QUOTED] likes this.
  4. Aug 1, 2022 at 5:58 AM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    Morning all:
    My solution has been to pour some gas into the hole at night when they are all in there and then pour a small line of gas to it and light it, so far that has gotten rid of them every time.
    If you don't hear a WA WOOM, you didn't pour enough gas in the hole! :laughing:
    Tom, it said that the wind turbine was in Luzerne county Pa.
  5. Aug 1, 2022 at 6:24 AM
    Tacoma Mike
    Southern Maine
    Improving is the word of the day.
  6. Aug 1, 2022 at 6:34 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    A friend of mine once worked a bit for the wind power industry and had some interesting remarks about the machines. At that point much of the design work was being done by aircraft engineers and his laconic (cowboy) comment was - "airplanes land - the mills don't, seems to confound them". Apparently "24-7" wasn't in their design handbook. Shortly after after he said this, I was headed to inspect a surface mining machine (dragline) near Hanna, Wyoming and passed a big Boeing machine (on the scale of these present mills) being tested near Medicine Bow, Wyo. Had to stop a minute to take in the scale of it - unusual at that time (30+ years ago). Cranking away in eerie silence. A few weeks later the local radio station reported that the machine had a catastrophic failure - I was headed to Rock Springs and swung by there to take a peek......... the prop was scattered all over the prairie in big chunks. When I questioned my friend, he said the prop pitch control had failed on one blade and it had thrown the whole unit into wild gyrations - local windspeed was over 40 mph (typical in my neighborhood in Casper was 35).
    The fields of solar panels seem to be a better maintenance risk to me!
  7. Aug 1, 2022 at 7:06 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    :pccoffee: :wave: sixtys/wannabes/covid sufferers.
    A local landowner wanted to put a solar panel farm in a field, had it all set up so it was above ground, no harm to the fertile land below, easily reversible back into a farmer's field if need be. Township shot it down as being environmentally unfriendly. :notsure:
    I got the rotted stairs patched up and put one dose of preservative on them. Still needs another dose. 6 parts borax to 4 parts boric acid; slowly stir 1 pound of the mix into one gallon of hot water, apply it with a sprayer or brush. I used a sprayer because I wanted to do underside and topside. It will eventually leach out and need to be redone but supposedly lasts quite a long time. I'll probably put the second coat on tomorrow.
    davidstacoma and Oldie2007 like this.
  8. Aug 1, 2022 at 7:17 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Did you use the same preservative on the stairs you replaced?
    Oldie2007 likes this.
  9. Aug 1, 2022 at 7:27 AM
    wdb
    Dave
    the perimeter
    plain jane
    I saturated the whole works. The new wood didn't absorb much -- I assume it is pretty well saturated from the pressure treatment process.
    Oldie2007 and Travlr[QUOTED] like this.
  10. Aug 1, 2022 at 7:30 AM
    Travlr
    Middle'a Utah
    The ones you built before these?
  11. Aug 1, 2022 at 7:53 AM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    Lucky!
    lynyrd3[QUOTED] likes this.
  12. Aug 1, 2022 at 7:57 AM
    Oldie2007
    Kurt
    Lockhart, TX
    :pccoffee: Good Morning Porch Pals & Gal! Happy Monday to ya'!
    davidstacoma likes this.
  13. Aug 1, 2022 at 7:58 AM
    wdb
    Dave
    the perimeter
    plain jane
    Ah! I get it now. We had them built for us. He used pressure treated lumber. I never put anything else on them, didn't think pressure treated lumber needed anything done to it. I know better now.
    Travlr[QUOTED] likes this.
  14. Aug 1, 2022 at 9:26 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    After noonish all!
    My first day of not having to work monday and tuesday on my part time job since I’ve now fully retired. Shipped my company laptop back to them this morning. Felt good not to have to be on another Monday Engineering Team meeting call! :D
  15. Aug 1, 2022 at 10:31 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Good morning-ish everyone. After my morning walk the clouds were out and I thought it would be a good morning to drain, scrub, clean, balance, and fill the hot tub. I don’t like the shell to bake in the hot sun without water. Got that done. Now I’ll start working on organizing documents for the next person who will get my job at the end of the month. 35E94E66-0E68-462C-BD81-0DCDCC562F1F.jpg72D2171C-2B4A-4B3D-ABE9-73369DFAEEEE.jpg
    woodtickgreg, 95SLE, lynyrd3 and 4 others like this.
  16. Aug 1, 2022 at 10:45 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Welcome to the club. Soon not only will you not know what day it is but you won’t care. No more Mondays. Every day is what ever day you want it to be.
  17. Aug 1, 2022 at 10:57 AM
    knayrb
    Bryan
    Pure stock
    So happy for you. I’m done on the 26th this month. Was going to do the 31st but my daughter is heading out of town and needs grandpa to tend. My wife will work until May 2023. It will be a long 3 weeks. In an hour I tell the CIO I’m retiring.
    Good luck and have a great retirement.
  18. Aug 1, 2022 at 11:05 AM
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    just so you know, don't take it personal, but that will be a non-event. He'll put forth his best impression of "Tell someone who gives a shit."
  19. Aug 1, 2022 at 12:19 PM
    davidstacoma
    David
    NC
    Good for you. Don’t believe them if they ask you if you will work part time until they get a replacement. I agreed and worked part time for 6 months and they never did hire a replacement lol. They tried to hire someone but it fell through. Finally had to say I’m done.
  20. Aug 1, 2022 at 2:52 PM
    knayrb
    Bryan
    Pure stock
    Actually we had a great conversation. He was very appreciative that I hung on until this huge 5 year project was launched and successful. We have worked together for many years as equals but 1 year ago he applied for the CIO job and I didn't. I've reported to him for the last year. He asked if I could serve on the selection committee to interview candidates for my position. Of course I will. We play golf together often and are just good friends. I have my projected payout worksheet, application for my pension submitted, and now notified executive management. The ball is rolling along now.
